Oil Recirculation in closed loop system
/ Oil Recirculation in closed loop system #41
I always thought the joystick valve had a return to the tank and you would be getting the cylinders purged with use. Shows what I know.
Ken
The FEL valve does have a tank port and dumps the total flow, both expended steering cyl fluid and pump flow.
I an not sure you are replacing all the fluid when you steer, maybe a little at a time as you use the steering.
You would have to go left full steer and then right full steer to use all the fluid.
/ Oil Recirculation in closed loop system #42
I meant purged over time, not 100% each time the steering was used.
Ken
/ Oil Recirculation in closed loop system #43
opposite ends of the cylinders are tied together instead of the same ends.
That's the key.
In the FEL lift circuit, when both cylinder bottoms fill, both cylinder tops empty towards the tank. When both cylinder tops fill, both cylinder bottoms empty towards the tank.
In the steering circuit, when the left cylinder bottom fills, the left cylinder top empties towards the right cylinder bottom, not towards the tank. When the right cylinder bottom fills, the right cylinder top empties towards the left cylinder bottom, not towards the tank. Since both the left steer and right steer circuits are of equal volume, there is no need for the fluid to go back towards the tank, as it has to fill the opposite cylinder end.
/ Oil Recirculation in closed loop system #44
I don't agree.
The steering is available at all times, and has priority.
The FEL get the PB fluid from the steering valve.
The fluid is flowing through the steering valve through the FEL, then to tank.
You always have volume in GPM, the hyd components develop the pressure.
I think you are correct on that. That's why the FEL locks up when the steering is at full turn.
/ Oil Recirculation in closed loop system #45
Yes, you lose a little fluid back to the tank when steering, but it has to be an extremely small amount. Going full left and then full right moves most of the fluid between the cylinders, not back to the tank. Look at the schematic. If fluid leaves the bottom of one of the steering cylinders it has to be made up in the top of the opposite steering cylinder. Very little fluid will pass through the post of the TEE back to the steering valve. It has to go through the cross of the TEE to fill the other cylinder.
I'm saying the steering valve is pressurizing one side of the steering circuit while relieving pressure on the other, not flowing tons of GPM, just tons of pressure.
:confused3:
/ Oil Recirculation in closed loop system #46
Ken
I don't see how it can ever be purged even over time. That's why the oil is darker in the steering rams. Perhaps a call to Terry at PT is in order for clarification.
/ Oil Recirculation in closed loop system #47
My guess is they'll tell you to crack a fitting to purge any air from the steering cylinders.....
/ Oil Recirculation in closed loop system #48
Hi Moss,
I would agree with you if there was a mechanical force pushing and pulling on the steering cylinders but it is a hydraulic pump. There is significant flow required. If I ever think to do it, I will ask Terry what he thinks about that circuit.
Ken
/ Oil Recirculation in closed loop system #49
Maybe I am not seeing things the way some of you do.
Every time a cyl moves, the expended fluid try's to go to tank.
New fluid from the valve is going to the cyl pushing and the other cyl pulling.
Turn the steering, and the fluid moves the other way.
I believe you are putting fluid in a line and then adding to it, with fluid going to tank.
You don't pull from one cyl and add to another.
So when you are turning full lock, the fluid is filling the base side on one cyl and the rod side on the other cyl.
I believe the hoses are short enough to exchange fluid
You have the hose from the steering valve to the cyl and then you have the hose from the cyl to tank.
The steering valve is sending fluid to the cyl or to the lift circuit or both at the same time.
You only have full flow from the steering when the steering wheel is at full lock, and there must be a relief valve there somewhere.
Put several drops of fluorescent hyd dye in one cyl and see if it ever gets to tank. Use black light and look in tank.
/ Oil Recirculation in closed loop system #51
Dear MR,
I hate to disagree, but to move a cylinder, there has to be a volume change. When you steer, you adding fluid to both the left and the right cylinder (opposite ends). That causes the cylinders plural to move. That movement dumps an identical volume to the tank. That volume is ~ 2x30=60cu inches per lock to lock cycle. I don't know if the analogy works, but it's like climbing on a teeter totter. You need a pressure (weight) difference to get movement. That movement does displace oil to the tank. As you correctly point out, in the steering circuit the cylinder ends are flipped, but just like the lift circuit, oil goes into one end and out the other. It is just that in the steering circuit, instead of having both bottoms filled, we are filling the left front and the right rear, while draining the left rear and the right front. (or vice versa).
Maybe this won't be quite so mud clear, but, feel free to point out the error in my thinking so that I can understand hydraulic systems better.
All the best,
Peter
:confused3:
/ Oil Recirculation in closed loop system #52
My simple answer is that expended fluid goes to tank from the valve and gets new fluid every time the cyl is activated.
I have stated how to check it, and that is using some hyd fluorescent dye in the cul to see oif it evere gets to tank.
The steering is not a closed loop system.
