Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,281
Doesn't it still depend on rotation?? My Ford Coarse Cut knives look similar to these and are mounted the same way. My rotor turns the same direction as the tractor tires when cutting. Thus, the cutting edge is on what appears to be the back side.
/ Let's talk flail mowers #2,282
Not sure if its true, but I remember reading that the PTO shaft rotates backwards on some gray market tractors.
/ Let's talk flail mowers #2,283
Good morning fellow members of the TBN forum and the esteemed members of The Flail Mower Nations.
After a night of somewhat restfull sleep:
If the previous owners mule was a grey market nag
with a Power Take Off that operates in that way wherein the
scoop knives rotate counter clockwise when looking at
the left side of the flail mower that explains the entire mess/opportunity.
It explains the condition of the existing scoop knives which
could have been or are most likely original equipment to begin with.
When the used in a flail chopper the scoop knifes would also
face forward which scoops the material up and throws it into
the cross auger which carries the green chop to the impeller fan.
When used in a flail harvester the cutting edge of the cup knives also face forward
and cut and throw the chopped hay up the chute and into the silage wagon.
The scoop knifes allow a higher suction to carry the clippings over the flail mower rotor.
there is so much we do not know as yet
/ Let's talk flail mowers #2,284
Yep. Rotor rotation direction is critical for scoop or hammer knives and easy to confuse. I think the simplest way to describe it is to use the tractor tires as a reference. The rotor either rotates the same direction or counter rotates. Easy to determine if you raise the 3PT and peek underneath (from a safe distance) when the PTO is started or shut off.
/ Let's talk flail mowers #2,285
A few did, mostly real small tractors though. Also, some flails were designed to mount on the front of tractors and used a different PTO speed and perhaps a different direction. One of my friends bought a Mott years ago that did not have the typical three-point mount. He fabricated a mount and was pretty proud of his bargain find, only to find that the mower spun the opposite rotation than expected and not at the right speed. He sold it cheap to another handy guy and bought a Vrisimo.
On knives, we sell almost 100% scoop knives in our area. Typical usage is mowing orchard grass and small twigs. For after pruning mowing, the guys are normally using heavy shredder mowers with hammers.
I mow my field and orchard with scoop knives and it gives a nice cut.
/ Let's talk flail mowers #2,286
A few did, mostly real small tractors though. Also, some flails were designed to mount on the front of tractors and used a different PTO speed and perhaps a different direction. One of my friends bought a Mott years ago that did not have the typical three-point mount. He fabricated a mount and was pretty proud of his bargain find, only to find that the mower spun the opposite rotation than expected and not at the right speed. He sold it cheap to another handy guy and bought a Vrisimo. On knives, we sell almost 100% scoop knives in our area. Typical usage is mowing orchard grass and small twigs. For after pruning mowing, the guys are normally using heavy shredder mowers with hammers. I mow my field and orchard with scoop knives and it gives a nice cut.
I've always thought that a front mounted flail would be the cat's pajamas. Easy to see exactly where you will be mowing and great for mowing close to obstacles. I've seen some of those setups in Europe but never here.
/ Let's talk flail mowers #2,287
The only downside would be managing the debris flow out of the mower so it stayed out of the radiator.
/ Let's talk flail mowers #2,288
I have a 5' front mount for my TORO 328D Groundsmaster. The radiator is back far enough that there is no problem with the cuttings.
Rotation is opposite of the tires. When the blades get dull, you can remove the drum and turn it around so the sharp edge will be forward.
437461-lets-talk-flail-mowers-p8110022-jpg
437462-lets-talk-flail-mowers-p8110024-jpg
437463-lets-talk-flail-mowers-p8110027-jpg
437464-lets-talk-flail-mowers-p8110034-jpg
437465-lets-talk-flail-mowers-p8110039-jpg
I don't have any pictures of it in use. This is what it fits on, after removing the rotary deck of course .
437466-lets-talk-flail-mowers-p4070002-jpg
/ Let's talk flail mowers #2,289
Why do you use the rotary mower instead of the flail? Does the rotary give a better cut?
/ Let's talk flail mowers #2,290
I'm glad we cleared up the confusion, but I can certainly see why there was some.
Here are the facts known at the moment-
(1) The knives in the picture are scoop knives
(2) They are also mounted backwards
(3) The true cutting edge is completely rounded over to actually give an edge in the opposite direction.
(4) The rotor spins opposite of the tractor tire rotation(moving forward)
I have a box of brand new scoops that I will install on Sunday when I get back in town and the paint is completely dry. I hope to take the mower back to the farm then and give it a shot. I haven't bush hogged in some time, awaiting on the day the flail is up and running.
