Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,101
KenB2920, why blow off the clippings before making a second lower pass with the flail? The flail will just mulch those clippings if you simply mow over them again. Green fertilizer.
I did this mainly for a couple reasons .... I wanted to see what I was working with and what was bent down with the roller or simply not cut, the customer wanted most clipping removed for purpose of fire (he didn't ask me to remove them, I just figured this would be a perfect spot to test it out), and then I figured after my last cut there would still be plenty of clipping for fertilizer. With the morning dew that were still getting here and a couple days of new growth that area Is going to look fabulous for his gathering.
/ Let's talk flail mowers #2,102
Well, my second set of belts (Gates Kevlar B43 singlesx3) just died after five years. They lasted about three times as long as the Caroni supplied non Gates originals. No complaints. Just ordered three more off Amazon.
In the meantime I mounted a set of Pix Kevlar belts I got a couple years ago from someone who sold their tractor and mower. Made in India. Not sure yet if I will bother switching to the Gates belts when they arrive and keep the Pix as spares or just see how the Pix do. Takes about half an hour to install a new set and the Pix belts worked fine yesterday so I'll probably just leave them on.
/ Let's talk flail mowers #2,103
Thanks for the part # Island, I'll be going to amazon today to order a set for spares.
/ Let's talk flail mowers #2,104
That looks pretty darn good. I noticed you are using a Motts and was wondering what you think of it. Been looking at Motts/Alamo flails and wanted some opinions on their overall ability and quality. Seems you can find some good deals on older ones from time to time. What size mower are you pulling with your Kubota?
Thanks
/ Let's talk flail mowers #2,105
Thanks
/ Let's talk flail mowers #2,106
That looks pretty darn good. I noticed you are using a Motts and was wondering what you think of it. Been looking at Motts/Alamo flails and wanted some opinions on their overall ability and quality. Seems you can find some good deals on older ones from time to time. What size mower are you pulling with your Kubota? Thanks
Yes, I'm not sure the model but it is a mott. I purchased a package deal with a motts and ford.
I replaced the knives on the ford and it does to a good job cutting short. The ford has 33 knives.
Now the mott is smaller and seems daintier but in all reality it cuts great! All the blades are dull and it still does an amazing job.
Both are 6' and I run them on my L3540. I just bought a L5240 but it hasn't arrived yet. I assume when I find a deal I will step up to a larger size. As for being a beginner with the flail mowers I am definitely a convert from the brush hog. They do a much much better job but you do go much slower.
My mott seems old and rusted but I tell yA, knock on wood it's great!
The ford I wish had a idler pully spring but it's a fixed tension pully. I managed to burn it's belt up and have yet to replace it.
/ Let's talk flail mowers #2,107
If anyone is looking for a flail mower I'm looking to get rid of mine since I'm getting rid of the tractor. Its a Ford 917 that looks rough but cuts good. All new blades and hardware last season and some extras to go with. . I'm located in N AL. Message me for more details.
/ Let's talk flail mowers #2,108
I finally got me a flail. I found a 6 foot John Deere that needs new bearings, at least I assume that's what the deal is. The shaft and the roller won't turn. I got it for 200, can't wait to get it up and running. Looking forward to joining the crowd
/ Let's talk flail mowers #2,109
Just incase anyone was like me in wondering if a 60" flail would cut good with around 23 pto hp *I ride a Mahindra 2816 geared with a Rhino RF60 flail behind* it is more than enough. We have had more rain here in the great state of Oklahoma already this yr than we usually get in a full yr so the field I use it on was about 2'-3.5' tall and a mix of bermuda/johnson grass . It mulched it up just fine running in 3 gear/medium range at about 3" high. Which medium 3rd is PLENTY fast!! I think I could've gotten away with a 72" flail but didnt want to push my luck too fast. 😝 In the morning I'm tackling some 5-6' tall johnson grass just to see how it cuts! Super glad to have it!
/ Let's talk flail mowers #2,110
Just incase anyone was like me in wondering if a 60" flail would cut good with around 23 pto hp *I ride a Mahindra 2816 geared with a Rhino RF60 flail behind* it is more than enough. We have had more rain here in the great state of Oklahoma already this yr than we usually get in a full yr so the field I use it on was about 2'-3.5' tall and a mix of bermuda/johnson grass . It mulched it up just fine running in 3 gear/medium range at about 3" high. Which medium 3rd is PLENTY fast!! I think I could've gotten away with a 72" flail but didnt want to push my luck too fast. �� In the morning I'm tackling some 5-6' tall johnson grass just to see how it cuts! Super glad to have it!
Before and after pics would be nice:thumbsup:
/ Let's talk flail mowers #2,113
Outstanding, is that one pass?
/ Let's talk flail mowers #2,114
Yep. I was in 1st gear medium range. It didnt bog down a bit but I havent bushhoged there too much and was afraid of finding a hidden surprise.
/ Let's talk flail mowers #2,115
Question for you flail mower owners.
I have 2 ac of tall grass / weeds that has a some rocks in it. Can I just raise the 3 pt hitch about 8 in off the ground to avoid the rocks and still cut the grass / weeds with a flail mower ?
/ Let's talk flail mowers #2,116
I raise mine to mow over rocks/stumps/logs. But if you keep it raised all the time it's not going to do a good job of following the contours of the ground and you'll mow very high when the front tires drop into a valley or much lower (and possibly hit one of those rocks) when the front tires climb a bit of a hill.
/ Let's talk flail mowers #2,117
Sure, it will cut grass and weeds like that just fine. It won't leave a polished look, but it's probably better than hitting the rocks.
/ Let's talk flail mowers #2,118
X2. Exactly
/ Let's talk flail mowers #2,119
I did this field yesterday. I was a little disappointed with the efficiency. I get my new/used tractor this week and will be able to tell if HP will make a difference at all or not. This for me at least will be the perfect control / variable as I will be using the exact piece of equipment (mott flail) with almost same tractor just more power. So im curious if the tractor will make the mower eat the grass better or if the mower is already maxed out.
/ Let's talk flail mowers #2,120
Is your current tractor bogging down? If not it won't make a bit of difference me thinks.
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2017 TAKEUCHI TB290 EXCAVATOR (A64279)
2017 TAKEUCHI...
