Widen Them Wheels
/ Widen Them Wheels #1
keg99
Member
St. Louis, MO
New Holland TC40DA
Call me a fool. I had my TC40 New Holland for almost ten years and FINALLY got around to widening the back wheels. What was I thinking. Years of living with a pucker factor every time is hit a slight slope. Made the whole experience, let's say, less than optimum?
I know, the wheels/tires are fluid filled. They are heavy. And I wasn't really sure I could handle them. But I did. And although it was a challenge, the end result was so worth it. Get a friend to help.
I suspect many others accept the wheel width as set by the factory. FORGET IT. That is just to ship them. Takes up less space.
A tractor needs to wide and needs to be sure footed. Factory settings suck. Wide is where it is at.
So, yes, I was a fool. But no more. I widened the wheels by flipping the inner dish. And I can now tackle that back field and don't have to worry about flipping it over.
Yes, I still need to careful. But to have waited so long. Sheesh.
So to all who haven't widened their wheels and are still living with those factory settings . . . stop it! Widen them out and begin to really enjoy your great tractor. It made me a believer.
But I'll reserve whether I'm still an idiot, because waiting almost 10 years doesn't make me look very smart!
Do it!
/ Widen Them Wheels #2
I encourage friends to do the same, but some have tight spacing to work around. Wider feels better and is safer for slopes. Application may limit some from doing it--or fear or handling a huge massive object without a tractor available to get it picked up if it tips.
/ Widen Them Wheels #3
An engine hoist would be a wonderful helping hand if you don't have a buddy.
/ Widen Them Wheels #4
I spent $150 having my rear tires widen to their widest point several years. A little thought beforehand would have led me to conclude that that $150 could have been spent on a engine hoist for about the same $ and I'd still have the hoist today.......
Oh well, live and learn.
/ Widen Them Wheels #5
I hear that the wheels should be within the width of the bucket. ... I see the reasoning, but dont go by it. In almost every case I find everything is gained and nothing lost by widening at the rear while keeping the fronts w/i the bucket width. I sometimes go with an even narrower bucket and get by fine with the fronts sticking out a little.
/ Widen Them Wheels #6
The only major down side I could see to the wheels being wider than the bucket would be if you are digging or pushing snow. Also, it's a good indicator if the tractor will fit somewhere if the bucket fits.
/ Widen Them Wheels #7
Just wondering, does widening out the rears affect the 4wd function at all? Pardon my ignorance.
/ Widen Them Wheels #8
It's not about 4WD traction, its all about stability. Wider stance = more stability going across hills.
/ Widen Them Wheels #9
OK, Thanks. I have read about not driving on pavement with 4wd engaged. I just want to be sure that modifying the wheel stance won't screw something up. Something I am already an "expert" at doing without really trying too hard. :rolleyes:
/ Widen Them Wheels #10
Do it!
Sometimes a tractor needs to fit between the rows. Set the track width to the need.
It's not that hard.
/ Widen Them Wheels #11
It's not that hard.
I agee... I had the dealer set my wheels as wide as possible and fluid fill all of them before I picked it up. Still wasnt wide enough so I made spacers to gain another 4.5" per side. Sidehill work feels much safer now.
/ Widen Them Wheels #12
/ Widen Them Wheels #14
When you widen the rears, is it necessary to widen the fronts? I have loaded tires but need extra stability on slopes
There's no point in widening the front since the front axle pivots. I've widened my rear tires to the max since I use my L4330 on my hill, but I haven't done anything to the front tires/axle except fill the front tires with water/RV antifreeze mixture.
/ Widen Them Wheels #15
My fronts are widened as far as they go, which isn't as wide as the rears, but it sets their track close to the rears. Makes it easier to judge the right path when mowing, but not a lot of other value. Doesn't help with stability until you tip far enough that the front axle hits the stops, by which point it's likely too late to stop a turnover.
Terry
/ Widen Them Wheels #16
Was thinking of making up my own set of spacers out of 4140. What is a good practical spacer width?
/ Widen Them Wheels #17
Changing the diameter of the front or rear wheels would screw up the 4wd, but widening them makes no difference.
/ Widen Them Wheels #18
Widening is much more stable. On my 4440 it has duals and the rear is ten feet wide and the front is probably eight. It is as stable as can be. On my backhoe I keep them the same width as the bucket. It gets a little scary at times but I like knowing if my bucket fits my tractor will also. We are currently digging a pond and we make cuts across it the width of a bucket maybe 2-3 feet deep at a time. If the tires were wider than the bucket it wouldn't work.
You also have to think about implements. My 7' shredder was about useless with my 4440 because the tractor was ten foot wide and I couldn't get close enough to fences. Same thing with plows or blades they need to be wider than your implements.
/ Widen Them Wheels #19
Mine are set to the max and I like it. Well until it's trailer time.
1995 Freightliner FL70 S/A Dump Truck (A64556)
1995 Freightliner...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2023 KENWORTH T680...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2017 Ford Expedition SUV (A64557)
2017 Ford...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
