Thoughts on this Armstrong grapple
   / Thoughts on this Armstrong grapple #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
A place just down the road from me carries Armstrong attachments/implements. I like that this grapple opens really wide, just concerned about the bottom side not extending out very far. I want to pick up brush, which it should have no problem with, but I don't want any problem picking up logs up to 18"-24" in diameter.
http://www.armstrongag.com/app/download/6353569/BGR+-+BRUSH+RAKE+GRAPPLE.pdf
   / Thoughts on this Armstrong grapple #2
Since the upper " jaws" hydraulically close I see no problem with that unit picking up any sized log.
   / Thoughts on this Armstrong grapple #3
I don't like it at all.
Short apron is going to really limit what it can carry.
Blunt jaw teeth is going to prevent it from digging into an odd shaped piece and snagging it.
Solid, one piece jaw is going to cause it to constantly be dropping material as you try to move it. The jaw will only be clamping hard on the largest object, everything else will try to fall out.
   / Thoughts on this Armstrong grapple #4
Mine seems to pick up brush piles very easy. (Picks up things it shouldn't too) image.jpg
That's what I'm thinking. I want to be able to scoop up stuff and then clamp down on it. I look at the clamp as more of a thing to keep the load from falling off during transport to the burn pile or whatever.
   / Thoughts on this Armstrong grapple #6
My first ever grapple was that style, works like a dozer blade for removing brush. Not great at picking up brush, good for picking up logs. Sold it when I sold the V518.
For picking up brush, and logs, I prefer this style. :thumbsup:
1997 EZ-GO TXT Electric Golf Cart (A50860)
1997 EZ-GO TXT...
1998 Lexus ES300 Sedan (A48082)
1998 Lexus ES300...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
