Front wheel bearings failed L5740
/ Front wheel bearings failed L5740
Well, I got it back together today by myself. I only changed the 2 bearings and the seal on this side. It seems that I caught it before as much damage as the other side. I was able to pick up one bearing and the seal from a local Kubota dealer, and the other bearing I found at a shop that specializes in bearings.
It looks like the outer bearing just broke into pieces instead of slowly wearing out. The balls didn't seem to have much wear or damage on them. The other side had so much damage, it was hard to tell what had happened.
/ Front wheel bearings failed L5740 #42
I wonder if the original owner was one of the tractor owners that thinks the 50 hr service is not important and refused to change all the fluid out. I've changed all my new tractors at 50 hrs. On every one the front axle fluid was very nasty and the catch pan would sparkle like metal flake paint.
As long as there was oil in there the failure had nothing to do with service. Little sparkles in the drain oil are mostly particles that have settled out. These very fine particles do not affect a lo speed rolling bearing critically in the short term - if at all. ... And these are nearly new failures. The Kub Ls are demonstrating a weakness in the front bearings. Like as not the metal particles seen at 50Hr are a harbinger of the early stage of bearing failure.
/ Front wheel bearings failed L5740 #43
50 hr does not include the front axle fluid, as far as I recall. But that reminds me I need to at least check it now at 120... Oops!
/ Front wheel bearings failed L5740 #44
Did you guys feel anything in the steering or from the tractor before hand? I'm feeling something, like maybe like loose lug bolts or the bumps when in 4WD on hard surface turning sharp. The bumps are coming from the front and on hard surface the rear wheels do the skipping, I can feel it in the steering. The feeling like loose lug bolts I can't tell where it is coming from.
I checked the front wheels to see if I could feel any thing loose, but seemed ok. Another thing it comes and goes. I can also feel it when sidehilling. This is on my L4240 with over 1200 hrs.
I didn't feel or notice anything until the oil started pouring out. At that point, I could feel it. In fact when the first side failed, I raised the 'good' side to see if I could shake the wheel and it was tight.
When the second side failed, I raised the wheel and it was still tight.
If you are feeling something, I suggest you take it apart and visually inspect the bearings.
/ Front wheel bearings failed L5740 #46
Actually, on slightly older Kubotas not only was the front axle part of the 50hr service but it called for a complete fluid and filter change. None of this filter, top off and go stuff like they do today. I've bought 3 new Kubotas and all were change at or before the 50 hr mark. After the seeing what came out of them I would never run one longer than that without a full service.
This is just my opinion of course but to me the 50 hr service is the most important one of the tractors life.
/ Front wheel bearings failed L5740 #47
Apparently they know of the problem with the front wheel bearings.
/ Front wheel bearings failed L5740 #48
It looks like most are being fixed out of warranty so they might not know.
Are you guy using OEM bearings and if so are the #'s and mfg the same? BTW who is the mfg of the old bearings? I'm going to check mine asap but think I well change mfg if I can. I like what Grateful11 had to say about the FAG bearings, might try and find them. My oil was changed at the 50 hr mark, it could be that the 50hrs oil change is already to late for the bearing.
/ Front wheel bearings failed L5740 #49
I did a seach on fag bearing 6209c3 and came up with this. Does the load rating seem low for the work it is doing? Seems low to me with the bucket sticking out there 5 miles. I'm wondering if this came about when they started useing the cruved boom.
Specifications for this item
Brand Name
FAG Bearings
Part Number
6209-C3
Material Type
Steel
Bore Diameter
45 mm
Outside Diameter
85 mm
Overall Width
19 mm
Max Rotational Speed
9000 RPM
Static Load Capacity
7460 pounds
Dynamic Load Capacity
4860 pounds
EAN
4012801071147
Number of Items
1
UNSPSC Code
31171504
I guess it would help if I posted what I found.
/ Front wheel bearings failed L5740 #50
Did you guys feel anything in the steering or from the tractor before hand? I'm feeling something, like maybe like loose lug bolts or the bumps when in 4WD on hard surface turning sharp. The bumps are coming from the front and on hard surface the rear wheels do the skipping, I can feel it in the steering. The feeling like loose lug bolts I can't tell where it is coming from. I checked the front wheels to see if I could feel any thing loose, but seemed ok. Another thing it comes and goes. I can also feel it when sidehilling. This is on my L4240 with over 1200 hrs.
I didn't notice anything in the steering. I only noticed wetness one day after I finished snow plowing. I filed it away in my mind thinking Kubota front wheel bearings never fail, especially at 650 hours. Next time I plowed it was worse so this time I felt the liquid and determined it was oil so I ordered the parts. Fortunately they arrived before the next snow.
/ Front wheel bearings failed L5740 #51
Well, yes, that is the point of the filter...to filter out contaminants.... So a new one early on, would help in filtering out more of them... Every new transmission/gear product will show lots of silver particles in the oil early on die to residual machining, early break in, normal wear, etc. I'm going to stick to the factory recommendations without a clear reason not to. I understand your point, but I am thinking that Kubota is pretty comfortable with their reasons for the schedule as written. So I should be pretty comfortable with it too. If you want to go above an beyond, no problem. I just doubt that it is really that necessary in most cases.
/ Front wheel bearings failed L5740 #52
I did a seach on fag bearing 6209c3 and came up with this. Does the load rating seem low for the work it is doing? Seems low to me with the bucket sticking out there 5 miles. I'm wondering if this came about when they started using the curved boom.