For whatever reason I have issues getting pictures to upload or else I would show some close up picks of how bad the blades are. I wish I could upload from my phone to the forum... Nevermind it worked this time! The way they were mounted there was an edge that I thought would cut, maybe wind resistance had something to do with the no cut issue on top of the backward blades. IMG_20150802_211614347.jpg
/ Let's talk flail mowers #2,291
The leading edge of that scoop blade actually looks like it was traveling in the right direction and was bent back from impacting an object.
/ Let's talk flail mowers #2,292
For whatever reason I have issues getting pictures to upload or else I would show some close up picks of how bad the blades are. I wish I could upload from my phone to the forum... Nevermind it worked this time! The way they were mounted there was an edge that I thought would cut, maybe wind resistance had something to do with the no cut issue on top of the backward blades. View attachment 437479
YES, YES, YES, YES,
Your mower is OK;
tractor wheels running counter clockwise/flail mower rotor rotating
clockwise as you are looking at the left bearing YAAAAAYYYYYYY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Be sure to mount the new scoop knives facing forward
I was so worried you had a grey market mule you were using to run it.
/ Let's talk flail mowers #2,293
Most of the flails offered in Europe have dual mounting systems to mount on the
front and rear of most of their mules especially the ones with dual three point hitches
and rotating operator stations like the ferrari and lombarini mules and others.
The caroni mowers can be set up like that but the hard ware has to be removed then
reinstalled on the opposing side.
This not an issue for them as they have side slicers as standard equipment on their flail mowers.
Berti and many more builders have the dual frames where all that is needed is to remove the PTO shaft and reconnect the mower to the opposing three point hitch if the mule has twin power take offs and three point hitches
AND the flail mower rotors rotation will not be an issue with the dual cutting edge slide slicers.
/ Let's talk flail mowers #2,294
No, the flail has the best cut, but don't need that here where we live now. I have a 6' Recycler deck that trims up close on either side that I use on the yard.
attachment.php
attachment.php
attachment.php
/ Let's talk flail mowers #2,295
Xfaxman, doesn't the pallet have a negative impact on the cut quality of your flail??
You being the "picture guy", can't believe you posted pics of your flail with a pallet wedged in it. :confused3:
/ Let's talk flail mowers #2,296
Xfaxman, doesn't the pallet have a negative impact on the cut quality of your flail?? You being the "picture guy", can't believe you posted pics of your flail with a pallet wedged in it. :confused3:
He was using the flail to mow the lichen off the pallet as a demonstration of what a fine mower it is.
/ Let's talk flail mowers #2,297
Holy Camoly!!! I was going to guess that!
/ Let's talk flail mowers #2,298
Yep, it does, but the pallet knocks down the high spots and fills in the low spots. :thumbsup:
It was on the pallet or nothing. :D
Thanks, now I know what I was doing. :laughing:
/ Let's talk flail mowers #2,299
Question for all experienced paint guru's..... I put 2 coats of john deere paint on my flail the other day and I ran out before I could finish with a final coat. The paint specs say to wait at least 36 hours before adding another coat if you miss the "tacky" window. It has now been 36 hours and I was going to apply 2 more coats this afternoon before I go out of town so it would be ready to cut on Sunday afternoon when I get back. The question is do I need to sand or scuff before applying more coats, I would think the answer is yes, but I am no paint expert? And on that note can anyone explain what sort of chemistry is happening between the tacky window and 36 hours so that further coats would not adhere so that I can better understand paint chemistry a little? I'm assuming that after 36 hours the paint is cured and would need to be scuffed to apply more coats, I just wish the instructions said that. I'm not trying to make a show paint job by any stretch of the imagination, but more for rust protection and I wanted to try the John Deere paint to see how it held up as I'm going to paint my 4230 this fall/winter.
/ Let's talk flail mowers #2,300
Well, it doesn't look like I'm going to paint today after all. I tested the paint with my fingernail and it dented and scratched off so I'm assuming it's not cured or I have other issues.... I didn't use hardener with the jd green and I used rattle can rusty metal primer. Should I be concerned? Can I spray hardener on my next coats in a few days?
SET OF 26' & 36' GATES (A62131)
SET OF 26' & 36'...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
1994 GMC Yukon SLE Multipurpose Vehicle (MPV), VIN # 1GKEK18K3RJ733313 (A61165)
1994 GMC Yukon SLE...
1994 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61567)
1994 Gehl DL11-55...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
