   / Your last generator Maintenance Run #461
One last update on the Champion 7K dual fuel. After 5 more hours runtime (fast moving thunderstorms knocked out our power again...) I dumped the oil for a second change - no sparkles - no particulates, oil looks pretty much the same as when filled (maybe darker?).
Also, I cranked up the old Phillips scope & took a look at the waveform unloaded vs loaded (used a step down transformer between line voltage & scope)
First - mains power waveform:
Champion waveform, unloaded:
Champion waveform, 12A load on each leg:
Looks pretty good to me...
Hopefully subsequent posts will stay better on target :)
Nick
Looking good on those waveforms Nick.
In the right hands, a 'scope is a useful diagnostic tool, so I find that right at home in a Maintenance thread..... besides, even when I'm OP, I usually don't mind some drift.....
Sounds like you are all set for another 15+ years :thumbsup:
Edit: (Scope newbies - take note of Nick's comment about using a transformer).
Rgds, D.
   / Your last generator Maintenance Run #463
Cranked up my JD Subaru powered AC-G8010S-E genny . It has electric start but battery dead on it . Haven't replaced it , cause one ,two yanks on recoil cord and thing always fires rite up . Ran it for about an hour , ran a small amount of Sea Foam through it . Then closed fuel petcock and ran dry and drained fuel . I have less than 5 hours on this unit. https://www.deere.com/en_US/product...rcial/large_frame_8000/large_frame_8000.page?
The 404 cc Subaru motor appears to be a winner (so far). Like I have said before only negatives I see/hear are unit is kinda noisy IMO compaired to like a Honda motor and no oil filter on 404 cc Subaru.
Bought it cause I got a good deal on it , it came with wheel kit and handles . I have yet to run into someone that has one of these , but I know these units are out there . I really like it so far .
If anybody has had any hands on experience with the 404 CC Subaru , sure would like to hear your opinion/ETC on them .
With the parent company being Fuji, there's a lot of mechanical engineering depth there.
What surprised me a bit is the engine division is privately held, according to Wikipedia:
https://en.wikipedia.org/wiki/Subaru_Industrial_Power_Products
That article has me wondering about a connection to Wisconsin (company that is).
Sorry, I have no direct experience with that engine BB, but given it's lineage I anticipate good performance from it..... that, and I'd expect that JD did a thorough engineering review when selecting that engine.
Rgds, D.
   / Your last generator Maintenance Run #466
Nick
You don't have a probe that can connect to 240V?
   / Your last generator Maintenance Run #467
If you put a large switching supply load on it, you should see that waveform start to get ugly.
   / Your last generator Maintenance Run #468
Rgds, D.
Dave
Thanks for info !!!
Dave
Thanks for info !!!
You're welcome. I'd seen a few Subaru small engines advertised on products up here, but didn't know much about them so was interested in doing a bit of reading myself.
Rgds, D.
   / Your last generator Maintenance Run #470
I think it went, Wisconsin, then Wisconsin- Robin, then Robin-Subaru and now I see them just called Subaru's...
DM
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A60460)
2019 John Deere...
2004 John Deere 4720 (A60462)
2004 John Deere...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
iDrive TDS-2010H...
