Replacing spool valve detents
   / Replacing spool valve detents #1
stowepotato
Stowe, VT
NH TC-29
I'm replacing the detent valves on the front end loader control for my NH TC29.
My basic question is whether the new parts should be lubricated before installing and with what and how much.
I don't see how any hydraulic fluid can get into the detent. But I find that water accumulates in the cap leading to rust and freezing up in the winter.
Any thoughts?
   / Replacing spool valve detents #2
Any thoughts?
I believe you can use vaseline to hold the ball bearings, springs, o-rings, and other parts in place, and it won't have any downsides if it somehow does come in contact with hydraulic fluid.
Hydraulic fluid really shouldn't reach the detent action unless the spools are leaking, and even then, it won't really be circulating. So you can probably get away with any old grease really.
Does that suggest that the real way to solve the recurring presence of moisture in the detents is to rebuild the spools with all new o-rings and seals?
   / Replacing spool valve detents #4
Not to me. I guess I don't understand where the water could be coming from other than an external leak. Couldn't possibly be internal in my mind. Is the tractor stored outdoors?
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
UNUSED JCT 72" HYD BRUSH CUTTER (A54757)
UNUSED JCT 72" HYD...
