Do You Cover Your Vertical Exhaust Stack Tip While Trailering?
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #1
Utopia Texas
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I've owned and driven dozens of tractors in my 61 years and tonight read something in the manual of my NH T4.75 that I had never seen before. The manual says to cover the end of the vertical exhaust stack when trailering the tractor so air/wind does not travel down the exhaust system and spin the turbine which is not being lubricated with the engine off. Has anyone ever burned out the bearings on their turbine set up by not following these instructions? This is a new one on me ! :)
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #2
I've heard of it but don't know anyone it has actually happened to.
I passed a load of New Hollands headed to a dealer the other day and don't remember seeing the stacks having covers.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #3
We moved lots of tractors between Missouri and Louisiana,and always covered the exhaust pipe,to prevent the turbo from spinning without lubrication. Note,it only applies if tractor is turbo charged.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #4
you'll get a lot of controversy on this. called "pinwheeling", the idea being the turbo is being rotated (due to vacuum) while being transported & not in operation & w/o lubrication. will be interesting to see what advice you get here. it is an old school practice to plug it up in transit. an old sock will do.... when i park outside in the open i cover the stack with something to keep the moisture out...just an old practice. hey ask a seasoned trucker on this one....
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #5
Someone told me that the turbo does not even have bearings. Somehow it spins in oil. So I am told.
I cover the stack, just in case. I mean, no big deal.
But I wonder, where can the air go? You need air flow to make the turbo spin.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #6
Turbochargers have ceramic bearings/seals on the hot side and conventional bearings on the cool side fed with pressurized oil.
I've never covered mine up when transporting on the low boy with no issue. If it sits outside (rarely) in the rain, I cover the stack so when I start it, it don't blow black soot all over the hood.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #7
vacuum is created in this situation (while being transported) & the turbine will spin, doesn't have to be an inlet/outlet for that to happen
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #8
In theory the air must have some place to pass through. Usually only an exhaust or an intake valve is open but the top of the exhaust stroke is the start of the intake stroke so briefly there is a valve overlap that will allow air passage. However this also holds true for parking your tractor outside if it is windy. On a truckers forum, one trucker said the bill of lading for one manufacturer states the exhaust must be covered. Can't remember which company that is. Another said he had a turbo show failed when the tractor was unloaded but was fine when he loaded it at a factory so his insurance had to pay for the replacement. Yet another trucker said he didn't think it was possible but why take a chance. He keeps a stock of Nerf footballs in his cab. If he forgets the exhaust blows the football out of the stack when the engine is started. Our John Deere dealer claims they have a valve that prevents turbo damage. Not sure what that would be unless it is an anti-bleed off valve that keeps oil in the turbo bearing area when the engine is shut down.
My manual actually uses the word "bearings" but who knows?
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #10
this is going to be an interesting thread. nerf footballs so far is my favorite answer....
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #11
If this is the case, it made me wonder if starting your tractor with cold oil can't be harmfull to the turbo as I imagine it doesn't get oil immediately.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #12
I think that would only be a problem IF you were to immediately put it to work. Depending on how cold it is out, most manufacturers of engines dictate that we should let them 'warm up' for a certain amount of time. This is to let the oil and engine warm up.
Although the turbo spins when the engine is running at idle, it isn't spinning fast enough to do any damage with the cold oil.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #13
When my used JD 6415 was delivered by Semi truck & trailer, the exhaust was covered. Not worth the risk when covering is so simple.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #14
I trailer an MX5100 turbo and stuff a paper towel in the exhaust. I think tractor makers now try to tip the exhaust so the air stream doesn't hit the pipe just in case the operator forgets. Damaging turbos used to be a concern and there were prominent warnings in the owner's manuals.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #15
I have a 2007 TD95D and my operator's manual makes the same recommendation. It certainly is a possibility that the turbine can windmill under those conditions. Why argue about whether it's a real problem when $0.03 worth of duct tape can close off the exhaust?
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #16
When ever I've had any equipment with a turbo low bedded the drivers have always stuck a rag in the exhaust for the reasons mentioned.
Just a side note on stuffing a rag into the pipe when trailering. I took my NH T4.75 with Tier 4B in today for the 50 hour service and stuffed a small white hand towel into the stack about a foot down with 2"-3" sticking out the pipe. When I arrived at the dealership I pulled the towel out knowing I would have to throw it away from being dirty and it came out clean and white. You cannot tell it was ever in the exhaust pipe.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #18
I've always just stuck a paper towel in the exhaust. Then when I forget to remove it, which is most of the time, the exhaust pressure just pops it out. It doesn't need to be pushed in hard or taped closed.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #19
It's a good idea to cover the exhaust pipe. I worked with pipeline welders a few years ago. They were all diesel machines sitting in the back of the truck. A couple of them forgot to cover their exhaust pipes. The machines had problems after that. The welders said they "dusted their engines".
Basically they had dirt and grime from the highway get into their diesel motors from the exhaust pipe ruining the motor. If the motor is running however, it is not an issue.
/ Do You Cover Your Vertical Exhaust Stack Tip While Trailering? #20
This is strictly my opinion.
Wive's tale. As we Missourians say.
No way, no how that vacuum or air pressure is gonna spin the turbo enough to ruin the bearings. Remember, there's no load, even if it would be possible to spin it, which it is not.
I live along Interstate 35 hiway in Northern Missouri. If I travel the Interstate it is very common to see new JD equipment being hauled South from their plant in Iowa. None of them, regardless of type of equipment, i.e., Backhoe, Grader Dozer, Skid Steer, CTL, etc., have their exhaust pipes covered. NONE OF THEM. Graders are 99% hauled backwards with their huge exhaust pipe pointing forward. Not covered.....
Makes for a great discussion though, with plenty of experts. :)
2025 Kivel Quick Hitch Skid Steer Attachment (A61572)
2025 Kivel Quick...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Farmall Cub Tractor (A62613)
Farmall Cub...
2015 CATERPILLAR 299D2 SKID STEER (A64279)
2015 CATERPILLAR...
2002 John Deere 544H Articulated Wheel Loader (A61572)
2002 John Deere...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
