John Deere 4100 Brakes Locked?
/ John Deere 4100 Brakes Locked? #1
pastorjeep
Eure, NC
John Deere 4100
I have just purchased a 4100 from a estate sale and know nothing about it. The engine starts quickly and runs smoothly while the hydraulic lift works well but doesn't hold in the up position long. The problem is that the brakes seem to be sticking. When put in gear you can feel the strain when taking off and if you push in the clutch the tractor stops immediately as if you pushed the brake. The pedal seems to be all the way up and the parking brake seems fully disengaged. any help would be great?
/ John Deere 4100 Brakes Locked? #2
check where the brake rod arms enter the cast housing, they may be corroded/rusted and stuck in the depressed position
Thanks for the suggestion, I will check in the morning. Are the rear brakes internal?
/ John Deere 4100 Brakes Locked? #4
yes they are, you have what are known as "wet disc brakes" if you follow the brake rods down each side of the housing, you will see where they hook to a lever going back into the front of the side axle housings. If you shoot me your email, I will send you a PDF of the deere tech manual for the 4100
Joe
Thanks Joe, you got me looking and I just found the PDF, and a Deere manual on fluid changes. I wonder if low trans fluid can cause a sticking brake condition? Do you have a recommended trans fluid that is equivalent to John Deere Low Viscosity HY-GARD (JDM J20D)?
Eric
/ John Deere 4100 Brakes Locked? #6
Doubt low fluid would make them stick, I'd still bet on a stuck rod, or even a broken spring
if yours is a hydro, I'd stick with deere fluid.
I think mine is a gear drive? On the left is a shifter that has reverse forward lo-hi, and another shifter with 4 speeds 1-4?
/ John Deere 4100 Brakes Locked? #9
From viewing parts catalog brakes on 4100 appear to be mechanical operated. My vote is sticking operating linkage. Have you lubricated grease fitting(parts key 15)?
Thanks Tex, I will hopefully get time this weekend to start servicing this tractor. Fresh fluids, filters and fixing some lights and wiring are in order. I read about "friction modifier " that may help these wet clutches. I am definitely going to go thru the linkage as well.
/ John Deere 4100 Brakes Locked? #11
The operating shafts (one on each side) are steel going thru an aluminium housing. The aluminium builds up a bit of corrosion and the external spring will not rotate the shaft back to the off position.
Once a year I put a helper in the seat, crawl under with a hammer and spray lube. The helper pushes the pedal, I spray and tap the spring holder so it rotates back off. Push the pedal again and rotate the shaft while spraying. When one side is free, switch to the other side.
Poor design but like emergency brakes on a pickup, you either use them all the time of they will seize up.... My tractor is hydrostat so I seldom use the brakes. Then I need them to park on an incline and they don't release, or lock the brakes while its on a flatbed and have to free them up before I unload...
/ John Deere 4100 Brakes Locked? #12
This parts diagram shows the internal brake view and the linkage shaft
and with the first diagram supplied by Tx Jim you can see the entire setup from pedal to friction disc
/ John Deere 4100 Brakes Locked? #13
Item #1 is the steel shaft that goes thru the cast aluminium housing. My return spring hooks onto it...
/ John Deere 4100 Brakes Locked? #14
Similar to the Cararo brakes . The thru-shaft seized up in in the boxhousing. You will have to remove the outer brakepedal and the inner brakepedal ....then move the shaft to the left of the tractor and clean it with emarytape and rebuild all .
/ John Deere 4100 Brakes Locked? #15
Thanks guys! Mine has a cast iron housing not aluminum, seems the gear drives were steel?
/ John Deere 4100 Brakes Locked? #17
Put a magnet on them where the shaft goes thru. I believe the 4300 and 4100 have the same housings....They look like steel but....
/ John Deere 4100 Brakes Locked? #18
OK. I've got a gear driven 4100 also, and need to replace the brakes. Looking at $1200 if the shop does it. Is this something I can handle if reasonably mechanically inclined?
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
(4) ST235/80R16 Tire (A65640)
(4) ST235/80R16...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
