Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,881
So do you use yours commercially? seems from your posts you probably do, which means you put lots of hours on yours. Me... mine would most likely be used a few times a year on my own place (unless I found a mowing job or something, I'm kind of retired with some time on my hands ). My point I guess is if you use yours commercially and its held up this well, an occaisional use one might last forever.. Also your name is Island Tractor (yes I saw your location) but the two guys that posted after you were both from Hawaii.. how weird is that?:D
I don't use mine "commercially" but I do a lot of volunteer cutting at a conservancy farm and on other conservancy land. I actually don't use the flail on my own property. Too hard to maneuver the DK40 around bushes etc or get close to the house.
Yes the island connection of posters is a bit odd. Even more is that I used to live in Hawaii and know the areas where the several TBN owners live. Even weirder is that 3/3 of the TBNers in Hawaii I know of all have flails!
/ Let's talk flail mowers #1,882
Any idea what this would be worth?
I believe it's the 90" model.
It's on a local auction.
It's a new holland 918H
/ Let's talk flail mowers #1,883
So I finally got a hold of the guy with the 77" alamo flail mower, SHD88. It has 184 blades and he says he thinks its a finish type mower, I'm wondering how it would do on brush??
Opinions?
/ Let's talk flail mowers #1,884
Opinions?
My Value Leader has the "grass blades" and all I use it in is brush. It takes a couple passes to mulch up really thick stuff, but it does a nice job. Somebody on here who has used both types can give you a real comparison, but the knives definitely work in the brush for me.
/ Let's talk flail mowers #1,885
Thanks.. and like you said, hope to hear from somebody who has used both..
/ Let's talk flail mowers #1,886
I use.the fine cut blades on my Mott, to cut old cane prunings in my vineyard, as well as mowing the cover crop planted between rows. It chops up the cuttings finer than the spade bits on my other flail, a Value leader, which I use in the woods.
Very happy with the results, blades don't seem to wear or break any more than usual.
Each cutting/mowing in the vineyard is about 14,000 lineal feet of constant heavy woody cane cutting. I think that Alamo is a quality machine, and you will not regret it if that's the way you choose to go.
/ Let's talk flail mowers #1,887
I would be a bit cautious using fine cut blades/rotor for true bush hogging. No question it will work on cane prunings, corn stalks and even small branches or saplings, but true bush hogging involves cutting and hitting things that you might not have intended to. Hitting a stump or rock with a rough cut mower is par for the course and most rough cut knives actually swivel on a clevis so that there are two levels of flexibility to allow the knives to "get out of the way" once striking an uncuttable object. The clevis itself can move backwards and the knife can both move backwards and sideways. A finish mower rotor typically has the blades attach directly to the rotor and there is very little if any lateral movement possible. That plus the fact that finish knives are generally thinner makes me wary of using a finish flail for bush hogging. I wouldn't hesitate to use a finish flail to cut a known pasture with high grass and a few smaller branches or saplings but I'd be loath to back a finish mower into a thick area with ??? under the visible layer of grass etc.
/ Let's talk flail mowers #1,888
My concern is the number of blades.. the Caroni has 56, not sure how many on the Value leader, but the Alamo has 184... that seems like a HUGE difference!
/ Let's talk flail mowers #1,889
That is simply because it is a fine cut. Fine cuts always have more knives. It insures a perfectly smooth cut. A rough cut rotor is not optimized to cut every last blade of grass cleanly and typically uses heavier but less numerous blades. It really isn't the number of blades that is as important but rather the gauge, weight and mounting system.
/ Let's talk flail mowers #1,890
Here is the kind of stuff I'll be cutting.. some worse..
/ Let's talk flail mowers #1,893
So long as you walk that before mowing, I wouldn't hesitate to use a "finish" flail to clean it up.
/ Let's talk flail mowers #1,894
I have a lot of stumps and downed trees on my property. I've hit a lot of them with the flail. The knives are on swinging hangers and they're also free to rotate on the hangers themselves, so they don't seem to mind the stuff I've run them into. When I hit a big rock it will make a big noise, but so far it doesn't look like I've damaged anything under there.
/ Let's talk flail mowers #1,895
I'm trying to determine which machine he has, he posted a SHD88, but that has 216 knives (108 pair) and is 96 wide.. The SHD74 has 184 knives (92 pair) and is 82" wide. My concern now is weight of these heavy duty guys.. the 88 is 1035lbs, and the 74 is 930lbs.. my tractor manual says 770 lbs for a mower and 880 for a box blade, I'm wondering now if its getting to heavy.. dont want to tear up the tractor.
/ Let's talk flail mowers #1,896
Your L-series Kubota should be able to lift more than a ton at the 3PH. Those flails weigh less than half what your 3PH can easily lift. Any idea why the manual says to get such light implements?
/ Let's talk flail mowers #1,897
Island a Tractor is correct. Just remember that the basic blade design on those units are for finish cutting. Not only will you notice the knives are thinner but they are also longer which makes them more likely to bend if tested. Once you bend these they can't be straightened as they will bend even easier the next time. Blades of this sort should handle 1" saplings as pictured but if you plan on doing much more I would opt for knives designed for the task.
/ Let's talk flail mowers #1,898
I have no idea why they list the implements like that.. Tractor Data lists the 3ph lifting capacity at 3,750 lbs!
/ Let's talk flail mowers #1,899
Finally got to the end of this. Lots of information. Didn't see anything on Tiger mowers. Thinking about going to look at one. I think it's the 96" extreme duty model. Anyone have any information these. Would use it for mowing some pastures. Thanks in advance.
/ Let's talk flail mowers #1,900
Tiger mowers are very high quality and USA made. They are a subsidiary of Alamo. Don't forget to bring your wallet... LOL
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
1 PALLET OF JACK & MISC TRUCK PARTS (A66091)
1 PALLET OF JACK &...
CAT 963C Cab (A68134)
TRIN  BOTTLE TRAILER (A67714)
TRIN BOTTLE...
