Front wheel bearings failed L5740
/ Front wheel bearings failed L5740 #21
Wheel studs press out of the hub (they are splined) with an arbor press. Thats not a big deal. I'm kind of amiss on the 'red' fluid, thats hydraulic fluid and that has no friction modifiers or EP boundary lubricant like GL 5 gear oil does (and to a lesser extent UDT/SUDT), of course I use neither in my Kubby's, I use Chevron All Weather Synthetic THF in the gearboxes. Easier to see, it's orange. Not reall much cheaper though but I've never been concerned with cost of fluids anyway.
/ Front wheel bearings failed L5740 #22
3rd bearing cage failure I know of, including my L2550. Seems there was a bearing selection error on the Ls.
So? Are you recommending that I use gear oil instead of hydraulic oil?
/ Front wheel bearings failed L5740 #24
As you have the parts you now know the ring is actually 2 parts, not a true snap ring as it is locked into its groove by the recess in the gear. I ordered a ring too before tearing mine apart as it was snow season and I didn't know I would have parts the next day - I didn't disassemble until new parts were in hand. I had switched to 75W-90 synthetic at my first axle oil change so in my case possible improved lubrication from EP gear oil did not greatly extend bearing life because our failures were pretty close in hours. At times my loader has been used heavy as I moved a lot of large round bales with it before I got my M135GX. I have also moved a lot of dirt around my yard re landscaping. So my tractor has had a lot of heavy front end loader work. Still I figured Kubota would have the front Cale's over designed because everybody seems to post "can you top this" pictures showing what they have accomplished with their tractor. At least they make it quick and easy to change unless it goes to major failure like yours. Loader to lift the front end, jack stands under the axle, and a quick repair. My biggest struggle was reinstalling the tire because by using the loader and jack stands, I limited my ability to drop the axle to the R&D got hightail to line up the studs without lifting the tire. Although it isn't that heavy, it is awkward. I will go back with synthetic gear lube when I change it this week.
/ Front wheel bearings failed L5740 #25
Bearings are made with different cage or seperator options, This looks like a place where a brass separator might be a better choice.
Kim
/ Front wheel bearings failed L5740 #26
It is odd that it failed with so few hours. Our L3940 runs one or two 600-700 lbs. round bales 365 days a year, no counterbalance on the 3 pt. just loaded rear R4's. It has 1100 hours on it. I would try to find FAG brand bearings, where I used to work they gave Motion Industries over a $1 mil. of business per year just in bearings alone and the FAG brand had the least failure rate of any brand they used.
/ Front wheel bearings failed L5740 #27
It's never that easy. But, it all came off in a few minutes. One thing is that we will have to remove the old wheel studs and put them in the new shaft/hub. Otherwise, with the right tools, it should not be too hard. But that's why I've asked my brother to do it. He has all the tools in his truck.
I have been researching what oil to go back with. I asked the parts guy at the dealer what oil it needed, and he said either hydraulic oil or gear oil. I told him the oil that was in it was red, and he said that's hydraulic oil. I just went through my owners manual and there is a section on how to change it and it says to look for 'lubricants' in the 'maintenance' section. But I can't find a 'maintenance' section in the manual. This is a pdf version of a manual that I ordered online, and not a hard copy.
Every Kubota manual I've looked at says Kubota UDT or 80-90w gear oil.
I don't think you had a lubricant failure. I think the bearing was inferior.
I agree that it was the bearing and not the lubricant. I googled it and this is what I found on Kubota's web site.
FRONT AXLE ASSEMBLY
4WD Tractor Applications
KUBOTA Universal Dynamic Tractor (UDT) or Super UDT2 Fluid recommended, or SAE 80W90 (GL-4) Gear Oil
/ Front wheel bearings failed L5740 #29
FRONT AXLE ASSEMBLY
When I changed the fluids in my M9540 I used SUDT2 because that's what I also was putting in the hydraulics.
Someone on here once posted the specs for UDT versus 80-90w. They had very similar viscosity. I was very much surprised.
Got it all back together last night. Total cost for parts was about $400 including 3 gallons of UDT2 oil. It took my brother (a professional tractor mechanic) about 2 hours to get it all back together.
