Diesel Programmer's
/ Diesel Programmer's #21
DPF issues it wouldn't regen I guess and the filter says at 80% had the horrible smell for like 3days even it just setting there. Anyways been driving it more to try and get it clean but I am only getting 10.8mpg. I could go get it cleaned and be back doing it again,when? Or I just go ahead get rid of the none sense,increase my mpg and pull better. I looked into Smarty at first but they can't do the deletes.
You're right, I just looked on their site and did not see anything. What's strange is there isn't anything for the 08 model either and I know they used to sell it because I've been trying to talk my dad into deleting his 2008, maybe they didn't want to risk getting in trouble selling a delete tune.
I'm thinking they probably will but not saying so. I read the deal on EDGE a don't see how the others did t get the same fines,guess it was just wording I dunno.
/ Diesel Programmer's #23
Jim,
I run a Smarty Jr. in my 2003 Dodge/Cummins Ram 3500. I keep it in performance tune at 100 hp. I can squeeze 2 mpg more out of it..............if I keep my foot out of it. I love it and suppose to change it to 50 hp tow mode for towing, but I don't................and just keep my foot out of it. Manually changing tunes is a pain.
hugs, Brandi
Be careful not tuning down to tow. A buddy of mine ran a Edge on his Cummins and forgot to tune down with his 10,000# boat. He accelerated hard then let off of it and the back pressure blew the intercooler apart.
I know on my Fords I ran Quadzilla. I have a 60, 120, 180 HP gain. They don't recommend going past 60 for towing for this very reason.
Chris
/ Diesel Programmer's #24
What is the "deletes" that is mentioned several times. I have thought about programmer/ chip for my 2006 but the deletes reference is not familiar.
/ Diesel Programmer's #25
That is for deleting the DPF (diesel particulate filter). Your 2006 doesn't have that.
/ Diesel Programmer's #27
Give Phil a call at Anarchy Diesel in Tennessee, I have a 08 Cummins that had 3 turbos replaced before 50,000 miles. EFI is the best tuner on the market and Phil is one of the best in the country with top customer service. I did not care about lots of extra power, just looking for a reliable truck. No problems for the past 35,000 miles and fuel mileage went from 15.5 to around 19 to 20 in the summer. Google AutoCal Lite, it has 3 programs, one 50 hp - 75 hp - 100 hp. You will smile every time you drive your truck.
Eddie
Eddie
Tennessee little far drive for me,lol.
Brandi I see there is Relentless diesel performance in Willis
/ Diesel Programmer's #29
Jim,
Just checked out their website. I gotta go visit them. That area of Willis is growing fast with Mom and Pop businesses. I don't go that way often, as that is the crowded, lake side, of Willis.
hugs, Brandi
Jim,
hugs, Brandi
I am taking my truck there thursday morning to get everything done.
/ Diesel Programmer's #31
Have any of you long wheelbase Cummins owners swapped your 2pc driveshaft for a single one?
I ordered one for my MegaCab and plan to pick it up at the dealership tomorrow. I've read that it makes the trucks a lot smoother.
Travis
Travis
I have never even looked until you said something. For a dually mine rides pretty nice thou,sometimes forget even in a 1ton.
/ Diesel Programmer's #33
Yours could already be a 1 piece. They used both one piece and 2 piece, often on the exact same model trucks. The 2 piece has a carrier bearing that is known to wear and cause vibration.
Mine's an 06. The dealership couldn't recommend a 1pc part# for my truck, but I found it by researching the forums. There's hours of reading on that topic.
Travis
/ Diesel Programmer's #34
Mine is a shortbed and it has a nasty vibration at somewhere around 65 to 75 mph. Faster or slower it goes away. I've also done some reading on the forums and its seems its usually the driveshaft, but not always. It can be very hard to fix.
/ Diesel Programmer's #35
Have any of you long wheelbase Cummins owners swapped your 2pc driveshaft for a single one? I ordered one for my MegaCab and plan to pick it up at the dealership tomorrow. I've read that it makes the trucks a lot smoother. Travis
My 07 LWB has the two piece shaft while my dads 08 LWB has a aluminum one piece. I have two buddies that swapped from the 2 piece to a aluminum one piece and both said the truck was smoother after. When I need to start replacing u-joints in mine I'll probably just order a one piece.
/ Diesel Programmer's #36
Yours could already be a 1 piece. They used both one piece and 2 piece, often on the exact same model trucks. The 2 piece has a carrier bearing that is known to wear and cause vibration. Mine's an 06. The dealership couldn't recommend a 1pc part# for my truck, but I found it by researching the forums. There's hours of reading on that topic. Travis
The only truck I have ever owned with a 2 piece drive shaft was my 05 Dmax. It ate carrier bearings and U-joints also.
Never thought of swapping in a one piece.
Chris
I looked under mine and it's a 2 piece. So I desided finally on these
RaceMe pro with touch screen,that will be able to monitor boost,EGTs,ETC and can change levels on the fly
MBRP cat-back 4"exhaust with muffler
DPF and EGR deletes
/ Diesel Programmer's #38
Hmmm. Shortbed would be a 1pc anyway.
I don't have any nasty vibrations, but it shudders a little at takeoff and has some annoying bouncy vibes on the interstate. I do have a 4.5" suspension lift and 35s though.
I'm planning to change mine out today before I go home, so i'll let you know what happens.
I guess you gotta take the bad with the good when you drive a real truck with straight axles. :laughing:
Travis
/ Diesel Programmer's #39
I ran an Edge in my 03 Powerstroke for the 10 years I owned it. Kept it on race program. 80 HP increase. No problem since I opened up the intake, exhaust, and put in gauges.
/ Diesel Programmer's #40
DPF and EGR deletes
Nice. You're definitely gonna have a smile on your face!! :thumbsup:
Travis
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
JLG SKYTRAK 8042 TELESCOPIC FORKLIFT (A64279)
JLG SKYTRAK 8042...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
