   / Your last generator Maintenance Run #461
One last update on the Champion 7K dual fuel. After 5 more hours runtime (fast moving thunderstorms knocked out our power again...) I dumped the oil for a second change - no sparkles - no particulates, oil looks pretty much the same as when filled (maybe darker?).
Also, I cranked up the old Phillips scope & took a look at the waveform unloaded vs loaded (used a step down transformer between line voltage & scope)
First - mains power waveform:
Champion waveform, unloaded:
Champion waveform, 12A load on each leg:
Looks pretty good to me...
Hopefully subsequent posts will stay better on target :)
Nick
Looking good on those waveforms Nick.
In the right hands, a 'scope is a useful diagnostic tool, so I find that right at home in a Maintenance thread..... besides, even when I'm OP, I usually don't mind some drift.....
Sounds like you are all set for another 15+ years :thumbsup:
Edit: (Scope newbies - take note of Nick's comment about using a transformer).
Rgds, D.
   / Your last generator Maintenance Run #463
Cranked up my JD Subaru powered AC-G8010S-E genny . It has electric start but battery dead on it . Haven't replaced it , cause one ,two yanks on recoil cord and thing always fires rite up . Ran it for about an hour , ran a small amount of Sea Foam through it . Then closed fuel petcock and ran dry and drained fuel . I have less than 5 hours on this unit. https://www.deere.com/en_US/product...rcial/large_frame_8000/large_frame_8000.page?
The 404 cc Subaru motor appears to be a winner (so far). Like I have said before only negatives I see/hear are unit is kinda noisy IMO compaired to like a Honda motor and no oil filter on 404 cc Subaru.
Bought it cause I got a good deal on it , it came with wheel kit and handles . I have yet to run into someone that has one of these , but I know these units are out there . I really like it so far .
If anybody has had any hands on experience with the 404 CC Subaru , sure would like to hear your opinion/ETC on them .
With the parent company being Fuji, there's a lot of mechanical engineering depth there.
What surprised me a bit is the engine division is privately held, according to Wikipedia:
https://en.wikipedia.org/wiki/Subaru_Industrial_Power_Products
That article has me wondering about a connection to Wisconsin (company that is).
Sorry, I have no direct experience with that engine BB, but given it's lineage I anticipate good performance from it..... that, and I'd expect that JD did a thorough engineering review when selecting that engine.
Rgds, D.
   / Your last generator Maintenance Run #466
Nick
You don't have a probe that can connect to 240V?
   / Your last generator Maintenance Run #467
If you put a large switching supply load on it, you should see that waveform start to get ugly.
   / Your last generator Maintenance Run #468
Rgds, D.
Dave
Thanks for info !!!
Dave
Thanks for info !!!
You're welcome. I'd seen a few Subaru small engines advertised on products up here, but didn't know much about them so was interested in doing a bit of reading myself.
Rgds, D.
   / Your last generator Maintenance Run #470
I think it went, Wisconsin, then Wisconsin- Robin, then Robin-Subaru and now I see them just called Subaru's...
DM
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
