Tire chains on DK35SE with cab
/ Tire chains on DK35SE with cab #1
Maineiak
Augusta, Maine
Kioti DK35SE
Has anyone put chains on a DK35SE with a cab? I know people have issues sometimes with clearance so I am trying to figure out if I just need the chains or will I have to have spacers as well. Also any recommendations on the type of chains is welcomed. I am pushing a plow and my dirt driveway is steep and can get icy at times.
/ Tire chains on DK35SE with cab #2
I have these chains on my DK45SE, same as your machine I believe.
DuoGrip Tractor Tire Chains
Just put them on snug and they will slack up with use. I have no problems with clearance and the chains work well in the woods and plowing snow.
/ Tire chains on DK35SE with cab #3
I have DUO chains on my non-cab DK35SE with R4's. The DK35 uses different rims than the DK40's and up. The DK35's rims are non-adjustable and have tight horizontal clearance (about 2") to the ROPS/fender support on the rear and the front axle components on the front. The DUO's on the rear work but I must run with them tightened on the tire and riding above the centre line of the tire. Small 2 link ladders(old truck chains) on the fronts were also a challenge and need to be installed with no slack and riding high on the inside of the tire.
Although the DK35 has the same frame as the larger DK's the tires have a smaller diameter than the DK40 and up. The frame vertical components angle slightly to the inside. The DK's smaller wheel diameter thus places the chains closer to the frame.
If you have R4's you will likely find you need shorter cross links for your chains than the chain vendors recommend. At least that's my experience. The shorter cross links improve clearance by putting the side chains higher on the sidewall.
Rear spacers would easily solve the rear clearance problem. I looked into spacers from a TractorByNet seller, Bro-Tek(Bro-Tek: Tractor Add Ons). I see the website has not improved and it looks like he only sells Kubota equipment and no spacers. But he does sell spacers for the DK35 Kioti. The spacers looked good and I would have purchased them had I not been able to get the chains to work without them.
/ Tire chains on DK35SE with cab #4
GM,
What is that attached to your 3ph ? :confused3: I'm trying to figure out if it is for pulling something VERY heavy, or something else ? ? :confused: Looks cool ! ! :cool2:
Dave
/ Tire chains on DK35SE with cab #5
GM,
Dave
Thats a logging winch.
Thanks for the information guys!! The Kioti dealer nearby here actually responded to an email last night and stated he has the spacers I need in stock and did recommend them or it would be tight like KCO mentioned. To bad tirechains.com do not offer anything but a 4 link chain for the front of my R4 tires (27x10.50x15). It's amazing how very few sites there are that offer chains for all tractor size tires. :mad:
Once again thanks for the responses. :thumbsup:
/ Tire chains on DK35SE with cab #7
How much for the spacers? I run the Aquiline talons on my DK35se, and it is extremely tight.. Requires a lot of messing with to get them to clear..I wish I had some spacers.
That was my last email to him and have not heard back on the price yet. I will let you know when he replies or after I call him tomorrow.
/ Tire chains on DK35SE with cab #9
thanks
/ Tire chains on DK35SE with cab #10
I think the chains TireChains.com or others specify for the 27x10.50x15 will not work on the DK35 with R4's. Here is a link showing my front chains:
http://www.tractorbynet.com/forums/...nly-front-chains-post3135822.html#post3135822
They are small truck chains with the cross links high on the sidewall, and yet have small clearance to the front end components. I was going to order skid steer 2-link square-link ladders for the front. But upon measuring with the old truck chains I had on hand(which were similar in crosschain length) I found they would be too long and interfere with front end components. You also likely want lighter chains with smaller cross hooks for the fronts rather than the heavier DUO's whose cross hooks require more clearance.
Although the suppliers specify chains that fit the tires they don't know if they will work for specific machines.
I didn't think I was going to have clearance problems on the front but after seeing your picture maybe I need to rethink them.
The spacers are $333.00 :shocked::eek: I think I will try the chains without the spacers first. If I can get them to stay high on the sidewall I think there will be enough room. This would certainly keep me out of the doghouse with the ole lady. :D
/ Tire chains on DK35SE with cab #14
FYI, Bro-Tek has these rear Spacers for $290 is you ever end up needing them...
/ Tire chains on DK35SE with cab #15
Check with Michigan Iron and Equipment, I think they manufacture them for a lot less than that.
Error
Finally got my chains on the rear and yes I had to leave the inside at it's longest setting and tighten the front as tight as possible. They are still VERY close without the wheel spacers. I plowed one storm that way and it does turn the tractor into a tank :)
Because it is so close I didn't want to chance to many storms that way. Any ice building up on the chains and I would scrape for sure. Here is the part from Kioti...
Michigan Iron Works told me they couldn't get them for me? But you can get them here T4125-B58500101 Kioti Spare, Rear Tire but I chose to get them from my local Kioti dealer to save shipping.
Spacing is good now :)
/ Tire chains on DK35SE with cab #17
Ok this may be a dumb question but does that part number contain 2 spacers (one for each wheel) or for the $291 do you have to buy two of them?
While my chains fit. (barely) just like yours did, If you do not maintain tightness perfectly, they hit the ROPS mounting. It would be nice to have the spacers, and at $291 for a set if that is the way they are sold, I would consider it. But at $291 each.. well not so much.
/ Tire chains on DK35SE with cab #18
Next question, is this a kit? does it come with the bolts and nuts needed?
/ Tire chains on DK35SE with cab #19
Everything is included for $290 to complete the install, you get the 2 spacers nuts/bolts, Shipping&Handling
