Do You Have a Tractor Shed/Barn?
   / Do You Have a Tractor Shed/Barn? #221
Old isn't bad! My tractors are kept in an old carriage barn, that was already coming up on 200 years old, when yours was built.
Dirt floor = damp interior and rust, once enclosed. How do you plan to ventilate, if you're closing in the ends? I understand wanting to keep rain and snow out, but I'd want to ensure substantial airflow, to keep interior dry.
I get that for sure, my current old shed is dirt floor. I'll make it work, part of the fun.
   / Do You Have a Tractor Shed/Barn? #222
I've seen guys post about throwing down a plastic or foam moisture barrier, and then back-filling over that with sand then crushed stone, when building these. I've never tried it myself, seems like there's lots of potential for the barrier to get damaged, but maybe still better than bare earth? Not sure if that's an option, at your present point of construction, or if it's just not worth the hassle at this point.
   / Do You Have a Tractor Shed/Barn? #223
Actually I excavated, laid down heavy vinyl, and built the base with RC6 (recycled concrete). We shall see how it works out.
   / Do You Have a Tractor Shed/Barn? #224
Nice! Definitely post back, if you remember. I'm interested in this for an upcoming project, as well.
   / Do You Have a Tractor Shed/Barn? #225
I will...if I remember but I'll probably brag when the ends are done. The RC6 handles well and sets up quite firm. We'll see how the moisture management works out.
   / Do You Have a Tractor Shed/Barn? #226
60' x 40' x 15' w/ concrete floor. sliding door is 20' x 14' built by Davis County Metal Sales. Ridge skylight.
   / Do You Have a Tractor Shed/Barn? #227
I need this or 2 even better!
   / Do You Have a Tractor Shed/Barn? #228
I'm told by our local code enforcer (in rural Northern PA) that an ag building 36' wide or less does NOT require an architect stamped design blueprint, but it still needs to be code inspected...
Length or height is not a determinant.
Wider than 36' requires a blueprint with a licensed architect signature and stamp. I understand the intent, but it is too much government oversight just to build a pole barn!
It'll be alright.
If condensation becomes a problem in wet or humid weather, you can always add vents.
   / Do You Have a Tractor Shed/Barn? #230
Probably mostly due to liability of collapse due to things like snow and wind load. When I did the expansion and 2nd floor addition on my carriage barn, I actually started with the structural engineer before even going to the township, just assuming this would be the first thing the township would request. I was really surprised how cheap it was, I think the engineering firm only charged me $500 in 2015, for a whole bunch of calculations along with a full set of stamped plans. I suspect I may have supplied them with plans of the existing structure in AutoCAD, which may have saved me a bunch, but it's too long ago to remember now whether that was the case.
I was removing a key structural timber from a timberframe barn, in order to add a second floor within the existing space. The engineers figured out a way to make this possible, namely building up load-bearing interior walls in the gable ends, adding a 30 long LVL ridge beam (the original barn had none), and then adding a pair of posts on piers in the center of each long wall, to carry another pair of LVL's supporting the floor structure. They also calculated the load bearing capability of the old early 18th-century stacked stone footers, based on measurements from my own excavation. Quite a bit of work, and I honestly don't know how they did it all at the price I was charged.
Point is, it may not be as bad as you expect it to be, and they may even offer some ideas you wouldn't consider on your own. In my particular case, the township surprised me, saying they weren't even "going to bother" writing up a permit for the work. The old zoning officer was a bit of a character, I'm sad he's retired since then.
   / Do You Have a Tractor Shed/Barn? #231
My main building is a 32 x 36 Perka building which is an insulated/heated shop with 10 x 10 doors on the north and south ends (drive through). It has a 36 x 48 addition on the south end with two 10 x 20 doors which is unheated dry storage for tractor, mowers, truck, trailers, etc. Secondary storage is an 18 x 24 pole barn for tractor attachments, other storage.
   / Do You Have a Tractor Shed/Barn? #232
This is my 24x36 two story barn in 2010 (built in 2000) then full in 2024 and I have been cleaning out - gave away 2 radial arm saws, sold 60" snowblower, sold the 1864 Cub Cadet Garden tractor.
Was going to put an 8x36 extension on the back but started cleaning out and getting rid of stuff first - then I buy more stuff (mini ex and buckets etc)
In the process of "arranging things" I lose stuff, the idea of pictures as you are rearranging things is great
I can't find things I KNOW are there - somewhere.
   / Do You Have a Tractor Shed/Barn? #233
Started out with a 20x21 carport that we outgrew. A neighbor had a tree land on his during a hurricane, so we took the uncrushed half and added a 12' lean-to to the smaller one. Had a large 26x50 drive through built a few years ago, all working out well, and all out of tree falling distance!
Crushed
I envy you people down south that can have a nice simple shelter like that and not have to worry FEET of snow every winter, LOL
   / Do You Have a Tractor Shed/Barn? #234
I’ve found being able to use a jack very helpful and dirt or gravel is problematic…
Another problem with having a dirt floor....this year for some reason mice have suddenly found my barn and decided my RTV-X1100C cab is a great place to keep making a home.
You can't seal it up like you can with a concrete floor.
   / Do You Have a Tractor Shed/Barn? #235
This is something I have come to appreciate... A concrete floor and rat guards on the walls. The mice stay outside where the cats can get them
   / Do You Have a Tractor Shed/Barn? #238
I have a steel carport for my small tractor. 20×20 is big enough to store my implements.
   / Do You Have a Tractor Shed/Barn? #239
I'm pretty happy to have a 12 x 13 x 20 shelter logic tent to keep the seat dry! Rain, snow, and dew are always present in Maine. I can also leave the chainsaw on the tractor with no fear of rusting out the muffler.
I set it up on 6 x 6's and built a back wall to add weight, and the wall allows for gear and supply storage. It is also set into a pocket in the trees on a gravel base to keep the high winds from moving it.
No permit, no Codes, no Taxes either.
   / Do You Have a Tractor Shed/Barn? #240
That sounds good but my shelter logic, same size, the fabric lasted exactly 19 months before it UV shredded, never again. Building new with metal.
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2016 LEEBOY 8510D ASPHALT PAVER (A60429)
2016 LEEBOY 8510D...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
John Deere 6110M (A60462)
John Deere 6110M...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
