Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread....
(I see they haven't figured out the double post problem)
/ Grappling fun - A Picture Thread.... #305
I finally decided on the EA wicked grapple and really happy I did!
It's about 275 lbs. with the slats in. I use about 400 lbs of ballast with it.
It will be an awesome retaking wall I'm sure.
I tried using older logs for the timbers. I did use 2 trees that I recently cut down but those had to go anyways. I am using all white oak for posts and pine for the wall. I'm hoping to get 10 years out of the pine but not so sure.
This is an older log that was sitting in the woods, the sap wood was in bad shape but all the heartwood was really nice.
I couldn't lift the log without any weight on the back, so had to go put something on the back to get this one out of the woods.
/ Grappling fun - A Picture Thread.... #307
Man o man do I regret selling that "counter weight":eek:
Matt
/ Grappling fun - A Picture Thread.... #308
I lifted my boat lift off of my flatbed trailer with my grapple.
430792d1435110138-grappling-fun-picture-thread-image-1132364618-jpg
/ Grappling fun - A Picture Thread.... #311
Why is your hood up??
I was having trouble starting my tractor because the brake switch wasn't triggering because one side of the brake linkage was binding from rolling a stump under the chassis which banged up my belly armor up against the right side brake linkage. In the cab, the problem was acting like the battery wasn't up to speed and so I checked my battery disconnect as the very beginning of puzzling out the problem.
/ Grappling fun - A Picture Thread.... #312
Mother Nature has many devious revenge strategies.
/ Grappling fun - A Picture Thread.... #313
You should do durability testing for Kioti. Have you counted the number of things you have broken?! Good for you, tractors are made to be used not coddled.
/ Grappling fun - A Picture Thread.... #314
I'd love to do something like that but in this instance the linkage bound against an underbelly plate I installed. When a stump along lakeshore I'm clearing rolled under the tractor. Without the plate the linkages, wiring, and hydraulic hoses are all exposed on that side.
What I've learned from using the belly armor is that my basic belly armor with high ground clearance is a good design, but I should make a new set out of thicker, stronger material and add a couple of stand offs.
My armor has taken multiple hits and is pretty banged up now. But the armor has done its job and nothing it has protected has been damaged.
/ Grappling fun - A Picture Thread.... #315
How thick is that sheet?
I've been planning on 1/8" for my up-armoring where wires and hoses are. I've already had one harness ripped out from an errant stick that popped up as I drove over it while looking the other way.
/ Grappling fun - A Picture Thread.... #316
Given a 6000 lb tractor plus momentum, it's hard to imagine that any belly armor less than 3/8" would not deflect and potentially crush or squeeze something beneath it if the tractor rides up on a stump or rock. I'm thinking that Eric's armor does a good jib protecting against broken brush and smaller/medium sized branches but asking belly armor to have near zero deflection when the tractor gets hung up on a stump is a bit extreme. Live and learn. If I were Eric I'd leave the current belly armor in place and just avoid traveling over stumps. It's also a good reason to uproot trees rather than chainsaw them (or chainsaw very close to the ground).
/ Grappling fun - A Picture Thread.... #317
Smaller tractors, and those with cabs tend to have less ground clearance. I've driven clear over 12" logs on the ground. I'm only concerned with snagged brush and protecting the brake lines, wiring, and hydraulic lines under the drivers platform on my machine - well above the bottom of the rear axle.
My MFWD axle protective tube might get upgraded to something stronger than the plastic it currently is, and that's the lowest part of the belly other than the axles themselves.
I don't leave tall stumps. It's just more to remove later, and wood that's left out of the first log (wasted money). Just about anything under 5" is getting pushed over if I need to drive around it now that I have the root grapple. It's faster than cutting them.
/ Grappling fun - A Picture Thread.... #318
I haven't felled a tree less than 10-12" diameter that I could reach with the tractor in years. Smaller trees get the root grapple treatment while the larger ones are toppled with help from my BH and ripper.
I hate digging out stumps. Much easier to uproot the whole tree. Faster. Less of a divot. I also get to choose where the tree falls more accurately by pushing. I'm sure experienced lumberjacks can drop trees safely too but I feel safer pushing than chainsawing.
/ Grappling fun - A Picture Thread.... #319
My wee, little, cab tractor that only has 15.7 inches of ground clearance tore a cat IV driveshaft in half today.
Smile.
Jim, I made my plates out of 16g. So 0.0625. You should be good with 0.125.
/ Grappling fun - A Picture Thread.... #320
You've got a lot of crap hanging down at that 15.7" mark though. The steps are actually the lowest thing between the tires on mine. ;)
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2003 KAUFMAN 29' GOOSENECK TRAILER (A63290)
2003 KAUFMAN 29'...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
1998 MACK CH613 WINCH TRUCK (A63569)
1998 MACK CH613...
John Deere 4710 Self Propelled Sprayer (A64047)
John Deere 4710...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