Cyl expended fluid is not normally reused, but can be used in certain circumstance.
There are two different volumes used when you steer. the base end holds a certain amount of fluid, and the rod end holds less.
The fluid does not bounce back and forth in the cyl circuit.
Can you not agree that if the base end is empty or the cyl is retracted, as the valve opens to extend the cyl, the pump is pushing new fluid in the hose plus the hose fluid.
/ Oil Recirculation in closed loop system #53
Dear JJ,
I agree with your points- just trying different words to see if we can all come to agreement.
All the best, Peter
/ Oil Recirculation in closed loop system #54
The only way for the fluid to stay in the cyl and move back and forth is with a hose size and length that could contain the same volume of fluid as in the cyl.
Say you had one quart of fluid in the base end of a cyl. What would be the length of 3/8 in hose to keep fluid from going to tank. Other wise , the length of hose from cyl to valve that could contain one qt of fluid.
The volume of fluid in a 3/8 hose is .006 gal per ft.
A 30 ft hose would only contain about .18 gal.
One qt = 1/4 gal.
So every time you fully extended the cyl, you would dump some old fluid and add new when extended again
So the answer is that the fluid is always changing.
/ Oil Recirculation in closed loop system #55
Most closed loop systems do leak about a pint to quart an hour so the whole system is filtered just slower, and trash will circulate, which is why high pressure loop filtering is required anytime the closed loop is opened. The steering cylinders will not leak unless the seals are bad and they will keep circulating the same fluid, and the fluid gets bad after a while...
Not true.
Read my other post.
You are always adding new fluid from valve to cyl.
You would need about 55 ft of 3/8 hose from the valve to the cyl to keep using the same fluid.
/ Oil Recirculation in closed loop system #56
Maybe the issue is that you don't get good flushing of the fluid in the cylinder (it essentially looks like a dead-end section of pipe... that moves back and forth). So wear products tend to build up in the fluid inside the cylinder; some of the the fluid expelled from the cylinder as it strokes isn't washed all the way back to the tank, but stays in the hose, to be flushed back into the piston when it strokes the other way,
/ Oil Recirculation in closed loop system #57
A small amount of fluid may be left in cyl, but the new fluid will mix with the old and keep mixing as you use the cyl.
I would suggest the discoloring of the fluid is due to contamination by water, causing acids , which could make new compounds.
So I am still here, have been following this with great interest. But I am not seeing it the way you guys are so help me a bit cause I am, well, no scientist.
So oil goes to the steering control under pressure. If not assigned to a pipe it returns to a tank (pipe being the hose to a steering cylinder).
So now I turn the wheel, and oil is assigned down a hose, pressurizing that hose, and in turn pressurizing the hydraulic cylinder.
Now the Hose to the Cylinder is long (my magical hose chart says 37" for each hose) and the Cylinder is actually quite small. I guess in the end the hose has a quite small diameter so maybe this is where the logic fails me....
Anyway, cause the hose is so long, and the oil in the cylinder has no place to go, how is oil recirculating. Maybe there is some mix happening in the hose at the head as it is pressurized but I don't see how fresh oil is going to make it all the way to the cylinder. Fresh oil is only going to go so far down the hose until the Limit of Travel on the cylinder is reached.
Now my whole theory could be bunk because the hose holds X amount of oil and the cylinder requires Y amount so indeed the hose is being purged to the point of getting fresh oil from the steering control.
Anyway, poke holes folks. Got lots to learn before I die.
/ Oil Recirculation in closed loop system #59
You can rest assured that a hose that short from cyl to valve is going to get a fresh supply of fluid each time you cycle the cyl.
The old fluid from the cyl has gone to tank after one cycle.
Hypothetically if you only use micro movements of the steering, the fluid might not exchange for a while, but I can bet that you do go full rotation sometimes.
I don't know if your hyd system is close to mine, but if the volume of fluid in the cyl is more than the volume in hose to the valve, it is going to add and exchange be it a little at a time if you.
It is not a closed loop system, and nobody would design it that way with a logical mind.
Say the cyl at full retract has 1 oz of fluid in the vase end, and say the hose to the cyl has 6 oz of fluid in the hose, then to fill a 32 oz cyl, you get to add 25 oz of new fluid from the valve which has new fluid from the pump.
Don't know more that I can say.
I would say that the dark fluid in your cyl was contaminated.
2 in bore
1 in shaft
16 in stroke
Volume extended .2175 gal
---------retracted .1631 gal
Your 37 in hose contains about .0176 gal
Can you not see what will happen?
Your cyl contains way more than the hose, so it is gong to exchange/add each time.
If your steering cyl is 3 in bore, the volume will be greater
Cylinder Calculator: Hydraulic cylinder valume capacity
I knew you would have the math...
Thanks as always. Going to pull oil out of the tank again and double check. Maybe it was just me thinking the oil looked too dark
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
