where to buy gearbox
/ where to buy gearbox #1
pv31
ontario
mf 50hp
Hey
I'm looking for a place where I can buy gearboxes, roller chains, sprockets, etc,
I'm designing an inter row tiller similar to the brands multivator, badalini, maschio. I'm looking for a t type gearbox capable of at least 60hp. If you google the brands I listed, there are some interesting videos on youtube and you'll know what I'm talking about.
The only places google shows are suppliers from china on alibaba.com. Agrisupply has one, but it doesn't list any specs and surplus center isn't much help either for that type of gearbox.
Any help is greatly appreciated. Thanks
/ where to buy gearbox #2
:welcome:
To the forum. I am sure someone will have some info for you.
/ where to buy gearbox #4
Check out surpluscenter.com.
/ where to buy gearbox #5
Also McMaster.com may have something
those suggestions have chains, sprockets etc, but they don't have the particular gearbox i'm looking for. any other suggestions where i could find a greater variety of gearboxes? any suppliers in ontario canada or new york i could talk to? thanks
/ where to buy gearbox #7
What kind of gear box do you want? Maybe cheaper to modify a used rototiller.
/ where to buy gearbox #10
the Curtis one on surplus has the right design but has the side shafts rotating opposite to each other. my preference would be t style, 60+ hp, 2 to 1 reduction. where do the equipment manufacturers get these kinds of things from?
thanks once again, really appreciate the help from everyone
/ where to buy gearbox #12
I think the side shaft rotating opposite each other is when you face the shaft output end. That would make both side shafts rotate the same when looking from the input shaft.
Could you use a RA gear box above your driveline shaft and use chains with sprockets for the 2 to 1 reduction?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 5090GN (A60462)
John Deere 5090GN...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2014 Ford Explorer SUV (A61569)
2014 Ford Explorer...
WHISPERWATT DIESEL POWERED AC GENERATOR (A60736)
WHISPERWATT DIESEL...
