Snow Equipment Buying/Pricing Best Blower for a 75HP Tractor?
   / Best Blower for a 75HP Tractor? #12
why go only one direction when you can go both.
   / Best Blower for a 75HP Tractor? #13
If I had a 75hp tractor with 1/2 mile, I would smile to do it with an inverted snowblower!
My pick:
Pronovost inverted snowblower 86" width model P-860 IV
Pronovost- Inverted Snowblower
http://www.pronovost.qc.ca/pdf/Pronovost - Snowblowers.pdfView attachment 406724View attachment 406725View attachment 406726
Hello Phil,
Thanks for mentioning the PXPL XPRO units, you beat me to it.
The PXPL units are are rear mounts that are capable of pulling snow
out of closed tight spaces that would not allow the operator to cast
the snow away safely. There are a bunch of videos on you tube
showing how well they work.
All he would need to do is add the rear work light option and the extended
chute to eliminate any of the blow back from wind blowing the wrong way.
The snow would be cast up and away from the tractor and the the snow would
not be able coat the rear window.
   / Best Blower for a 75HP Tractor? #14
Hello Phil,
Phil had the links for the inverted. You will need to use the links I posted for the PXPL.
   / Best Blower for a 75HP Tractor? #15
Whoopsy!
My apologies cford36. We both know good snow casters
when we see them so we have that in common :)
   / Best Blower for a 75HP Tractor? #16
I'd suggest the Normand Inverted (pull style) blower. They have a Hardox steel frame that is stronger than the other brands. I know several guys using them on long driveways, and even more guys running them commercially.
Also just so everyone knows, the PXPL mentioned above is not a pull style blower, it only blows while moving in reverse. What it has is a pull back blade for getting up close to garage doors. It's a nice blower, but it's almost 2x the cost of an inverted blower. It's really more suited for a bi-directional tractor like a TV145. I know several contractors that used to use the PXPL that have switched to inverted blowers because they are easier to use, faster, cost less to buy, cost less to own, and don't need an expensive bi-directional tractor to use properly.
Here are a couple videos of my tractors with Normand inverted blowers.
http://youtu.be/wW6SEg19YXY
http://youtu.be/LibDG4NjZlw
http://youtu.be/UxN8OSuDLg4
And here are a few others by some of my friends:
http://youtu.be/SUd3RpA7ra8
http://youtu.be/4Kr4TN2EdwE
http://youtu.be/-czQLKZp5-U
That last one is a good one. Enjoy :)
   / Best Blower for a 75HP Tractor? #17
   / Best Blower for a 75HP Tractor? #18
Hey.... i know that guy in the last video! That driveway had LOT of snow on it...
   / Best Blower for a 75HP Tractor? #19
I would cast my vote for a Normand as well. VERY impressed with our Normand 92-280. Well built, durable and awesome to watch it work.
Image is the guy to get a hold of in the states, for help with selecting the right size and options.
large capacity skid steer bucket (A56857)
large capacity...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
2017 John Deere 6105E (A57148)
2017 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
