L Series owners
/ L Series owners #81
Welcome to the asylum. You'll find a wealth of info on TBN about the L series Kubotas. Every time mine breaks I find lots of folks that have had the same problem and many times they have provided good advise on how to fix it.
I think a lot of people, myself included, purchase an L thinking they can use them to clear land, dig up stumps, move heavy rocks, and do big grading jobs. My neighbor says a CUT is great for maintaining stuff, but you need a real backhoe to build stuff. I learned the first time I tried to pull out a 2" oak that the wheels would spin and the tractor would just sit there. I also learned that carrying many loads of soil and gravel on a side hill is a good way to break the castings on the front hubs and loader mounts. My L3240 HST has almost 2000 hours on it now, and it came to me with 1300 hours. The previous owner learned that using it like a bulldozer will warp the bottom lip of the bucket and rip the top hydraulic cylinder mounts right off the LA724 FEL. And deferring grease will wear out the pivot bushings (an issue I'm currently trying to resolve). Several folks here have had the propeller shaft seals fail in their transmissions, and learned all about splitting the tractor as a result. I can tell you, that's a real fun job in a freezing garage in December. It's even more fun when you're headed down a steep hill with a bucket full of rock and the splines in the front coupling of that same propeller shaft strip. All of a sudden you're gaining speed with no brakes (they're only on the back wheels which are unweighted by the heavy load up front), but if you're quick on your feet maybe you'll realize you can drop the bucket and avoid an abrupt stop when you hit that big oak at the bottom. I've done a fair amount of trenching with a little Nardi backhoe on the back, but even a bread box sized rock can take a long time to dig around and out. I've used an auger to dig a few fence post holes, but usually end up with a spud bar when I hit rock. Filters and hydraulic oil seem overly expensive at the dealer, and now that Ronnie's TractorSmart site lost access to Kubota parts, there doesn't seem to be any alternative.
All negatives aside, I've gotten a LOT of work done with this little tractor, a heck of a lot more than I could have with a wheelbarrow, shovel, and push mower. My little slice of heaven features hillsides so steep they're difficult to walk, but in 4WD the tractor will go right up, happily running a 60" Bush Hog all the way. The 72" box blade won't cut down through the limestone rock that underlies my Jeep trail driveway, but it does a fine job spreading gravel and evening out ruts. It's also handy for chaining up logs to skid them out of brush piles, and the 4in1 on the FEL makes a good saw buck in a pinch. It's also good for grabbing the giant poison oak trees we have around here and pulling them out by the roots. All my firewood is on pallets, and the L has no trouble moving almost half a cord of oak in one go. I've moved a lot of mulch and top soil, and the compact size has let me get into places a bigger tractor just wouldn't go. I've mixed a fair amount of concrete in the bucket, more than would ever fit in a wheelbarrow, and I have yet to tip the bucket over. Last summer I terraced a notch in my hillside below the house and moved an empty 385 gallon propane tank into it. The trench to the new location was dug by the Nardi, and the pallet forks made short work of bringing the retaining wall blocks down the steep hillside.
The same neighbor that has the backhoe also has a similarly sized Deere CUT, and comparing the two side by side shows that the Deere is built to last with heavier castings, larger pins, and thicker plate. Were I to do it again and knowing what I know now, I'd probably end up with something green or yellow instead of orange, something significantly bigger, and rather than trying to save money by inheriting somebody's else's problems, I'd buy new.
As with most things in life, your mileage may vary.
