Sorry, I haven't read every page in this thread, it's become quite large. But to the OP, if you still have the original question in mind: I built a
grapple to go on the bucket of my
L3301. Just a single lid. I'm still trying to find time to do a write-up on it (and several others). Its not pretty by any means, but its very strong. Stronger than I thought actually. The other day I needed to move a propane tank. I'm not sure exactly how big or how many gallons, I would guess nearly as long as the tractor. Definitely longer than the bucket is wide. Probably wasn't the best thing to do, but I scooped the bucket under one end and clamped the
grapple down onto it and lifted it up and away I went. I was able to drive across my 10 acres, bumps, ruts and all with little issue. I have often wondered if I would like a double lid
grapple. But I don't think that would have worked here. The seam between them would have been right where the tank was, putting quite a bit of sideways stress on both lids.
This applies allot of the time with larger stumps and whatnot. But then there are other times that I scoop things, such as uneven loads of large rocks or something, that I wish I had 2 lids to hold the load in better. In a perfect world you would have both. Personally I think There are always going to be instances where the one that you don't have would seem to do the task at hand a little bit better, no matter which one you go with. But all-in-all, I'm quite happy with the single lid that I build.
