John Deere 4100 Brakes Locked?
   / John Deere 4100 Brakes Locked? #1
pastorjeep
Eure, NC
John Deere 4100
I have just purchased a 4100 from a estate sale and know nothing about it. The engine starts quickly and runs smoothly while the hydraulic lift works well but doesn't hold in the up position long. The problem is that the brakes seem to be sticking. When put in gear you can feel the strain when taking off and if you push in the clutch the tractor stops immediately as if you pushed the brake. The pedal seems to be all the way up and the parking brake seems fully disengaged. any help would be great?
   / John Deere 4100 Brakes Locked? #2
check where the brake rod arms enter the cast housing, they may be corroded/rusted and stuck in the depressed position
Thanks for the suggestion, I will check in the morning. Are the rear brakes internal?
   / John Deere 4100 Brakes Locked? #4
yes they are, you have what are known as "wet disc brakes" if you follow the brake rods down each side of the housing, you will see where they hook to a lever going back into the front of the side axle housings. If you shoot me your email, I will send you a PDF of the deere tech manual for the 4100
Joe
Thanks Joe, you got me looking and I just found the PDF, and a Deere manual on fluid changes. I wonder if low trans fluid can cause a sticking brake condition? Do you have a recommended trans fluid that is equivalent to John Deere Low Viscosity HY-GARD (JDM J20D)?
Eric
   / John Deere 4100 Brakes Locked? #6
Doubt low fluid would make them stick, I'd still bet on a stuck rod, or even a broken spring
if yours is a hydro, I'd stick with deere fluid.
I think mine is a gear drive? On the left is a shifter that has reverse forward lo-hi, and another shifter with 4 speeds 1-4?
   / John Deere 4100 Brakes Locked? #9
From viewing parts catalog brakes on 4100 appear to be mechanical operated. My vote is sticking operating linkage. Have you lubricated grease fitting(parts key 15)?
Thanks Tex, I will hopefully get time this weekend to start servicing this tractor. Fresh fluids, filters and fixing some lights and wiring are in order. I read about "friction modifier " that may help these wet clutches. I am definitely going to go thru the linkage as well.
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
