Tire chains on DK35SE with cab
   / Tire chains on DK35SE with cab
I didn't think I was going to have clearance problems on the front but after seeing your picture maybe I need to rethink them.
How much for the spacers? I run the Aquiline talons on my DK35se, and it is extremely tight.. Requires a lot of messing with to get them to clear..I wish I had some spacers.
The spacers are $333.00 :shocked::eek: I think I will try the chains without the spacers first. If I can get them to stay high on the sidewall I think there will be enough room. This would certainly keep me out of the doghouse with the ole lady. :D
   / Tire chains on DK35SE with cab #14
FYI, Bro-Tek has these rear Spacers for $290 is you ever end up needing them...
   / Tire chains on DK35SE with cab #15
Check with Michigan Iron and Equipment, I think they manufacture them for a lot less than that.
Error
Finally got my chains on the rear and yes I had to leave the inside at it's longest setting and tighten the front as tight as possible. They are still VERY close without the wheel spacers. I plowed one storm that way and it does turn the tractor into a tank :)
Because it is so close I didn't want to chance to many storms that way. Any ice building up on the chains and I would scrape for sure. Here is the part from Kioti...
Michigan Iron Works told me they couldn't get them for me? But you can get them here T4125-B58500101 Kioti Spare, Rear Tire but I chose to get them from my local Kioti dealer to save shipping.
Spacing is good now :)
   / Tire chains on DK35SE with cab #17
Ok this may be a dumb question but does that part number contain 2 spacers (one for each wheel) or for the $291 do you have to buy two of them?
While my chains fit. (barely) just like yours did, If you do not maintain tightness perfectly, they hit the ROPS mounting. It would be nice to have the spacers, and at $291 for a set if that is the way they are sold, I would consider it. But at $291 each.. well not so much.
   / Tire chains on DK35SE with cab #18
Next question, is this a kit? does it come with the bolts and nuts needed?
   / Tire chains on DK35SE with cab #19
Everything is included for $290 to complete the install, you get the 2 spacers nuts/bolts, Shipping&Handling
2006 CATERPILLAR D4G LGP CRAWLER DOZER (A52707)
2006 CATERPILLAR...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
UNUSED JCT HYD TRENCHER (A57193)
UNUSED JCT HYD...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2019 Deere 35G (A53317)
2019 Deere 35G...
