Oil Recirculation in closed loop system
/ Oil Recirculation in closed loop system #81
Excerpt from Eaton steering valve like mine.
Flow is only directed to the tank port when steering is
operated. Avoid systems where return flow from tank
port is used for auxiliary functions.
Do you not have a tank port on your steering valve?
His oil was discolered for some other reason.
/ Oil Recirculation in closed loop system #82
If you push the left rod in, it goes to the return via the tee.
If the pump is doing the pushing, the flow from both cylinders goes to the tank via the return.
I wish I had that hydraulic modeling software to show the flows.
Ken
/ Oil Recirculation in closed loop system #83
The majority is still getting transferred from cylinder to cylinder, and not much to the tank.
/ Oil Recirculation in closed loop system #84
Moss,
If you trace the two vertical lines, one goes to the pump via the valve. The other goes to the tank via the valve.
In a hydraulic cylinder circuit, pressure determines the amount of force you can overcome and flow determines the speed and magnitude of movement. If there is no (or minute) flow to the tank or the return of the pump, then there is no real movement. You are saying no flow to the return of the pump/tank so there can only be minimal movement of the cylinders.
Flip the right cylinder 180ー leaving the hose connections as is. If you now mechanically connected those two cylinders as is to your FEL, it would work appropriately except because the rod end are switched, the cylinders would not have equal maximum force.
In this case, I am afraid that everything I know about physics as applied to hydraulics says you are not thinking about this correctly. Doesn't mean that I am not missing something because I am quite capable of having a brain fart but in this instance I do not think I am. If I thought there was an even 1% chance I was wrong on this, I would ask in the hydraulics forum.
Ken
Well, everyone in the choir is off-key, but me! :laughing:
/ Oil Recirculation in closed loop system #85
Ken
Me, too. A nice animated GIF would do me some good. :)
/ Oil Recirculation in closed loop system #86
Or is the schematic this way, which would make more sense?
423762d1430959785-oil-recirculation-closed-loop-system-steering8-jpg
When you push more orange stuff in the cyl, where is the orange stuff on the other side of the piston going.
Answer: TANK
/ Oil Recirculation in closed loop system #87
In your diagram, that is the same as saying the white hoses are supplying pressure. If the flow did not return up the vertical leg of the Tee on the "red" lines, then you have the red (low pressure side of the right cylinder) being stronger than the pressure from the pump. There is no way for that to happen if the red is connected at all to the return of a pump directly or via the tank because that line is at minimal pressure. If the red line does not connect to the tank/pump return, then there is no flow from the pump which means the tractor is not doing any work.
Ken
/ Oil Recirculation in closed loop system #88
If you push the left rod in, the right rod extends.
Someone just get in their car, drive over here and slap me silly cause I ain't getting it!!! :laughing:
/ Oil Recirculation in closed loop system #89
NOt true at all.
You are filling both cyl, period. Both are doing work.
/ Oil Recirculation in closed loop system #90
What you are saying is I believe correct when YOU are pushing on the end of the rod and the valve is closed because YOU are doing the work and not the pump. You are the mechanical force I was mentioning earlier. But when the pump is supplying pressure via the valve, then you are the force to be overcome. And I hate to hurt your ego but unless you have a very long lever and a good fixed fulcrum, the pump/cylinder is moving you.
Ken
/ Oil Recirculation in closed loop system #91
Ken
Don't make fun of my skinny arms!
/ Oil Recirculation in closed loop system #92
MossRoad
The above is correct as the pump is filling both cyl and pushing old fluid to tank.
Turn the steering the other way and the flow reverses.
/ Oil Recirculation in closed loop system #93
OK, I think I've got it...
The two full sides are tied together and the two empty sides are tied together.
Why didn't anyone say that before?
:laughing:
/ Oil Recirculation in closed loop system #94
Orange is pressure, green is tank. Turn the wheel and they reverse. Right? I think I finally get it. :cool2:
423776d1430964448-oil-recirculation-closed-loop-system-steering9-jpg
/ Oil Recirculation in closed loop system #96
ok, David, now lets see you animate that... and add the steering control valve for good measure...
/ Oil Recirculation in closed loop system #98
Orange is pressure, green is tank. Turn the wheel and they reverse. Right? I think I finally get it. :cool2: <img src="http://www.tractorbynet.com/forums/files/power-trac/423776-oil-recirculation-closed-loop-system-steering9-jpg"/>
So the fluid returning to tank is determined by the steering control valve position, ie whether turning left or right? This thread has been a great read.
/ Oil Recirculation in closed loop system #99
Whew, I am glad that mystery is over.
I thought I was going to have go back to the Holiday Inn and get more sleep.
/ Oil Recirculation in closed loop system #100
Yes, that's the point.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2022 EZ-GO ELITE...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