I'm not sure how long it will last since the gear was in pretty bad shape, and we didn't change it.
A couple things to keep in mind if you ever have to do this....1. The 'collar' is 2 pieces. I thought it was 1 piece that had broken, but it's actually 2. Make sure the parts person orders 2. My guy ordered 1, but luckily I found one more at another dealer about 30 miles in the opposite direction.
2. The 'shims' are of different thickness and the right one to order is based on your tractor serial number. This dealer ordered the wrong one because he never asked me for my serial number. We were able to use the old ones. (There were 2 in one place and one in another place).
This would have taken me at least half a day to put back together with the tools and equipment I have. Luckily my brother's truck is very well equipped and he has experience doing this sort of thing. If I would have had to pay a mechanic to do this, I could see it getting to $1000 pretty easily as I had expected it would.
0199c5b3df2f3dc83e2d77d1a3c61e9e1fc5fa04e3.jpg01d3c87ce1072dbba90fe979cceafe2c071ad344ee.jpg01a4a267136736412a7630cb2224bee0d5de5edb87.jpg01286ce228a4df91a8155c273e82369d1cf6652eaa.jpg
/ Front wheel bearings failed L5740 #31
That's good you're back at it and nice to have someone like your brother to lend the expertise. What's your brothers thoughts on the gear? When I zoom in on it I don't think it looks too bad but it's hard to tell from a picture.
He thinks it won't last long.
/ Front wheel bearings failed L5740 #33
/ Front wheel bearings failed L5740 #34
I had a bearing go on my dozer while I was deep in the woods. I had no way of getting it out of the woods other than very slowly and carefully driving it. The bull gear looked in worse shape than that and has lasted at least 6 years now without issue. I wouldn't worry about it but I would drain out the fluid. If you can find a place to put a magnet to catch the filings.
Barring further incident it will last thousands of hrs. If the same happens every 500 hrs then maybe a thousand hrs more..
I hope you guys are right. I have not been able to use it yet because of all the rain we've been getting. We did drain the fluid and cleaned everything out. You can see in one of the pics pouring diesel in the gear to clean it. It was dirty.
I just went through this a few weeks ago - I went with 80W-90 gear oil after flushing with diesel. http://www.tractorbynet.com/forums/kubota-owning-operating/337490-l3010-front-axle-seal-bearing.html
Wish I had seen your thread before we went back with mine. But, I think we got it all cleaned up and in good shape. I hope so because it's finally dry and the tractor goes back to work tomorrow and I'll be putting lots of hours on it for the next 3 weeks.
I went with the UDT2 oil.
Well.....whaddaya know....The other side failed today. Crap!!!
Luckily, I was just finishing up a job and I felt the grinding, and got out and saw oil pouring out. Loaded it on my trailer and got it back to my shop. I'll probably order the parts 'next day air' delivery from Messicks and see if I can get someone to put it back together for me by Tuesday night.
I have one more field that needs to be graded and I was planning to be on it Wednesday morning.
/ Front wheel bearings failed L5740 #39
Well.....whaddaya know....The other side failed today. Crap!!! Luckily, I was just finishing up a job and I felt the grinding, and got out and saw oil pouring out. Loaded it on my trailer and got it back to my shop. I'll probably order the parts 'next day air' delivery from Messicks and see if I can get someone to put it back together for me by Tuesday night. I have one more field that needs to be graded and I was planning to be on it Wednesday morning.
That's awful!!! This makes me apprehensive on purchasing a new / used 5740 with 1000 hours... Also see one with 1600 hrs.....
My 3540 has 420 hrs...
/ Front wheel bearings failed L5740 #40
I wonder if the original owner was one of the tractor owners that thinks the 50 hr service is not important and refused to change all the fluid out. I've changed all my new tractors at 50 hrs. On every one the front axle fluid was very nasty and the catch pan would sparkle like metal flake paint.
Caterpillar C Series Backhoe Service and Parts Manuals (A63117)
Caterpillar C...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2018 Ford F-150 4x4 Pickup Truck (A61573)
2018 Ford F-150...
(2) 26X12.00-12 TIRES W/ 5 LUG RIMS (A64280)
(2) 26X12.00-12...