Yes. A loader tractor can see very hi loads on the fronts when lifting and pushing. This load on a bearing with significant distance between the balls causes the balls in the loaded zone to spread, skidding and moving slightly toward the unloaded zone. The bearing cage must resist this. It wears and the situation gets worse. It fails and its all over. A higher compliment of rolling elements is necessary.
,,,These bearings never see above ~200rpm. Why use a bearing rated to almost 50 times that? ... A bearing with a FULL ball compliment would probably handle the speed.
larry
/ Front wheel bearings failed L5740 #53
This is kind of my reason for questioning Kubota and I would love to have a real answer not just another opinion like my own. When I said a little older tractors I'm not talking about 70's or 80's models. My 2000 model L3000 said to change all the fluid including the front axle at 50 hrs. I know the new manuals say different but what has changed, and I mean really changed. I've been on a farm my entire life and was a heavy equipment operator for 20 yrs. Every single piece of new equipment I've every been around was full of metal on the first change. My last loader was a 08 model Cat 980H and a full service was required on it @50 hrs. And when you service one of these you're talking money, over 100 gallons of oil and almost $1000 in filters.
Are they doing something different in their machining process, doing a more thorough cleaning? Every new machine I have seen has been full of metal @50 and I can't imagine it being different now. I'm not trying to question the manual, my question is what has allowed them to change the manual?
Again this is my opinion but I would rather know what has changed to eliminate the need for a full service @50 instead of just thinking it's okay because the book says so. Who knows, maybe this is Kubota's opinion instead of a fact. Maybe they got tired of hearing owners ***** about the cost of a 50hr service and cut it out to make them happy.
It's great that we can have our own opinions about things and be able to make our own choices. For me, looking at the big picture the cost of repairing or replacing a tractor is way higher than the cost of changing oil. For that reason alone I can't make myself cut corners.
/ Front wheel bearings failed L5740 #54
I feel the 50hr is to long, I like the old school with a 20 hr. I went with manual on my 1st kubota and didn't change on the others, didn't even check the manuals on the others. I might be wishing I had went with my gut feelings with doing a 20hr on my 4240 before I'm done.
/ Front wheel bearings failed L5740 #55
Gee guys it seems like some are paranoid and doing service way before it's recommended. My neighbors a working dairy farmer and I asked him about wheel bearings in a few of his IH tractors, 1066,1486, 966. All have loaders and he does lots of big heavy round hay bails.A few of the IH's have 9,500 hours on them and he never had a failed wheel bearing, lots of flat tires but never a bad wheel bearing, now that makes you wonder huh? I know it's not a Kubota but come on, none of his tractors have ever been inside a barn of garage ever!
DevilDo
g
/ Front wheel bearings failed L5740 #56
Almost 5000 lbs for each bearing, 4 bearings with a pivot in the middle of the front axle so the load is evenly split between the two wheels would mean they can handle over 9 tons of force continuously. You're loader is only good for a little over 2 tons, if you have equal weight on the rear to balance it out (and assuming the rear axle hasn't got any weight on it) and now you are up to 5 tons, add in 3 more tons for the weight of the tractor. So now you are at 8 tons using some very liberal moth, most likely less only when you have a full load on the loader.
Brand Name
FAG Bearings
Part Number
6209-C3
Material Type
Steel
Bore Diameter
45 mm
Outside Diameter
85 mm
Overall Width
19 mm
9000 RPM
7460 pounds
4860 pounds
EAN
4012801071147
Number of Items
1
UNSPSC Code
31171504
/ Front wheel bearings failed L5740 #57
IH tractors, 1066,1486, 966.g
It's hard to compare any of these tractors to a Kubota of any size. You're bring some serious old school American iron to the table with any of the 3 mentioned. You don't play fair, everybody else is sitting around with a flip and you just came in with a 50 BMG.
/ Front wheel bearings failed L5740 #58
I have 2 neighbors with Farmalls of the generation cited that they use for loading large round bales. I've had to help both out loading bales when they had failed bearings. Both have said they want to replace their tractors with MFWD loader tractors as they consider the front end to be a weak point on theirs when it comes to moving large rounds, possibly because large rounds weren't common when those tractors were designed.
/ Front wheel bearings failed L5740 #59
Sorry guys your right those tractors that I mentioned could not have a Kubota compared to them, I'm just amazed how the still do so many field tasks and seem to run all the time. Now if you'll excuse me I just remembered that I still have diesel fuel from last winters blend, need to drain it and put in today's fresh diesel in just to make sure there's no contaminates in it
. :cool2::cool2::thumbsup:
DevilDog
/ Front wheel bearings failed L5740 #60
koyo bearings are some of the best available. wonder if they have a bad batch?
Just thinking aloud:
As you lift a heavy bale, having some ballast on the rear 3 point, and then bouncing across a field at speed, plus side loading, your dynamic load could easily go 3X your static number. Remember, when heavy laden as described, and then turning the front wheels trying to get a bale lined up on a trailer next to the previous bale, even pushing sideways to scooch them tight together. Just trying to explain the side loads on the bearings that are mainly designed for loads inline with the tire's rotation.
Many, many, old front wheel bearing designs have opposed tapered roller bearings. Not so easily done in MFWD front ends.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
INSPECTION (A65579)
INSPECTION (A65579)
SKIDDED PLAIN/WASTE WATER TANK (A65643)
SKIDDED...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
