Another Firewood Processor
/ Another Firewood Processor
Bags came in.
I built a frame to hold the bags out of 2x4s and various recycled lumber. Seems to work well. I will need more clamps on it though.
Not snazzy but we are holding off to see if we like these or want to spend the dough on DinoBags down the road. Not sure if the ease of bag setup and removal is worth 3-4 times the price...
Opens up to remove the bag.
Tractor has no issues lifting the pallets. I can double or even triple stack them if I were dumb enough to do so.
The bags are from bagsupplies.ca and seem to be very durable. You can see that this pallet was all small rounds. It is just the bag that is keeping it together, nothing was stacked.
Thanks Ken, this will save us an enormous amount of time!!!
/ Another Firewood Processor #82
A couple of observations on your indeed rollers:
Does the chain just sit on top of the middle sprockets with gravity to hold it in place? If so, I suspect you will have problems with the chain jumping on them. I think on Ken's he put some idler sprockets on the top side to ensure contact on the middle ones.
With the way you have the 'sprockets' at the center of each infeed axle, it would appear that once you pass a certain diameter of log, they will no longer be making contact and the log will be sitting on the sides of the V of the trough.
You can't see it in that picture of the chain I posted yesterday but there is not one long chain running all of the bars. Each bar is run independently from the previous bar.
The infeed though was designed to be wide enough to hold our largest diameter log without hitting the sides, but that is for a straight log. We will have to see what happens when we start running it. We milled the keyway wide enough so we can add more sprockets towards to outside if we need to.
/ Another Firewood Processor #84
Looking at your log trough, I too think you will have problems feeding the log. What is the reason the sides of the trough where made so high? It looks pretty narrow at the bottom as well. Normally you see a shallow trough with sides just high enough to keep the log from rolling off. as shallow trough will allow a crokked log to pass thru, but I am afraid that what looks like close tolerances with your setup, I think anything but the straightest of wood will get in a bind.
I designed it based off of Ferguson's. Though mine is wider and therefore the sides got taller. If I had it to do over again the sides would have been shorter for sure. The entire machine is tall, taller than it looked on the computer screen. At this point we will give it a try. If it doesn't work then I guess I will get my chance to make those changes.
/ Another Firewood Processor #86
LOL, I've been blessed with those chances a few times myself! Its all going to depend on how straight the logs are. I had one that needed a little persuading from my pallet forks but if most of your logs are straight, its just easier to deal with the one or two that aren't. It doest take much of the log touching when you basically have 6 wheel drive.
Glad you got the bags, he's a good guy to deal with. I read the concern about slumping and unloading a while ago in this thread but I haven't had any time to respond. Both are valid concerns but having used them for the last 4 years I can say they're incredibly strong and will hold the wood even if it's slumping badly. They were a PITA to unload when I first started using them but I've just figured them out with time, its no big deal now. The time and effort it saves stacking and bringing wood to the house far out weighs the slight difficulty you have unloading them. I will no longer lift a single piece of firewood before bringing it in from the deck to burn it. I used to pick the same piece up 9 times before it was in the fireplace.
Don't be tempted to stack them 3 tall by the way, they move and settle with time. You still need to be able to slide your pallet forks in to retrieve them in the winter. At least one of mine moved so much I basically had to slide the fork under the bag instead of the pallet on one side. Wouldn't want to drop one that was stacked 3 high!
/ Another Firewood Processor #87
Very neat project. Also you've really nailed using sketchup I use it but not to the same extent and detail, doesn't it take forever to draw things like that?
Been a while...
Thanks for the compliments. The drawing was not done over night. It was months of planning and different iterations that got us to this point. I am a planner. So I can't imagine how to go through this type of project and NOT have a plan like this. (I know that I am a little nuts however)
Ken, I will not be stacking these 3 high. Some of the pallets that are 2 high will be interesting enough like you say.
Ok, so progress... We've done a lot and there is so much that I don't have photos for yet. I'll give you what I've got.
Hydraulic tank:
Here is the end plate with 3" suction port (we have a suction strainer that will go in and reduce the opening to 2") 2" return port (will be reduced to 1-1/2), 2 " fill port, and a port for a temp gauge.
