Looking for advice on a 3616
/ Looking for advice on a 3616 #21
Do yourself a favor and don't sit on a suspension seat. You will want to change out the standard seat in a hurry. A suspension seat cradles your rear end as you blissfully sink into comfort. It's a night and day difference.
Here is a prime example of "ignorance as bliss".....and cheaper.
I use a rear blade and the bucket that came with the tractor (3016 which is same frame) I built up the sides of the bucket to make it act more like a snow pusher and it greatly reduced snow plowing time by a third to almost half depending on snow depth.
That is awesome that is what I need to do. What did you all use to make that work and how exactly did you do it.
/ Looking for advice on a 3616 #23
It is made out of 1/4" steel for the sides. It is supported by the 3/4" log hooks at the bottom because I do my logging in the winter and wanted something that would take less than 3 minutes to whip on and off. There was no deflection of the panels ever no matter what the snow depth (including the 25" drop). Here are pics describing build. Cost $40. Log hooks were $50 as I had them cut out. They are held on by one bolt per side.
Does the snow blower work good? What was the price tag on something like that?
/ Looking for advice on a 3616 #26
Works like a dream...it's a Bercomac with the Manhindra name on it front mounted so you need the mid pto...i believe after all was said and done it was right around $4000 i believe...a lot i know but i live in northern Maine and we get SNOW a lot of SNOW...plus my drive is 800 feet long and on an incline...it will cut through 2 feet of snow with no problem...for me it was worth every penny...:cool2:
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Kuhn FC400RG (A60462)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
2021 Bobcat T66 (A60462)
2021 Bobcat T66...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
Toro Timecutter Max (A61166)
Toro Timecutter...
