Asphalt shingle installation ~ need advice ~ (pics)
/ Asphalt shingle installation ~ need advice ~ (pics) #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
The roof on the dog house covering this well was severely rotted and the tarp being used to cover it looked ratchet so in a spur of the moment I replaced it on Saturday..
I used PT 2x4 and plywood (3/4") and the best tar paper Lowes had.
My concern is the nails I put on the side edges.. I think I had to at the top edge but I put them on the sides because it was a pain cutting the overlapped shingles.. My back was bugging me lol.
I don't know squat about roofing, first timer..
What do you folks think?
/ Asphalt shingle installation ~ need advice ~ (pics) #2
Take some scrap small pieces of your shingles and hammer it down over nail heads,do on a hot day will help.
/ Asphalt shingle installation ~ need advice ~ (pics) #3
it's a dog house, it will be fine for years. don't ever do that on your own house though, that's why shingles adhere to each other so you don't have to.
I call it a dog house for lack of perhaps a proper term. This enclosure covers a well.
I'd prefer it not leak.. I'm thinking it would not be a good idea for it to be moist during the winter and I'd rather not have to come back and do this again in a couple years!
I think I like the idea about putting pieces over the nails, might look better than dabbing tar on them. That stuff seems to cook out in a few years anyway.
/ Asphalt shingle installation ~ need advice ~ (pics) #5
I would buy a tube of caulking designed for roofs and cover each nail head. Henry is my favorite brand and it's sold at Home Depot in their roofing isle. Lowes has something very similar if that's closer. Just make sure it's for roofs and it's black. Just put a spot on each nail head and spread with your finger.
How did you flash the high side? Ideally you want the metal to overlap the siding so there is no way for moisture to get behind the siding or into the structure.
/ Asphalt shingle installation ~ need advice ~ (pics) #6
Its just fine for a covering for your well. Like has been said - don't nail the edges on your house roof.
Another point - unless there is something I don't see here - there is no ventilation on the "doghouse". Humidity/moisture accumulation inside the structure is what has led to the rotting of the wood. You might consider poking a couple holes - 6" - on opposite ends and installing screened vent covers.
/ Asphalt shingle installation ~ need advice ~ (pics) #7
:banghead::banghead::banghead:
Thanks Eddie and Oosik.. I like the venting idea.. I'm going out of town for nearly 2 weeks so I'll revisit this then. If anyone has any other suggestions I'm all ears..
And M5Farms, I know lol
It was dumb, I can't believe I did it.
/ Asphalt shingle installation ~ need advice ~ (pics) #9
Eddie is right the drip edge on the top should of been on top of the shingle. You dont really need nails on the edges closest to camera. One day in the sun and they stick. Use a roofers black polyurethane (i think is what it is) caulk. Its real rubbery and black and can take the sun. I buy at lowes as we dont have an HD close. I think thier brand there is Black Jack and sold in the roofing isle. It stays soft and pliable to expand and contract.
Also it looks like i see a nail head between the tabs of the top shigle. At the end of the first shingle bwtween its last tab and the tab on the first of the next one on the top row. Put of caulk/sealent on this head as well. Lift the tabs to apply it if partially covered. Also do it with any other head you see anywhere. You should have your nails all fall completly under the tabs on the above rows.
/ Asphalt shingle installation ~ need advice ~ (pics) #10
WHAT?!?!? Perhaps I am not reading you right, but the term shingle in the building world means to make sure the water that runs off of one thing goes OVER the next thing and not behind it. Drip edge over the roof shingle means the water will run behind it. Bad hoodoo. And I don't believe that is what Eddie said either.
/ Asphalt shingle installation ~ need advice ~ (pics) #11
Also seal up the corners of your drip edge to keep water away from the ply wood deck.
A roof vent on the top would help. Make sure it is installed correct to keep the water out.
Dan D.
/ Asphalt shingle installation ~ need advice ~ (pics) #12
No, they are all right and you maybe didn't see the picture. On a "shed" roof like that, the drip edge should overlap the shingles on the upper (high) edge of the roof. The drip edge will then overlap the top course of shingles. On all the other edges, the drip edge goes under the shingles.
/ Asphalt shingle installation ~ need advice ~ (pics) #13
OK - the top edge. That makes some sense... But still that is not typical for shed roofs I have seen. Of course most shed roofs die into a wall at the ridge, so there is no drip edge...
/ Asphalt shingle installation ~ need advice ~ (pics) #14
Don't use caulk to seal something--look for the term 'sealant' on the tube. Regular caulk is a gap filler, but lacks adhesion and expansion properties a compound designed as a sealant has. Don't mean to mince words, just failed to note the difference myself before, and it does make a difference. Good old tar is hard to beat for abilities to 'run' in the heat and hold in the cold when it comes to shingles--look for roofing application if you go the sealant route.
/ Asphalt shingle installation ~ need advice ~ (pics) #15
well i guess technically its better than a tarp
/ Asphalt shingle installation ~ need advice ~ (pics) #16
more than adequate for your wellhouse.
I let the shingles overhang the sides 1". Never ever would I put drip edge on top of a shingle, even at the top of a shed roof. drip edge would still be under with the shingle extending 1" past. Also, would cut and put tabs at the top over the top part of the shingle that is to be covered. The only exposed nails would be on that last top row.
28ft Metal Frame Trailer (A65563)
28ft Metal Frame...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
1996 International 4800 Bucket Truck, VIN # 1HTSEAAN6TH399113 (A65563)
1996 International...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2013 LAY FLAT REEL TRAILER (A65643)
2013 LAY FLAT REEL...
