ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
What is the internal diameter of the new and old cylinders? It is easy to calculate the actual percentage change. It doesn't look quite like 50%, but hard to tell. I carefully lift up to the capacity of my loader from time to time, but a friend mentioned the other day he doesn't pick up large rocks because it is "hard on the loader". If that were the case, I'd sell my tractor.
I hear ya. I leave my loader lift cylinders in the "height" position which limits lift capacity a little. Figure that gives me some cushion before reaching the capacity of the FEL/tractor. I carry rear ballast and use a Grapple. Sometimes I have to push whatever I'm lifting up against something so I can curl it back enough to be able to pick it up. So I know I'm exceeding the manufacturers intent when they designed the loader frame. If I added larger cylinders and continued to "cheat" as I do, I'm positive I would exceed their intent.
