Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,941
Its setup for a fine cut. When i was looking at it, it had a slight bearing whine so he let me have it for $500.
Ill be using it to keep about 1 3/4 acres knocked down. I had been using my brush hog but it never looked like I wanted it to. Plus Ive wanted a flail for a long time! ��
Congratulations! That thing looks really well built for $500!
/ Let's talk flail mowers #1,942
Good morning,
I hope the sun is shining in Oklahoma today.
I want to welcome you as the newest member of the Flail Mower Nation.
No worries about your purchase. The V belts and bearings are obtainable locally.
All Bearings and V belts are measured as metric in actual size.
Check the V belts and if any rubber dust falls into your hands you need to dispose of them
and buy new ones. purchase the Green Kevlar belts if possible as they are shock resistant.
Check to make sure the gearbox has oil and it has no water in the oil.
Just be sure to grease the flail mower rotor each time you mow or after you mow with six
pumps of high temperature grease to flush the bearings and no more, remove the V belt guard and
dig out/wash away the rubber dust with hot water to expose any buried grease fittings and check
the tensioner pulley if it is a spring type that has a flat pulley for movement to assure it is free moving.
Be sure to grease the open driven bearing that rotates the V belt pulley(the one under the V belt guard that
is connected to the cross shaft that is connected to the gearbox.
I have a universal joint connected to the output shaft and engine crankshaft on my flail mower and I need
to grease that several times per year when i use my flail mower.
Check the bearing housings on the inside to be sure that nothing is wrapped around them each time
you mow.
The rear roller should get at least four shots of grease and preferably when the mower is raised and you can spin the roller.
Happy mowing.
Once you go flail you never go back!!
Only 17,870+- mowers to go.
/ Let's talk flail mowers #1,943
Thanks so much! Unfortunately *not really, we are in a drought!* its been raining for 2 days. As soon as its nice I'm going to hook it up and grease the crap out of it and check my belt, then spin that baby up. Glad to FINALLY be part of the fail nation!
/ Let's talk flail mowers #1,944
Welcome from New Brunswick
I purchased a 7 foot Hanmey flail mower last year, it was slightly used but like new it is one of the best investments I have made in a few years. I mow 20 acres of field with my flail set up as a finish mower, my fields look like a golf course after each mow. The flail allows me to operate tractor at a lower RPM with my PTO in the 1000 RPM range, I used a portable Tach meter to get the proper engine RPM so I do not over rev my flail.
I can mow at a higher ground speed and lower engine RPM and achieve a good result, love it.
Troy
/ Let's talk flail mowers #1,945
Thanks so much! ....... Glad to FINALLY be part of the fail nation!
Fail nation??? Wrong address, that forum is three doors down on the right!
Congrats on your purchase, you got a really good deal even if you need to replace bearings, belts and knives.
/ Let's talk flail mowers #1,946
I have an old Vemco flail with a 74 inch cut. The previous owner had welded chains to the attach points so it really beat and bent the lugs. Had to replace 18 and straighten almost all the rest. To save money on set up I skipped the fancy Jacobson style shackle and just attached the blades on either side of the single lug attachment points with a bolt/locknut setup. Getting cleaned up and finding the grease fittings was the easy part. I'm using a MF-65 diesel for power and it seems to be fine.
/ Let's talk flail mowers #1,947
I have an old Vemco flail with a 74 inch cut. The previous owner had welded chains to the attach points so it really beat and bent the lugs. Had to replace 18 and straighten almost all the rest. To save money on set up I skipped the fancy Jacobson style shackle and just attached the blades on either side of the single lug attachment points with a bolt/locknut setup. Getting cleaned up and finding the grease fittings was the easy part. I'm using a MF-65 diesel for power and it seems to be fine. M
/ Let's talk flail mowers #1,948
My husband and I have a 52-acre weekend farm in Magnolia, Mississippi with rolling hills. We cut several acres around the house with a zero turn and about 40 acres of thick hay grass / pasture with two late-sixties Ford 3000 tractors (38 HP at the PTO) with bush hog type rotary mowers. We also have 10 acres of thicket that we are slowly clearing and cutting trails through. Due to our schedules and the weather, we cut the grass / pasture area once every 6-8 weeks. I am interested in a flail mower due to the large clumps of grass currently left by behind.
I stumbled on this tread a few days ago and finally made it to the end, although I skipped a few pages here and there. I am considering the Caroni mower because it seems to be the best value and fit for us, but I just wanted to verify that I did not need a heavier duty mower due to the acreage and continuous operation time. There are no rocks or stumps in the grass / pasture area and I should be able to keep my husband from using the flail mower in the thicket as long as one of the tractors always has the heavy duty rotary mower attached.
/ Let's talk flail mowers #1,949
The thick hay grass explanation of your field and cutting every 6-8 weeks would be difficult to maintain with a light or medium duty flail, increasing the frequency of the cut would allow a flail to do a better job for you. I have found that in thick grass a foot tall the flail will have difficulty clearing itself of the clippings. I mow bi-weekly during grass growing season, this allows me to mow to golf course quality grass height.