/ L Series owners #82
Welcome to the asylum. You'll find a wealth of info on TBN about the L series Kubotas. Every time mine breaks I find lots of folks that have had the same problem and many times they have provided good advise on how to fix it. I think a lot of people, myself included, purchase an L thinking they can use them to clear land, dig up stumps, move heavy rocks, and do big grading jobs. My neighbor says a CUT is great for maintaining stuff, but you need a real backhoe to build stuff. I learned the first time I tried to pull out a 2" oak that the wheels would spin and the tractor would just sit there. I also learned that carrying many loads of soil and gravel on a side hill is a good way to break the castings on the front hubs and loader mounts. My L3240 HST has almost 2000 hours on it now, and it came to me with 1300 hours. The previous owner learned that using it like a bulldozer will warp the bottom lip of the bucket and rip the top hydraulic cylinder mounts right off the LA724 FEL. And deferring grease will wear out the pivot bushings (an issue I'm currently trying to resolve). Several folks here have had the propeller shaft seals fail in their transmissions, and learned all about splitting the tractor as a result. I can tell you, that's a real fun job in a freezing garage in December. It's even more fun when you're headed down a steep hill with a bucket full of rock and the splines in the front coupling of that same propeller shaft strip. All of a sudden you're gaining speed with no brakes (they're only on the back wheels which are unweighted by the heavy load up front), but if you're quick on your feet maybe you'll realize you can drop the bucket and avoid an abrupt stop when you hit that big oak at the bottom. I've done a fair amount of trenching with a little Nardi backhoe on the back, but even a bread box sized rock can take a long time to dig around and out. I've used an auger to dig a few fence post holes, but usually end up with a spud bar when I hit rock. Filters and hydraulic oil seem overly expensive at the dealer, and now that Ronnie's TractorSmart site lost access to Kubota parts, there doesn't seem to be any alternative. All negatives aside, I've gotten a LOT of work done with this little tractor, a heck of a lot more than I could have with a wheelbarrow, shovel, and push mower. My little slice of heaven features hillsides so steep they're difficult to walk, but in 4WD the tractor will go right up, happily running a 60" Bush Hog all the way. The 72" box blade won't cut down through the limestone rock that underlies my Jeep trail driveway, but it does a fine job spreading gravel and evening out ruts. It's also handy for chaining up logs to skid them out of brush piles, and the 4in1 on the FEL makes a good saw buck in a pinch. It's also good for grabbing the giant poison oak trees we have around here and pulling them out by the roots. All my firewood is on pallets, and the L has no trouble moving almost half a cord of oak in one go. I've moved a lot of mulch and top soil, and the compact size has let me get into places a bigger tractor just wouldn't go. I've mixed a fair amount of concrete in the bucket, more than would ever fit in a wheelbarrow, and I have yet to tip the bucket over. Last summer I terraced a notch in my hillside below the house and moved an empty 385 gallon propane tank into it. The trench to the new location was dug by the Nardi, and the pallet forks made short work of bringing the retaining wall blocks down the steep hillside. The same neighbor that has the backhoe also has a similarly sized Deere CUT, and comparing the two side by side shows that the Deere is built to last with heavier castings, larger pins, and thicker plate. Were I to do it again and knowing what I know now, I'd probably end up with something green or yellow instead of orange, something significantly bigger, and rather than trying to save money by inheriting somebody's else's problems, I'd buy new. As with most things in life, your mileage may vary.
Yes they are not earthmoving equipment. They are FARM tractors.
/ L Series owners #83
Please tell me you havent took the bait? Aside from his excellent fabrication skills, The Fred is an enthusiastic angler. It would seem his live-well overfloweth.
His obvious sarcastic points regarding his "awful" farm tractor are missed by many newbies. For his size machine... All brands will have similar performance characteristics.
/ L Series owners #84
Are you saying that a John Deere in the same size/class as your Grand L 3240 has heavier castings, larger pins pins and thicker plating ??
I'm curious what model you are comparing, because that hasn't been my observations when looking at Kubota vs Deere.
/ L Series owners #86
Are you saying that a John Deere in the same size/class as your Grand L 3240 has heavier castings, larger pins pins and thicker plating ?? I'm curious what model you are comparing, because that hasn't been my observations when looking at Kubota vs Deere.
Yeah me too. The small deeres are built like large lawn tractors with their plastic hoods and cheapy controls.