Here you see we made a baffle right above the suction port on the inside of the tank so that it can't create a vortex and suck air.
Here is the longitudinal baffle inside the tank which makes the fluid run to the far end of the tank and back again to get from the return to the suction port.
Finishes tank with a 1/2" breather port in the top and two 3/4 drains in the bottom.
Here it is mounted on the processor. The return is plumbed in for the most part. Misssing the oil filter in this pic.
Picture of the return manifold from the other side.
Pusher plate and ram are in place. We have welded on some scraps of 2" square tube to hold the logs during splitting.
Infeed trough has the plates welded in place.
Fuel tank is mounted
Engines are welded in place. Had the local exhaust shop bend and swage pipe to fit the two engines. Didn't want exhaust running into the fuel tank or the block of the other engine.
First load of my logs are delivered and wouldn't you know it... It's got the smallest diameter stuff that I've ever received.
Much more is done. Need to get pics.
We are hoping to have it up and running this week!
/ Another Firewood Processor #90
Good to see an update, I was wondering if you guys had scrapped the idea and taken up golf or ping pong. LOL
How tall is that pusher block? It looks really tall hopefully you won't have a problem with it bending in at the top like I did with mine. Looking good though.
Good to see an update, I was wondering if you guys had scrapped the idea and taken up golf or ping pong. LOL.
No, most extra curricular activities have ceased over the last couple months. Focused on the build. Looking forwart to playing some Stump after this is up and running. We have quite a crew that wants to come up and see this thing work. None as much as us though.
Got some pictures of the progress at the end of the day today.
At this point we are pretty much just waiting on hoses to try this bad boy out. A little disappointed that it is taking 10 days between order and receipt of the hoses from Surplus Center. But I guess it is a fairly big order and if I were in the warehouse I'd want to keep putting "that order" on the bottom of the pile too.
Valves are all mounted. Some of the tight hoses we had custom made rather than dealing with extra hose and finding a place for it.
-Auto-cycle splitter valve is all the way on the left with the 2 handles. Pull them both down to detent. THe cylinder will run to the end of its stroke and one lever will release. The cylinder will return and then the second will release.
-2nd from the left is the saw motor valve.
-In the first bank of 3 valves we have the saw actuation, the log clamp, and the infeed advance.
-In the second bank of 3 valves we have the multi-wedge lift, the infeed table log stop, and the infeed table lift.
A lot more stuff going on a bit further down the machine.
Got an enclosure to hold all of the electrical. Tach/hour meters to the left of the key switches. We placed a digital hydraulic oil gauge in the display window of the panel. We still need to get longer choke and throttle control cables for the splitter engine.
Bar oil tank in the upper left. 4 PSI/30GPH 12 volt fuel pump to pump the bar oil. After the pump it goes through a needle valve and then a check valve/ball valve before the line runs over to the saw.
Here you see the saw valve
In this closeup of the saw valve the saw is off. You see that we have a switch that will turn on the fuel pump when the saw valve is actuated. When you push the lever down to turn the saw on it pushes the spool up. This releases the switch which turns the pump on. We installed a triangular stop that prevents the lever from being pulled up (extending the spool down) and putting the saw into reverse.
Closeup of the saw valve in the run position.
Here is a pic of the oil cooler circuit. It is a bit difficult to see since there are bags that cover the open gauge ports obscuring the view. In my hydraulic thread someone advised against this and to purchase a larger cooler that has a minimum of 1-1/4" ports to take the full flow. The group decided that this was cost prohibitive since we are not a commercial operation. We will try this and see if it works for us.
The supply to the cooler is on the right. After that there is a ball valve in the main 1-1/2" return line. After the ball valve there is the return from the cooler. We will adjust the large ball valve in the middle to achieve a 10 PSI pressure drop through the chiller. I will get you a better picture after Tuesday when the gauges come in.
Here is a pic of the suction and return from the tank. The tank is filled with fluid and is not leaking. phew!
Pusher plate (which is 20-1/2" tall including the plates at the bottom) has its roof on it. This will allow us to simultaneously split and cut. If a cut is finished before the ram is fully retracted the log will rest on the roof and drop off into the splitter once fully retracted. It works in my mind, we'll have to see how it works in reality...
