New guy question about unhooking implements.
/ New guy question about unhooking implements. #21
Fluid Film is great stuff and I use it all the time, but it does smell a little funky to me. The little balls inside the female PTO coupler on my Woods RFM didn't want to retract when I pulled back on the collar, which made attaching the PTO to the tractor an exercise in frustration. A couple of applications of Fluid Film on the balls, and rolling them around to make sure they were completed lubricated, did the trick.
So, the end result is that I used Fluid Film on my balls and now they work great but smell funky. :D
I'm seriously considering making the last line my signature line....LOL!
/ New guy question about unhooking implements. #23
DON'T use Grease on the PTO connection?
Learning something new every day.
I'm very thankful for this forum.
Off to google "fluid film".
/ New guy question about unhooking implements. #24
You can now buy Fluid Film at Lowes if you have one nearby.
Steve
/ New guy question about unhooking implements. #25
Thanks, Steve. I visit them regularly.
Have a great week.
/ New guy question about unhooking implements. #26
Have a great week.
You will love Fluid Film... just don't use it on your....ahem.. well you know..:laughing:
/ New guy question about unhooking implements. #27
Careful!! :laughing:
/ New guy question about unhooking implements. #28
that fluid Film is $16 bucks a can up here in Canada at TSC that is outrageous! ...........what price you folks seeing ?
/ New guy question about unhooking implements. #30
My Massey/Kioti dealer has it for $8.50/can
/ New guy question about unhooking implements. #32
You can make your own version of Fluid Film with some pure, unscented liquid lanolin, a spray bottle and 99% isopropyl alcohol.
A solution of 1 part liquid lanolin and 4 to 5 parts parts 99% isopropyl alcohol (4 oz of liquid lanolin to16 - 20 oz of isopropyl) works well. When mixing you may find that the lanolin mixes better if you warm both the alcohol and lanolin in a bath of warm water to about 105 - 110 degrees F before mixing. DO NOT WARM EITHER OF THEM OVER AN OPEN FLAME! Once the solutions are warm, pour together, mix thoroughly, allow the mix to cool (mix occasionally as it cools) and store in an air tight container to prevent water from being absorbed by the isopropyl.
/ New guy question about unhooking implements. #33
$10/can at Lowes.
Good info, I'd always greased my PTO shafts but as others noted they kind of gunk up and get hard to move.
What dept would it be in? I took a quick look around our store and didn't see it.
/ New guy question about unhooking implements. #34
It was located near the tool department in my local Lowes, on shelves also containing PB Blaster, WD 40, etc.
Steve
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
2004 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2004 Harmon Steel...
