Welding and concrete?
/ Welding and concrete? #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
A while back I cut down some posts at work. They are 6" round tubing filled with concrete- not sure if it's 1/4" or 3/16", I'll have to check. I cut them flush with the concrete floor with a torch and boy was there a lot of popping. Anyway, I want to weld some together but not sure if it is a good idea. I would plan to weld some angle to them for 3 point brackets for counterweight.
I would have to imagine that there is still some sort of moisture in them and would possibly build pressure inside. Since they are round I don't anticipate a lot of contact area, so at most I'm thinking maybe 3/4" long welds. Would enough heat build up from short welds like that? Do you think they will blow up in my face? Am I worrying too much?
/ Welding and concrete? #2
Hmmm.... an interesting question. My guess... and yes it is worth :2cents:, but how much more I don't know. You should be fine as I would expect the metal tube to expand more than the concrete with the introduction of heat. This is based on their relative coefficients of thermal expansion. The steel 'alpha' is about 50% greater than that of concrete.
From what I understand, the problem with concrete and heat is the moisture contained in it will become steam.
/ Welding and concrete? #4
This is probably an excellent question for Shield Arc! My gut says the pipe, along with expanding, will also dissipate the heat much more than the cement so the amount of water that would get 'superheated' and pressurized will not be enough volume to burst it if you are welding short lengths... but I wouldn't take my guess as gospel. I am sure you would rather hear from someone with experience. I will try to shut and and just tag along here.
You are probably right, it's kinda what I was thinking but I still had my concerns.
/ Welding and concrete? #6
:laughing::laughing::laughing::laughing::laughing:WOW! This brings back memories! I remember this happening to me on my first job right out of welding school. I cut something with a torch on a concrete curb. Luckily I used my welding hood instead of burning goggles. When the concrete blew up in my face and hit the hood I couldn't imagine what happened.:shocked::shocked:
The heat from the torch or welding is just heating the water trapped in the concrete, and it will blow out! I'd say just protect yourself the best you can. And don't let anyone in the area while your working on this.
/ Welding and concrete? #7
As long as the ends of the pipe are open as in not a welded steel cap on both ends, any steam generated is going to be able to vent out between the pipe wall and the concrete. I wouldn't worry about it. IF you are going to weld some of these back together (concrete exposed near the weld), you may want to chip out the concrete a bit from the weld area. I don't think it will "blowup" but it could send some popping concrete into your weld puddle that would contaminate it and make it very weak.
By the way, all aggregate (rocks) will pop like that when heated, it doesn't have to be just concrete, so protect yourself when welding or cutting around gravel or concrete when heat could transfer into these objects.
/ Welding and concrete? #8
I moved some 6" pipes one time, which were concrete filled and not capped, to new locations, and welded them on top of new pipes that were sticking out of the concrete 2". It was interesting to hear all of the popping going on inside the pipe. The concrete appeared to be dry, but as you might expect it had plenty of moisture, and there were lots of explosions going on inside while I was welding. Considering that aggregate was exploding inside, I *sure* wouldn't want to be welding on something that had exposed concrete on it. What I was doing worked, but sounded plenty scary.
/ Welding and concrete? #9
When this bridge project across Lake Washington was just about completed we had to remove the 24-inch pipe filled with concrete under every pier table next to the concrete columns. I got everything set up to do it, but got transferred to the Metro tunnel project down town Seattle before the work actually started. The guys used these thermal lance to cut the pipe.
https://www.youtube.com/watch?v=EV4r7OKkXmU
/ Welding and concrete? #10
I remember in Hi school shop someone spilling molten metal for a casting project and metal and concrete splattering everywhere! It is the moisture in the concrete or its crystalline structure that causes it to spray both crete and metal at you!
/ Welding and concrete? #11
Drill several small holes (1/8?) around the weld area to vent any pressure. After cooling, quickly weld them closed, or fill with epoxy.
Bruce
/ Welding and concrete? #12
Bruce
This seems like a good solution to be extra safe if you are completely closing off the concrete.
/ Welding and concrete? #13
That brought back memories of when I worked for Calument Concrete Cutting, back in 1960!
One of the most unusual jobs we did, was cutting and removing a blast furnace at Inland Steel. I got to cut (melt) the fire brick with the iron powder oxygen lance. I have been inside an open hearth blast furnace and lived to tell about it!
/ Welding and concrete? #14
No
No
Yes :laughing:
All the action is on the outside side of the pipe, concrete is on the inside. I predict that you can weld it as you wish. Even 1+ inch long welds, and NOTHING will happen.
No, the ends are not capped- wide open. I'm not welding them together end to end, just going to lay about 4 of them next to each other and weld angle across them, then flip over and weld angle across again, then stand up and put pins in the angle for 3 point arms.
Thanks guys for putting my mind at ease. This all pretty much agrees with my original thinking, I just started having doubts and figured I'd ask before doing something stupid.
I see people ask stuff on here with similar situations and I feel some people have been saved from some pretty severe injuries or close calls by asking first, so it seems the smart thing to do, often there are things we overlook. Thanks again.
/ Welding and concrete? #16
No, the ends are not capped- wide open. I'm not welding them together end to end, just going to lay about 4 of them next to each other and weld angle across them, then flip over and weld angle across again, then stand up and put pins in the angle for 3 point arms. Thanks guys for putting my mind at ease. This all pretty much agrees with my original thinking, I just started having doubts and figured I'd ask before doing something stupid. I see people ask stuff on here with similar situations and I feel some people have been saved from some pretty severe injuries or close calls by asking first, so it seems the smart thing to do, often there are things we overlook. Thanks again.
I thought it was a great question. It is stupid when you don't ask on something you have never done before. It's also great to get several opinions and tips along the way. Let's see the finished project! It's the least you can do for us now. Ha ha.
I'll try to get to it this weekend. Right now they are laying out on the other side of some decent snow drifts. It's going to take some ambition to retrieve them! Although I've nearly gotten the tractor stuck in the snow a few times already, so I do have some incentive. Hopefully this ballast will do the trick.
/ Welding and concrete? #18
When I built that log splitter for my brother-n-law, I also built him a counterweight something like you have planned. I took a piece of 16-inch diameter fender pile that came out of the local Navy shipyard. Welded the ears on it. I had planed for him to stand it up on one end on some visqueen and fill it with concrete. I understand he hasn't done that yet.:rolleyes:
Mike for what you have planned I wouldn't think twice about doing it. :thumbsup:
/ Welding and concrete? #19
Especially since they were cut with a torch they won't seal pressure until the weld is just about complete. IE won't mate tight anyway. I agree you'll be fine.
Jim
Well when I went out to get them a few days ago they were frozen to the ground. We've had a warm weekend so I was able to get them. Now I just have to plan how to build this thing! They are about 300# each so manageable one at a time but once I start welding them together it won't be so easy to move them around. Wish I had a gantry!
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
2086 (A65055)
2086 (A65055)
X (A68191)
X (A68191)
2015 John Deere CX15 (A64126)
2015 John Deere...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
