Help with Hinomoto E2304
/ Help with Hinomoto E2304 #1
Kody500
Chickasha, OK
Hinomoto E2304
I own a Hinomoto E2304, I cannot seem to be able figure out how to turn the PTO off. And by doing this would it fix the problem i'm having with box blade not going up and down? Any help would be much appreciated!
/ Help with Hinomoto E2304 #2
use the clutch to disengage the pto (set the lever in neutral).
no, it is an independent pto as far as I know.
Okay Thanks. For some reason my box blade will not raise and lower, and I don't know how to fix it, I have tried everything that I know of.
/ Help with Hinomoto E2304 #4
Have you checked the knob under your seat ? Try turning it left and right to see if the lift reacts ...
/ Help with Hinomoto E2304 #5
Most Hino's have a plate near the rear end that holds the hydraulic filter.
Drain the hydraulic fluid, find and remove the plate and filter.
Clean the filter, reinstall both and refill the fluid.
The 3 point will then work.
Ken
Thank you I will try that and see what happens.
FREIGHTLINER GRAIN TRUCK (A63291)
FREIGHTLINER GRAIN...
John Deere 4044R (A62177)
John Deere 4044R...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