Pusher plate has grab hooks welded on either side in case we need to pull a log back out of the wedge.
Video of the two engines running. That makes us happy! Although only one of them starts. The saw engine has toasted 2 starter solenoids. Need to find out what is going on there. Not sure what it could be, the other engine starts just fine.
That is more or less it for the progress. We have a polycarbonate window to put in over the splitter and saw valves. We ran into an issue with our saw plate. We need to recess the motor into the back side of the plate further so that we have more of the shaft to grab onto on the sprocket side.
Hoping to see things start moving on Tuesday or Wednesday at the latest.
/ Another Firewood Processor #92
Thanks for the updates. Looks like progress and the end is near.
Have you got some sort of bottom stop built in that the saw can't hit the top of the push block?
Yes, it only travels to horizontal. A good distance above the pusher. Should be 4+ inches above.
/ Another Firewood Processor #94
Very impressive Bill!!! My Mrs wants to know how much something like that costs so she can buy me one:thumbsup:. I told her it would be cheaper to just buy presplit wood.:laughing:
You can tell her that we have $11,691.66 into it at this moment. A bit more than the $8000 upper end that I was initially thinking.
All of those little things really tend to add up! As for purchasing one with these capabilities you are looking at least $30,000 to $40,000
I believe you can find smaller ones that start around $10,000 though. In the end even that is a lot of firewood when you consider the upcharge for buying cut/split/delivered...
/ Another Firewood Processor #96
Wood her is now going for 350 to 500 a cord so that's still alot of wood.
ITS ALIVE!!!!
Got the last of the lines installed tonight and fired it up. Had two leaks that were easy to fix. The oil filter and a fitting that wasn't tightened. Not bad at all.
We got the bar oil pump primed late so we did not put the chain on. Motor at least spins though. Looks like we will may take the needle valve and the check valve out of the line for the bar oil. Seems to have a nearly perfect flow without them in the loop.
Our biggest issue is that the I-beam bends way too much! With the splitter valve relief set at 2000 psi we saw both ends of the beam flex and we saw the beam twist near the rear mount. Not good at less than 20 tons, really it was pretty scary! We are going to box the beam in on both sides. Probably with 3/8" so that it looks like this
____
Next biggest issues are slightly embarrassing, but hey, I'm a beginner at this hydraulics stuff.
-First, My initial plan was to run some additional hydraulics off of the power beyond from the log splitter valve. I ended routing those items to a different pump but still ended up purchasing the calve with power beyond. So is there any way to convert this so the power beyond flow goes out the out port or do I need to plumb the power beyond to the return manifold? Could I just tee into the current line running from the out port or will I have an issue backfeeding something?
-Second, Looking into power beyond. I have 2 valve bodies each with 3 directional valves. I just plumbed the out from the first into the second. Am I OK doing this if I only ever want to use one function at a time or do I put too much pressure on the output of the first valve somehow? I could convert the first valve in the series to power beyond. We'd just need to cut and re-weld the mounting plate since the location would change.
-Last hydraulic issue, I see that my log clamp pressure bleeds down. Is it a lock valve that I would want to prevent this?
22HP engine seems to be bogging down easily under what I would consider to be light pressures. 1500 PSI on the 6.5 GPM Pump. Tomorrow we will try to see how it works when running the saw with the 17.4 GPM pump. That will be the acid test...
/ Another Firewood Processor #98
I looked into getting an auto-cycle valve but I have been hesitant to do so. When I was reading the manual for the, the retract set point had to be a few hundred psi higher than the extend set point and also a few hundred psi lower than the pressure relief valve So I would lose a fair amount of splitting pressure by using one. At least that is how I read it.
Ken
Put the first log through the processor this evening. Made no adjustments to any valves as of yet. Still have a rats nest of hoses. Waiting to see how things come off the wedge before we build the splitter outfeed grates.
How'd it run? Not too shabby...
/ Another Firewood Processor #100
Good job. Seems to work pretty well definitely faster than a chainsaw a splitter. :thumbsup:
KMC 216-18' HEAVY DUTY ROTOTILLER (A62130)
KMC 216-18' HEAVY...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
New/Unused Landhonor No Till Seed Drill (A61166)
New/Unused...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
