blueridger
Hey, Fellers,
Couple things about the 3038e I just bought.
First, the photo shows the concrete ballast block I fabbed up. It turned out nice, but it's too heavy. I got the AF11 hydraulic-angled front blade for pushing snow. I believe the blade's 780# and it projects a ways beyond the loader frame, so I wanted to unload the front axle some and have more rear weight than just filled tires. (If I'm reading it right, the manual says that with a loader, the minimum rear weight is filled tires plus 380# hitch weight.) Anyway, the block measures 6 cu. ft., so figuring 144# per cu. ft. it's almost 900#. The rear hitch is rated at 1300# @ 24" behind the lift points so I thought it'd be OK. Turns out the rear hitch will barely lift the block at rated rpm. Plus it just feels too heavy. Ya know, when I was building the form, I thought about reducing the size to 4.5 cu. ft., but noooo. And, with the cost of a shop welding up the 2" receiver assembly and reinforcing steel that runs through the block, I didn't really save much over the cost of the JD BW15073 ballast box, which is what I'm going to do now. Hope this info helps someone avoid the same mistake.
Also got the forward work light kit which the dealer mounted halfway up the ROPS uprights. I thought about moving the lights to the forward edge of the canopy which looks like a much better position for them. Anyone done something like that?
Finally, I can't find a tool box add-on for the 3038e. Am I missing something there?
TIA....
TIA....
