Temperature gauge
/ Temperature gauge #1
winston1
Super Member
gilmer tx
Bobcat CT235
Just installed this gauge on a 1050 John Deere. Equus 6262 - Water Temperature Gauge | O'Reilly Auto Parts Although the on line information does not state this, it comes with adapters, one is the m16-1.5 adapter required on all these grey market Yanmars. Several wires to do on it although it comes with some terminal spades it does not include wire. Takes a 2" hole for installation. Includes illumination light.
/ Temperature gauge #4
looks real good there Winston, I plan to add a temp ga to mine, may have to "borrow" the install location from you !!!
/ Temperature gauge #5
Is the JD1050 yours or someone you know?
It's basically a YM4300. Those YM4300 are popular as grays in other countries like Australia, Germany, western Europe areas and Russia. Far and few have been here in the states as YM4300. I had contact Fredricks if they have access to the YM4300. They stated only one has ever made it over here in the years they have been doing grays restorations.
/ Temperature gauge
Just bought it a month ago. To cheap to pass up. 4 wheel drive, power steering, John Deere 75 loader for $4000. to get it in good working order. Probably sell it or my Yanmar later this spring when I decide for sure which one I want to keep.
/ Temperature gauge #7
That is one great deal. $4K for a machine already equipped with a good dependable strong motor. Did it come with a cab or not? There are cabs for it.
/ Temperature gauge
No cab, came with a metal canopy which I have removed. A lot of my work is in the woods and under trees. Can't deal with something sticking up very high. will put it back on if I sell.
/ Temperature gauge #9
If you lived within an hour drive, I would have made you an offer for the canopy. :tractor: :cloud9:
/ Temperature gauge #10
Winston, were you able to splice into the stock sensor wire or was there a new sensor that goes with the gauge and if thats the case, did you need an adapted to make that fit or was it the correct size to screw into the stock sensor location? And I AM GUESSING but since there is a backlit gauge, was that another wire going to the ignition?
Have you installed an oil pressure gauge or is that necessary at all? And I am guessing that requires a big mod in tapping the block.
Thanks Dave
/ Temperature gauge
The gauge requires it's own sensor. The correct sensor and adapter is included in the kit. Yes, you would need to splice into a dash light wire to illuminate. I cut the wire going into the old warning light and used that wire from the new sensor to the new gauge.
Many people prefer an oil pressure gauge over the warning light. I prefer the light. I am much more likely to see a light come on than to see a gauge drop pressure. I do regularly check to make sure my warning light is working. You can install a pressure gauge that reads off and elecrical current. Just requires its own sensor. Your threads are 1/8"bpt, 1 thread per inch different than npt.
/ Temperature gauge #12
I have a dumb question. Where are the fuse panels for these rigs? There is a removable panel under the gauges on mine, screws are rusted shut. I have no shop lights yet so Im using a flashlight in the now dark shop trying to check fuses.
RUMBLON
/ Temperature gauge
/ Temperature gauge #14
You may have a old fuse panel. Old Fuse Links maybe wire looking on a Flat pane "no cover". Just to the left under the dash. The are probably burnt just like a Glass fuse. The System is simple. Temp. Oil. and Charge. Ground out the wire and the light on the dash will come on. That tells you your Circuit is working and probably your gauge is to. Turn the key on and Oil/AC. Charge will come on. Crank it and they should go out. Get it working then I would add Gauges if need be. Here's a Diagram of a Ym2000. It's not your model tractor but it's basically the same. Crank it up and Oil/charge light goes out then your good. Ground the water Temp Wire out and it should come on. Hope that's right it's early for me!
