scavenger pump relay HELP
/ scavenger pump relay HELP #1
dal929
Approximately 75hrs on the machine and the relay seems to have gone south again. The machine beeps 5 minutes into running. I ordered and have the new relay but have NO CLUE where it is to replace it!! I've been told that it was under the floor plate in front of the driver seat but when I open that I don't see it under there. Any help would be greatly appreciated as it's driving me crazy!
Thanks
Daltro
I found it!! It's under the console on the wall. I swapped out the unit and unfortunately I still get an annoying beep after 5 min. All fluid levels are good, machine runs fine. I guess it's going to the dealer for a checkup. So far Mahindra 8560 has been CRAP!! So far it's been throttle position sensor, Scavenger pump relay, sometimes it won't start unless you wiggle the wiring harness by the starter, no visibly loose wires, and now this mystery issue, all under 100hrs. I should have bought a Kubota.
/ scavenger pump relay HELP #3
The senting unit for the transmission lube system is most likely the problem. It's under the platform .
/ scavenger pump relay HELP #4
replace starter relay or be sure its not loose...
/ scavenger pump relay HELP #5
What OldGin said there is an oil pressure switch( sending unit ) for the transmission charge pump. If it reads low oil pressue it will cause a beeping after several minutes of run time. It located on the right side of the tractor ahead of the rear wheel above the battery in the transmission case if i remember correctly.
The switch is probably bad but you should check the oil pressure with gauge to be sure.
/ scavenger pump relay HELP #6
:thumbsup:
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
