Using a rear remote to power the trailer hydraulics would be the easiest way to connect to the tractor. However, a few words of caution. It is IMPORTANT that you activate the remote in the correct direction so high pressure oil is supplied to the inlet of the trailer hydraulics. Return oil from the trailer will flow through the remote valve to tank. Before disconnecting the trailer hydraulics from the tractor, be sure to turn off the tractor, open the remote and cycle the trailer valves to release any trapped pressure. Without the remote valve open, in same direction to power the trailer, there is no return path for the oil to relieve pressure in the trailer hydraulics. If you have something lifted with the trailer, do not try to lower it unless the tractor remote is open. Do not leave the trailer sitting with a load on the hydraulics unless the remote is open as there would be no path to tank for any leak down unless the remote is open. If your remotes are not detented, use a bungee cord to hold the lever. If anything on the trailer, such as the out riggers, drift down when the trailer is sitting idle, then you should strap them up when disconnected from the tractor so you do not build pressure in the return line of the trailer.