/ Temperature gauge #15
Thanks for the replies. I thought I REMOVED THE FUSE BOX ? As I did find it. But the pic tells me a lot as it shows me the fuse sizes. Mine has four fuses and they are all huge amp fuses, which tells me they either had issues with then or were just out of fuses. I have zero lights on in my dash and nothing works, horn, headlamps ect. Since I am used to cars/ trucks I am used to a HOT leads coming off to a fused link off of the positive. This has a hot battery cable that goes directly to the starter solenoid and then from there the harness goes behind the dash are. I have five rusted screws holding that metal plate on under the dash/ steering wheel so I WILL remove that. My main issue is my shop is not done, just enclosed and I am waiting to add another sub panel to give me more lighting and its cloudy cold and dark. so I will have to wait. so I sprayed all the leads and screws with WD40 so as to be able to get it all apart. If all else fail I can wire a temp gauge in from scratch using all new wiring. Thats almost easier for me. Once I have some light, I will use my test light and start tracing power.
/ Temperature gauge #16
I managed to clean up the connections on the fuse box and now I have power to my OIL and CHARGING lights. This was the far left or #1 FUSE in the box and it also fixed my horn, which now works.
I have a TEMP LIGHT but I also have a TEMP AND FUEL GAUGE, neither of which work. I have NO POWER coming from the connector that comes out of the dash to my fuel sending unit.
I have shown a picture of the fuse box. The fuses are listed 1-4 from left to right.
#1: fixed my two working dash warning light OIL and CHARGING.
#2 IS UNKNOWN
#3 IS UNKNOWN
#4: LIGHTS.
Does anyone know what #2 and #3 source?
Also, I am trying to work on this dash from under the dash and the throttle arm goes through it and wont allow the dash to pull forward.
My turn signal is SOLID and wont turn either direction but its the least important item.
Looks like fender lights are pretty corroded and I see they sell them at HOYE. I will need these and a turn signal switch if I decide it needs one.
If I knew what the #2 and #3 fuses were suppose to source I could probably work around other issues. If one of them is suppose to source the TEMP gauge and I cant get it working then I can use the fuse block and add new wiring and a new gauge that is more accurate.
I have a REAR fender light question. When checking HOYE they well one with a single gree wire with the yellow stripe. The broken wires that I have that go to the rear are a HOT RED and two GREENS. Do these rear fenders take a GREEN and a RED or just the GREEN and than ground on the fender like a trailer light?
FUSE BOX
TEMP FUEL GAUGE
BROKEN WIRES
WARNING LIGHTS
/ Temperature gauge
Looks like one middle fuse goes to the horn and regulator,other goes to the turn signals.
Pull the wire off the temperature sensor and with the key on touch it to ground and see if the gauge moves. If so, the sender is probably bad.
Schematic shows only one wire going to fender lights, they have to ground to the fender. Most likely the green wires going back there.
Hot red going to rear is probably for a work light.
/ Temperature gauge #18
would the regulator manage the OIL and CHARGE WARNING LIGHTS? My #1 fuse manages those and the HORN.
/ Temperature gauge #19
and YES--When I remove the TEMP GAUGE sensor wire (yellow) and ground it with mt test light to the battery it moves.
So that said, my plan is to add two gauges if possible. The TEMP gauge which winston1 has done and I want an OIL PRESSURE gauge. Can I install an oil pressure gauge to this engine without taping the block ect? HAS ANYONE DONE THIS?
And the GREEN wires with the yellow stripe that match the fender light wires are not hot when I have the lights on? Just the RED is hot.
/ Temperature gauge #20
Winston, since the fuse box was talked about, do you know the fuse box positions for a YM2500/YM2610 maybe?
Also, I've booked marked your thread for the gauge too. It should fit my gauge panel too.
RUMBLON, You horn switch cover looks in bad shape. I've looked around the web for a replacement for mine, but Hoye, Fredricks and other places no longer offer them. I did find something really close in comparison being a marine horn button or a Club Cart horn button. It costs more than a new shiny penny though.
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
BUSHHOG 286 - 6' ROTARY MOWER (A64277)
BUSHHOG 286 - 6'...
2007 International Flatbed Dump (A62613)
2007 International...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
