Welding a Small Part
/ Welding a Small Part #41
For anyone wanting to learn more about tempering, etc, here is an excellent "starter" book - the author (now deceased) was, among other things, a sculptor and he traveled around the world making friends and his own sculpting tools, many locally in various home shops.
Book is mostly black and white, but the back page has an excellent "oxidation color" chart showing various latent heat colors (necessary for differing degrees of temper) - I've had a copy of this since the '70's, re-read it every so often and learn something new each time -
The Making of Tools: Alexander G. Weygers: 9780442293604: Amazon.com: Books
...Steve
/ Welding a Small Part #42
Cool. Thanks, Steve. There's a few used copies available, but I'm just tryin to find one that ships to Canada for less than the items purchase price. :(
Terry
/ Welding a Small Part #43
Wonder what others would do here.
My first bit of advice after reading these 5 pages is to use the tools you have as opposed to tools you don't have. Your MIG is perfect, and fits the above recommendation. It's much more efficient that way. :D Good reading though, lots of subjects mentioned.
But back to the title subject,,,,,
Don't jam it all the way into your counterbore, leave a little room to true it up in case it 'pulls". I'd tack one side. A good tack on a corner. Then screw it on and watch it rotate to decide if it's as straight as it needs to be, bend it straighter if necessary. Then weld up the opposite side and go all the way around. Nothing sequential is necessary beyond tack, inspect, weld. 3 steps.
Setting the MIG at 1/8 would be the MAX I'd use for this part, it's 1/16" thick. The little part barely has enough mass to absorb all the heat at a 1/8 setting. I enjoyed the comment where some fella advises about "not enough penetration". I make stuff like this all the time and the only recommendation regarding penetration is to do a test-weld first so you don't melt that pretty little thing. If you are unsure about wrecking it start at the next lower setting, like for 14ga, but 1/8 can work. Doing a couple test parts will tell you what setting you need.
Don't worry about it being "strong enough" just 3 welds (on 3 flats) is far stronger than it could possibly need to be. And could look nice too.
If those parts are mild steel you can't get any temper no matter what you do, so cool it however is convenient (or entertaining). Possibly you can get some carbon to absorb into the surface though, but what is its function? Would it benefit from a harder surface a few molecules deep?
/ Welding a Small Part #44
My first bit of advice after reading these 5 pages is...........Setting the MIG at 1/8 would be the MAX I'd use for this part, it's 1/16" thick. The little part barely has enough mass to absorb all the heat at a 1/8 setting. I enjoyed the comment where some fella advises about "not enough penetration". I make stuff like this all the time and the only recommendation regarding penetration is to do a test-weld first so you don't melt that pretty little thing. If you are unsure about wrecking it start at the next lower setting, like for 14ga, but 1/8 can work. Doing a couple test parts will tell you what setting you need.
Don't worry about it being "strong enough" just 3 tacks is strong enough (which you can do too,,,, could look nice)
Where are you coming up with "1/16 inch thick?" Please look at both photos. Try some of the things suggested, like tempering or quenching with used oil- then critique.
/ Welding a Small Part #45
Fawken I admit I'm making assumptions. If this item is made of heat-treatable steel (like spring steel) then yes it can be tempered. If it's mild steel then it can't, although it can be surface hardened with some home shop processes, perhaps dirty oil works, and you are right in assuming I've never tried it. Haven't needed it, but I am interested.
My assumption that it's mild steel is because OP was able to drill a fairly large counterbore (the 1/16" thick welding area). Folks with home shops usually find heat treatable steels difficult to work with and their posts often include details related to that difficulty.
Also yeah its thicker than 1/16, that 1/16 lip will burn back and disappear, and your weld will move down the part from where you start, which could be dicey if you want a pretty weld. But in any case the heat has nowhere to go on this small part so you don't want to weld too hot. You can penetrate to (or disrupt a little) the fine threads of that 3/8 nut easily. You may need to run a chaser thru it.
And on that note, using 3 (or 6) short, quick welds is safer than what I wrote earlier about welding all around. With regards to penetration you should worry about "too much" (not "too little"). Often in these small parts welding I have a good idea how it will go, but then I know a lot more once after the first tack.
As said I'd recommend a couple mockups first if you're unsure. I've seen the finish quality that Pat likes, and it's very feasible for this part to look nice when done. It's all good experience (which you will have, shortly).
/ Welding a Small Part #46
These "disappearing lip" and melt that thing, comments are why those of us with simple inexpensive TIG equipment would TIG that in a heartbeat. I have welded with TIG down to around 5 to 8 amps. Yes it is hard to get the arc started, but it can be done. I would start around 17 to 20 amps with that piece and see how it runs, Turn up or down if need be.
You have such fine control with TIG, I would never be without one again. And mine is nothing fancy, just a 17V torch on my little DC stick welder. Scratch start and go. Yes I know he doesn't have TIG, and I would use my MIG if that is what I had too. And I am sure he can git-er-done with what he has with the proper technique as many have pointed out and offered good advice..
