Replacing spool valve detents
   / Replacing spool valve detents #1
stowepotato
Stowe, VT
NH TC-29
I'm replacing the detent valves on the front end loader control for my NH TC29.
My basic question is whether the new parts should be lubricated before installing and with what and how much.
I don't see how any hydraulic fluid can get into the detent. But I find that water accumulates in the cap leading to rust and freezing up in the winter.
Any thoughts?
   / Replacing spool valve detents #2
Any thoughts?
I believe you can use vaseline to hold the ball bearings, springs, o-rings, and other parts in place, and it won't have any downsides if it somehow does come in contact with hydraulic fluid.
Hydraulic fluid really shouldn't reach the detent action unless the spools are leaking, and even then, it won't really be circulating. So you can probably get away with any old grease really.
Does that suggest that the real way to solve the recurring presence of moisture in the detents is to rebuild the spools with all new o-rings and seals?
   / Replacing spool valve detents #4
Not to me. I guess I don't understand where the water could be coming from other than an external leak. Couldn't possibly be internal in my mind. Is the tractor stored outdoors?
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
23013 (A55787)
23013 (A55787)
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2007 Hannay reels Hose Reel (A54865)
2007 Hannay reels...
MILLER MP-30E WELDER (A54756)
MILLER MP-30E...
