Mig weld bead diagnosis chart?
/ Mig weld bead diagnosis chart? #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
Is there a site that would help me understand more about my welds?
For example, what does it look like if my wire is to fast or to slow, machine to hot or to cold?
/ Mig weld bead diagnosis chart? #2
When I was a newbie at this I got great info from the Lincoln Welding site. I had their hard copy material but I was told everything was on line as well. Their material is excellent. My instructor said to buy whatever machine you want but go to Lincoln for the info.
Thanks! I'm using a Lincoln... It's been years since I've fired it up and couldn't watch the VHS it came with :). Will check out their site.
Was welding som AR500 for some shooting targets and it's much thicker than I'm used to.
/ Mig weld bead diagnosis chart? #7
/ Mig weld bead diagnosis chart? #8
Those sights will help you get in the 'box', but your still going to put a piece of scrap on the table and experiment with the settings to find the 'sweet spot'. I'll also add this: Check your electrical connection starting at the breaker box all the way up to the connections inside your welder. If your not comfortable working around electricity, hire somebody that is. Welders draw a lot of current and create heat and it is not uncommon for the heat cycles to cause loose connections. If your welds start out good and get more erratic as you go, this is a classic case of what I just described. Also check your ground clamp. It should be clean and not oxidized. Make sure your contact tip isn't worn. Once you get to this point, set up your scrap piece and play with ALL the settings. You will learn a lot on your own.
/ Mig weld bead diagnosis chart? #10
I see you are trying to weld AR plate. A Google search on that subject might help you with your set up.
Yeah. That ar500 plate is different. First quick tack rolled off it.
Hard to get a good pic.
Finished product. Base is made out of scrap laying around.
I guess some shots with my 45 and 454 should tell if my bubblegum sticking holds up.
Holding up so far to a .45. Had to turn my wire speed down and spend more time on the ar500 plate to get decent fillet weld.
/ Mig weld bead diagnosis chart? #15
Yeah, that stuff usually likes some preheat and 7018 stick - haven't tried wire on it yet, maybe a couple of projects from now... Steve
/ Mig weld bead diagnosis chart? #16
When I did this bucket extension a few years ago, the metal supplier didn't have AR-500. Only AR-200. I pre-heated, welded the cutting edge with Lincoln's L-56 wire, and a slow cool down. Still working great.:thumbsup:
/ Mig weld bead diagnosis chart? #17
What is the purpose of the flip away sections on the target? That leaves a hole presumeably for head shots and centre of mass, but how do you know you hit them?
It's a reactive target. Those are paddles that flip back and forth when you hit them.
When you hit the head shot it flips out to give you a hostage shot.
On the back of the ar500 plate I welded tubes that the paddles slide into and allow it to flip back and forth.
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
24220 (A56859)
24220 (A56859)
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