/ L Series owners #87
My L4600 with 46 hours new in June 2014 decided to quit moving after unloading it to do a beach tilling job called dealer and they said they would come get it but would take a few days and would be 2 dollars a mile.
Not wanting to leave it on a beach over the weekend took a friend and after about an hour we got it loaded. Took to dealer 60 miles away explained to him I was not real happy and asked to set up meeting with Kubota rep. they said they would try and get meeting. on my way back home dealer called and said Kubota agreed to deliver it back home free of charge. Well as my Wife says Time Will Tell. Also on day it quit I received my 60 inch wicked root grapple and I can't use it.:confused3:
/ L Series owners #88
Seems most people here own a BX series Kubota.
Any L series owners here? I'm a first time tractor owner with a nearly new(13 hours when I bought it)L3200. Any advice or suggestions?
I'm also a first time tractor owner and bought an L-3200 with the BH 77 backhoe and mechanical thumb. Will be doing lots of french drain projects, and putting a culvert under my driveway, this spring/summer once the ground dries out. Removed several alder trees and stumps last summer. have about 44hrs so far. Have removed the backhoe once, then put it back on to see how tricky it was. Being a tractor noobie, it has taken seat time and repetition to get better with the backhoe and the FEL...
/ L Series owners #89
My new L3400 with FEL was delivered in 2007. It doesn't have many hours on it (130?) due to overseas deployments. In that time I've had to replace the hydraulic oil sight glass, two small hoses on the loader, the large hose under the right foot, and the ignition switch. Had to replace one of the turnbuckles on the three point hitch but that was my fault. Also unfroze the seat suspension. Fortunately all repairs were done onsite without having to get the dealer involved. What is amazing is the original battery lasted seven years. Other than that, a dependable tractor that's found use in many applications including hauling deer in the bucket.
/ L Series owners #90
How involved was changing out that sight glass? I need to do that when I change my fluid filter and wondered if you had any tips you could share?
Thanks in advance,
Clay
/ L Series owners #91
Thanks in advance,
Clay
/ L Series owners #92
L4600 here. Has exceeded all my expectations. Been worked like a red-headed step child.
/ L Series owners #93
Thanks in advance,
Clay
Very easy. First drive up on some ramps or blocks so the left side of the tractor is high. Now you won't lose any fluid. Then just unscrew it and put the new one in.
If your changing the fluid then it is even easier. If I remember right, it is a 3/4" pipe thread.
/ L Series owners #94
It's easy to unscrew and put in a new one. I tilted my tractor on a hill side so the fluid was below the sight glass...
Edit: ^^^ ya, what he said :D
/ L Series owners #95
So if I may ask, what causes the need to replace the sight glass?
/ L Series owners #96
Since I posted about my "new" L3400, I've added some rear wheel spacers ( I also added chains for winter plowing, and don't like to crowd the fenders) and that seems to make it at least feel a lot more "planted" and stable. I guess it really would be. It has started right up after sitting in a single digit barn for days, a little black smoke to begin with, but soon clears and off I go. I was going to install a block heater, but the dealer said not to bother, and he was correct.
/ L Series owners #97
Thanks in advance,
Clay
Unless it's actually broken, it just needs to be re-installed with a bead of fresh silicone sealer. Mine began leaking several years ago but hasn't leaked since re-mounting it. 10 minute fix.
/ L Series owners #98
How hard is the sight glass to unscrew? Doesn't seem there's much to grip.
/ L Series owners #99
The older ones tend to crack. The new gray ones are supposed to be better.
/ L Series owners #100
Chilly807,
35 psi sounds good. Going to have to wait for some snow to melt as the L3800 is trapped in the barn. Should have kept up with the snow. :eek: The bx2200 handles everything around the house. :thumbsup:
Thanks
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
40' 6 Door Shipping Container (A68183)
40' 6 Door...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
2006 MACK CHN613 DAYCAB (A67714)
2006 MACK CHN613...