A heavy duty Flail with the right knives will mow what you have described but like all of us part time farmers budgets sometimes prevail over needs.
/ Let's talk flail mowers #1,950
The Caroni should be fine for your acreage even with long intervals between mowing. It won't leave the land looking like a golf course but it is much better than what a bush hog does. I mow typically every 6-8 weeks and in some areas just once a year. Just don't mow when it is wet. I'll repost a few photos showing what it looks like below.
If you are used to maintenance free bush hogs you will need to readjust however. Greasing of bearings (2 minutes) each day and periodic replacement of drive belts (about $50 every few seasons) are routine maintenance requirements. Blade replacement intervals will depend on how many obstructions you hit. Some guys seem to go forever without needing blade maintenance when mowing pastures. Others, myself included, mow in rocky areas and I probably replace about one set of two blades and clevis every four or five acres mown. If you have read through the whole 1947 posts before yours, you are probably aware that the Caroni supplied clevises used to hold blades are not as durable as those sold by Flailmaster (but which require minor modification to fit).
Based on my experience, the Caroni will certainly fix your problem with clumping. I would probably still use the bush hog to do first cutting of the 10 acres of thicket even though the flail can do that work too simply to save on broken clevises/blades.
/ Let's talk flail mowers #1,951
Kathryn, watch out for that Island Tractor guy, he will be very good at spending your money!! HAHAHA!
I'm into about $3000 in new implements cause of him!:laughing::D
All good stuff, I bought a Caroni flail partly due to his advice and I love it! Dont ask him about a grapple however, unless you want one of course!
/ Let's talk flail mowers #1,952
Kathryn, If you are going to be mowing +50 acres I would be looking at a medium/heavy duty flail mower with at least an 84" cut. Not knocking Caroni but I think the widest they offer is a 6'.
/ Let's talk flail mowers #1,953
Katherine, If you are going to be mowing +50 acres I would be looking at a medium/heavy duty flail mower with at least an 84" cut. Not knocking Caroni but I think the widest they offer is a 6'.
I would agree that wider is better but the cost of going past 75" (Caroni) involves basically at least doubling the acquisition cost. More if heavy duty. If they are a non commercial hobby farm it just may not be worth the extra $$.
/ Let's talk flail mowers #1,954
Valid point! I guess it depends on their budget and willingness to put in the extra seat time. Having kept up about 40 acres of semi rough property with a 72" cut was very convincing. My thinking is more seat time equals more wear and tear time on your body, tractor and implement, not to mention the additional fuel and maintenance due to running everything longer. I can't speak for everybody but to me that additional 2k investment is well worth it in the long run.
/ Let's talk flail mowers #1,955
Understood. The other issue with going bigger though is the available PTO HP and the fact that they mow infrequently and therefore are mowing lots of material. No doubt 38hp can drive more than a six foot flail but not so sure it could drive a 7 or 8 ft flail in thick grass at normal mowing speed. If you have to slow down it partial nullifies the benefit of the wider mower.
/ Let's talk flail mowers #1,956
Friend of mine got the 7ft value Leader from Betstco last year and very happy doing his 30 acres. Sorry I don't remember exact size or price.
David
Created = 1;
Discard = TRUE;
Domain = ".ridgid.com";
Name = "__utmc";
Path = "/";
Value = 192756009;
/ Let's talk flail mowers #1,957
Thanks for all of the responses. I have decided to go ahead and order the Caroni. We are fortunate that we could spend more for a heavier duty mower, but we can use the extra money on other items on our list, especially if it's not needed. If we did not already have several rotary mowers, I might go with the heavy duty flail. All of our rotary mowers are only five feet, so a six foot flail is definitely an improvement.
Here are some pictures of the front pasture the Craig cut last weekend with the rotary mower that leaves rows of grass and causes ruts. Sorry about the rotated one - I could not figure out how to fix it.
/ Let's talk flail mowers #1,958
You won't see windrows with the flail but if you cut really high or lush grasses, there will still be evenly distributed cuttings laying on top of the cut grass that will turn hay color in a few days. Only way to prevent that is to cut more often.
/ Let's talk flail mowers #1,959
Those pics look really nice!! What kind of speed are you running to get those results?
/ Let's talk flail mowers #1,960
In the really heavy stuff or brush I typically run in low range both for better cut and so I can look out for obstacles. Not sure what MPH. Strolling pace is the best I can come to quantifying speed.
In fields I know well but are dry and have tall but not dense grass (usually Sept or Oct after no mowing since Spring) I mow in midrange at a speed that doesn't rattle my teeth too much. The fields are a bit lumpy. I'd say fast walk or jogging speed.
2025 IRANCH IREAS Wood Grab Grapple Mini Excavator Attachment (A61572)
2025 IRANCH IREAS...
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
2016 Jeep Compass AWD SUV (A61574)
2016 Jeep Compass...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