All I am saying is TIG would be the preferred method for this. At least in my simple mind:) And it is not all that complicated nor expensive to get started in doing it. If it was.. I would not be doing it.
/ Welding a Small Part #47
James, my dearly departed dad use to have a saying about some people.
"You can ask them anything, but you can't tell them a thing!"
I try to keep track of what steel I am using. And I have read up a bit on quenching and tempering in the last couple days. The nut is Grade 5 which I understand to be 3-4% carbon and is tempered. So would benefit from quenching and re tempering. The tube is 1026 ie 2.6% carbon, on the low side for heat treating, but possibly capable of being strengthened a bit by quenching in dirty oil. So all in all I think it is worth doing.
On process. I started gas welding at age 14 and I know I could do a nice job on that part. Maybe I am the last known gas welder.
I guess I was really looking for feedback on MIG technique. Still learning MIG - I have satisfied myself I can do .120 - 3/8. This is smaller, so I thought it worthwhile to ask for advise. And I got lots of very good advice, thanks again to all.
If I blow it up I will just use another dollar of material and 30 minutes of time and make another. If I make a glue stick weld I will clean it up and do it over.
I understand the value and purpose of TIG, and am appreciative of the guidance offered here. At some point I will follow up on the scratch start option. TBN is always an amazing source of expertise and help.
/ Welding a Small Part #49
Don't know how this is relevant and not trying to hijack... but this I am sure doesn't deserve its own thread. That said, I just finished making a couple of 8in long QA pins for a project I am working on. I had to make my own because I couldn't find anything long enough off the shelf and I needed a close fit. I used drill rod for the pin and bent some simple 1/4in rod for the loop handle and coated with plastic dip. I think they came out pretty well MIGing it. Curious if anyone knows the material for 'drill rod'?
/ Welding a Small Part #50
Drill rod is harder than the hubs of he!!. Even harder if you heat treat it.
I used drill rod in the fair leads for the power travel on my bridge crane. They have been in use for 12-years with 3/8" wire rope running on them. And they were not heat treated. ;)
/ Welding a Small Part #51
Haha Shield, I think I get it. When I tell someone about doing a job with tools they don't have its NO surprise if they don't seem to "hear". I have no doubt you could do it if stranded on Gilligan's island with just a MIG. You could probably even teach Ginger how to do it. :D
This job is easily doable by a (motivated) newby MIG welder. And look as nice as DE's hitch pins. No doubt that subpart took 30 minutes to make, it's real nice. Why don't you grab a couple nuts out of the junkpile & weld them onto pipes first, see how it goes. Post pics & ask about those. No doubt folks can offer more focused help once they have something to look at, and once they know you're gonna use the MIG.
This can be done nicely with the MIG, a great tool.
/ Welding a Small Part #52
MIG: First one I ever used was three years ago a fella at the shop brought one in to see if I could fix it. He said it was $99 at Harbor Freight. What a jerk. I told him I wouldn't even bother taking it apart for a cheap machine like that. He said just keep it then. Took it home put a piece of bike inner tube on the feed wheel so the wire would stop jamming in the hose. I used it 3 times and ended up throwing it out.
/ Welding a Small Part #53
The most common drill rod is O1. The O stands for oil quenched. My stash of it has the ends painted yellow. That may be an industrial color code for O1.
/ Welding a Small Part #54
Fawken that sounds like bad experience! You're wise to throw it out, I'd try to fix it. Note to self, never let a $99 MIG follow me home. :D
Anyway I guess I have to restate that this job is doable with a good MIG.
/ Welding a Small Part #55
Here is a Mig weld I did with dragoneggs welder on 1/16" thick square tube.
/ Welding a Small Part #56
....The nut is Grade 5 which I understand to be 3-4% carbon and is tempered. So would benefit from quenching and re tempering. The tube is 1026 ie 2.6% carbon, on the low side for heat treating, but possibly capable of being strengthened a bit by quenching in dirty oil. ....
1026 steel is 0.26 % carbon. You might get it to harden some.
The nut will respond to heat treating, but I'm not sure of the time/tempature.
As for picking up carbon from the oil quench, I doubt such a brief time will do much. Case hardening or pack hardening takes a much longer time to produce a thin (.025 - .060) case depth.
/ Welding a Small Part #58
Shoot... I thought that was color code for diameter. I was using 9/16". I don't recall but I want to say it was red. Any clue what that means? The gal behind the counter at Tacoma Screw said it wasn't hardened yet so... ?
/ Welding a Small Part #59
Looks like 12ga 1 1/2" tube. Nice weld. I can make one just as pretty (after I clean off the slag) with my old 230A stick machine. In fact I made a 30'x7' rolling driveway gate for a guy in Mesquite out of that same steel last summer.
/ Welding a Small Part #60
Yep I made a couple tables for my wife's greenhouse using that for a frame and 5/4 eased edge cedar decking for the top. Haven't yet got welds spread like jiffy peanut butter on that gauge as SA did on his first try... Dang it.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A66736)
2015 International...
2022 PETERBILT 579 6X4 T/A CAB AND CHASSIS (A69167)
2022 PETERBILT 579...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
