Your last generator Maintenance Run
/ Your last generator Maintenance Run
90 - I suspect what you are pondering is what looks to be Hour ratings, under different test Classes.
Bigger stuff ^ than the caps I used to work with (down into the detail-weeds @ times), so I don't know those Classes.
No promises, as it is the Holidaze @ moment, but I'll ping a retired buddy of mine, as there is a decent chance he is familiar with those Classes.....
Rgds, D.
P.S. Ducati ! I'm so used to seeing red !
90 - got an email back today, from my Power Electronics buddy..... (Thanks GC !).
"As far as I know, the "Classes" listed refer to the lifetime rating, lifetime ratings also happen to be listed on the capacitor (redundant info). Good info for an electric motor run capacitor.
Assuming that is a "run" capacitor, as the low cap. value suggests, lifetime would be critical as the cap is always passing current, generating heat and internal gas pressure - i.e. wearing out.
A start capacitor is usually a higher uF value."
Rgds, D.
/ Your last generator Maintenance Run #7,903
Brushless generators use capacitors for voltage regulation. All you need to do is match the uf and voltage class rating….. I’ve even used slightly different uf rated capacitors when exact replacements can’t be found, and they work fine…maybe a volt or 2 more output.
Does increasing the uf increase or decrease voltage output?
Good info 👍
90cummins
/ Your last generator Maintenance Run #7,904
Increases voltage a bit as you increase uf, but that was when I only increased one from 78uf to 80uf. Not sure how healthy for gen though
/ Your last generator Maintenance Run #7,905
Don't change the cap value too much, it goes on an inductive load.
/ Your last generator Maintenance Run #7,906
Agree, but they stopped making the 78uf required one for the generac 10kw brushless. I went with a 80uf out of necessity, and it worked out ok. Figured they have a 5% +/- rating anyways.
/ Your last generator Maintenance Run #7,908
Hi Daugen,
I just installed one very similar that only 8KW 161 hours, a 2018 model, though but it was free! My neighbor, a contractor, was remodeling a house, new owners wanted "everything" connected so pulled it out. I did wire it for 75 amps if we decide to replace it in the future,
We installed a new ATS, and bigger LP tank, and did the trenching, electrician and gas co did the connections - all in $6K (with a $1K new tank). Runs great and clean power.
Up here, these units go for $1-2K barely used. I guess people want to add the AC, or enlarge their system. Seems like a waste of $ but I was happy to get a whole house unit,
/ Your last generator Maintenance Run #7,909
/ Your last generator Maintenance Run #7,911
That’s a good price…. But I would also wonder why it was pulled. Maybe too small for their house
thanks
I'd want a guaranty of decent operating condition if bought from a company
I have a 900 sf cottage with one small hvac
probably the right size
I run it all on 9kw now with the hot water heater turned off but it struggles at times
I think with the "reasonably" priced models up to 24kw now, going up from 17 to 24
might have been what someone needed with multiple hvacs. Or a new hot tub.
/ Your last generator Maintenance Run #7,914
Understood, @ Load.
Perhaps also a large enough pail to sit a 30#'er into hot-water for the short test ?
Rgds, D.
That's a standard work around for blacksmiths on gas forges. They freeze up due to rapid use too. As long as it's warm not boiling your fine. Some use a torch or heater, but that's pretty dangerous. If it's just a short test like 5-10 minutes you probably won't need to bother with anything
Makes sense (not the torches etc....) . Increase in tank area (@ Cold Ambient) is one reason for dual-manifold tank setups, ie. on RVs, and IIRC, somebody built one on here for their small gen.
I understand some of the general thermodynamics, and have seen my HVAC buddy do same (water/pail) with refrigerant.
d seems to have found a good deal, and may have been working fine when pulled, but nothing beats actual operation and check of fundamentals....
Rgds, D.
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2010 Ford F-150 Crew Cab Pickup Truck (A59230)
2010 Ford F-150...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
light tower (A60352)
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
