Diesel Programmer's
/ Diesel Programmer's #1
foreman Etexas
Elite Member
texas
Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
I'm currently running a 2011 cummins,just curious what brand you are running and/or any suggestions. My plans currently is to get the EDGE CTS programmer and remove the DPF/muffler and install a FLO PRO. I'm not about the straight sound,just looking to gain on MPG and Pulling,not anoy the neighbors:laughing:
/ Diesel Programmer's #2
Been a while since I owned m 2004 dodge cummins diesel,sold it 2011.Back then edge or smarty were the programmers of choice..
/ Diesel Programmer's #3
Look at the H&S programmers. You may have a hard time finding one that removes the DPF. I'm running H&S not deleted 120hp tune. The nice thing about the mini max I run is I can change power levels on the fly. I think you have an auto but just to let you know the power increased enough to slip the factory clutch in 5th and 6th gear. I replace the factory clutch with am aftermarket clutch to handle more power than I'll ever make and all has been good. My 2012 long bed 4x4 with a work body returns 20 on the highway and 16 or so in town.
/ Diesel Programmer's #5
I ran Bully Dogs in all my 6.0 PSD. Never had any problems.
/ Diesel Programmer's #6
Check out atp trucks. I bought from them on my duramax. I got EFI live, I pull the 7060 around with ease getting 9-10mpg (I think). You can tell the exactly what you want and they customize the tune for your needs. I also deleted everything, egr and dpf replaced with Flo pro muffler.
/ Diesel Programmer's #7
I have ran PDQ and Quadzilla on my 4 diesel trucks. 3 Fords and one GMC.
Chris
You haven't run into any issues not being deleted with the programmer?
My brother run his 6.0 in extreme mode a lot(don't know what programmer he had) but never heard him having any clutch issues and he pulled a 5th wheel a lot. Now he had a lot of other issues he has had to fix but that's a whole different story. His truck was pretty fast but I am not about the go fast,he is the drag racer in the family. Don't wont to run coal either,lol.
/ Diesel Programmer's #9
You haven't run into any issues not being deleted with the programmer? My brother run his 6.0 in extreme mode a lot(don't know what programmer he had) but never heard him having any clutch issues and he pulled a 5th wheel a lot. Now he had a lot of other issues he has had to fix but that's a whole different story. His truck was pretty fast but I am not about the go fast,he is the drag racer in the family. Don't wont to run coal either,lol.
Yeah that's another reason I didn't delete. I don't want to roll coal. I think doing so doesn't make sense. No issues at all running programmed and not deleted. I have right at 90,000 miles and programmed it at 3,000 miles. The mini max I run also shows the pyro using the factory pyro gauge so you don't have to drill.
Along with being able to disable the TPMS, adjust tire size, turn off seatbelt chime and other features I don't recall.
I think the main thing I need to do is delete the DPF and EGR. Getting the regens gone from my lack of driving at highway speeds for so long or not dogging the crap out of it every time get in it.I don't see how making someone drive so fast so far to clean the DPF is better than just using the truck around ranch and not really seeing the highway but just when need too...
/ Diesel Programmer's #11
I don't think you can delete with out tuning. It will look like Christmas on your dash and go into limp mode.
Smarty with FLO PRO exhaust is $1300
/ Diesel Programmer's #13
Had good luck with a DP Tuner in a 7.3 PSD.
/ Diesel Programmer's #14
I have a Smarty Jr. on my 2006 Cummins. My truck seems to like it. :)
Kitty cat ran away and I had a Banks muffler installed in place of the factory muffler.
That made it a little loud for my liking, but then I installed an S&B cold air intake and it must have balanced out the flow because the drone's gone now.
There could be truth to that, or it could be all in my head. :laughing:
Travis
Alright so my choices are the EFI LIVE or H&S Mini Max to do full deletes. $2,019 and add $750 for the other,installed. Just won't to do the best one for my truck and not worry with trying to save a few hundred and regret later.
/ Diesel Programmer's #16
I've had my 2004 Cummins for 3 or 4 years now, big there is a big difference between yours and mine. I have no real world experience with it but from following the Cummins boards it seems EFI Live is all the rage. It's really just a series of tunes that can be done in a custom manner for your truck. They usually have a 4 or 5 position switch with tunes for each position such as tow, performance, fuel mileage etc.
With deletes it can get pretty advanced. For example I think your truck has three injection events, they can tune it to run correct on one injection event.
As far as deletes, your warranty is pretty much gone if you do, but at your mileage, that may not be an issue. I also know it's getting harder to do, Edge got fined heavily. I do know they deletes eliminate a lot of the problems and make the trucks more reliable.
One of the weak points of the 5.9 common rail Cummins is the injectors. They can ruin the engine if they go bad and over fuel. The 6.7 has the reputation as having better injectors. With deletes, you will have the best of both worlds. You will have the power and torque of the larger displacement 6.7, but the lack of emission problems that the 5.9 enjoys. Good luck.
/ Diesel Programmer's #17
Jim,
I run a Smarty Jr. in my 2003 Dodge/Cummins Ram 3500. I keep it in performance tune at 100 hp. I can squeeze 2 mpg more out of it..............if I keep my foot out of it. I love it and suppose to change it to 50 hp tow mode for towing, but I don't................and just keep my foot out of it. Manually changing tunes is a pain.
hugs, Brandi
/ Diesel Programmer's #18
I would go with either EFI or a smarty. I've been running a smarty on my 07 but it is a pre emissions truck so it doesn't really apply. My dad has an 08, not deleted, and has had a smarty on it since 10,000 or less miles and he has about 85,000 on it now. I haven't researched it too much but EFI seems like the best way to go as you can do the delete and have custom tunes for exactly what you want. Are you having issues or just want to get rid of the emissions equipment?
DPF issues it wouldn't regen I guess and the filter says at 80% had the horrible smell for like 3days even it just setting there. Anyways been driving it more to try and get it clean but I am only getting 10.8mpg. I could go get it cleaned and be back doing it again,when? Or I just go ahead get rid of the none sense,increase my mpg and pull better. I looked into Smarty at first but they can't do the deletes.
/ Diesel Programmer's #20
When I bought my 2004 K1500 Reg Cab I had a shop use EFILive and I drove while he created a custom program. It took about 30 minutes and consisted of driving at several constant speeds, full throttle acceleration from a full stop and full throttle acceleration several different speeds. If I want to go back to the factory tune, I press the Tow button at the end of the shift lever. As I recall, I paid $400.
Click Here for the people I used (when they were located on the East Coast)
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
