Loader Introducing the Kubota Super L45!
   / Introducing the Kubota Super L45! #11
What is the internal diameter of the new and old cylinders? It is easy to calculate the actual percentage change. It doesn't look quite like 50%, but hard to tell. I carefully lift up to the capacity of my loader from time to time, but a friend mentioned the other day he doesn't pick up large rocks because it is "hard on the loader". If that were the case, I'd sell my tractor.
I hear ya. I leave my loader lift cylinders in the "height" position which limits lift capacity a little. Figure that gives me some cushion before reaching the capacity of the FEL/tractor. I carry rear ballast and use a Grapple. Sometimes I have to push whatever I'm lifting up against something so I can curl it back enough to be able to pick it up. So I know I'm exceeding the manufacturers intent when they designed the loader frame. If I added larger cylinders and continued to "cheat" as I do, I'm positive I would exceed their intent.
   / Introducing the Kubota Super L45! #12
How does the change between "height" and "load" work? Is it a change in where the cylinder mounts?
   / Introducing the Kubota Super L45! #13
Yes, you change the location of the mounting pin. I do wish my loader had a power position, but alas, it does not...
The main reason that I wanted the increased lifting power is because I do a lot of landscaping with rocks. There are many rocks that I can start to pick up (like the one in the photo) with the stock cylinders but really it is the stronger curl ability that enables me to get them completely off the ground and move them around. There are other rocks that I couldn't really lift at all but if they were on a pile of dirt or elevated I can place the forks under them and then curl back and get to me destination ASAP before the cylinders leak down. Now I will not have to deal with that as much although of course I can now play with larger rocks. Being a TLB the hoe is always on the L45 for 3 seasons and if it does not have enough ballast on its own one can always adjust the hoe to increase the weight on the rear axle.
It is not my intention to suddenly start overloading the L45 on a constant basis. I think the Kubota 4-in-1 for the L45 is poorly designed as the hoses are exposed along the top edge of the bucket. I added a 6" wide piece of 1/4" thick steel plate to the top edge of the bucket with a piece of schedule 80 pipe on the top edge of it. This increased the capacity of the bucket slightly and that added weight plus the 100 pounds or so of my modifications to the bucket resulted in me be able to lift it full of wet soil but only high enough to get the spoil in my dump trailer with the side boards off. Now I expect I won't have to remove the boards when moving heavy, wet soil. But I have no intention of purchasing larger a larger capacity bucket for the L45 to move more spoil on a constant basis.
I forget the exact numbers but based on the cylinder OD's of the factory and new cylinders we estimated the piston size to be 40% - 50% larger but I do not have exact numbers. Unfortunately with winter upon us I have already installed my snow blade and next weekend the hoe will be removed and the snow blower attached so it will be spring before I can do any more thorough testing of the new strength of the L45. I am sure that the loader arms and pins on the L45 are capable of lifting an extra 1,000 pounds or so on occasion without the front axle collapsing, a pin shearing off or a loader arm bending.
Regards,
Lauren
   / Introducing the Kubota Super L45! #15
Lauren,
I agree with what you are saying in concept. But us humans tend to eventually use all the power/capability we are given. With caution you will be fine. Without caution the system will eventually fail somewhere. But then, I feel that way about my Grapple bucket too. It puts excessive strain on my FEL.
   / Introducing the Kubota Super L45! #16
Lauren wrote:
"I like the L45 but to be honest I always wished it had a little more loader lifting capacity. An L45 with the lifting capability of the M59 would be ideal for me. I looked seriously at the M59 before purchasing the L45 but the only one I could find was used and so in the end I went with the slightly lighter weight and full warranty of a new L45."
I can't help but wonder what a person of your ability would have done if you had started with the M59?
Creativity is the one thing that all R&D departments hope for ...... but it's the one thing nobody can command.
Kubota might have gained by the transaction if they had simply given you a new M59!
Nice work,
rScotty
   / Introducing the Kubota Super L45! #17
I still don't understand why they don't offer the TLB's with factory cab. :mad: It's such an excellent platform, and would be perfect with a factory cab option.
   / Introducing the Kubota Super L45! #18
The front axle might actually be up to it. I believe one of the upgrades from the L39 to the L45 was the addition of the M series front axle.
ac
Yeah true, I broke my L39 fron axle dropping a large boulder in the bucket from my excavator. L45 has lager curl cylinder.
   / Introducing the Kubota Super L45! #19
Out of curiosity, did you try increasing the setting on your loader's pressure relief? It wouldn't give you nearly the capability you have now, but it does make a difference. I've increased mine and it's helped picking up some large objects (although in all fairness, it's not like I've tried it both ways on the same object).
I wouldn't attempt to put larger cylinders on mine that would increase the capacity by 50%, but the loaders are much more beefy on the dedicated TLB's than they are on the standard tractors.
Poor picture quality, but this larger rock maxed me out. View attachment 401403
I'm jealous of your rocks... mine are too many to deal with and up to basketball size. Just a pain in the butt. Can't do much with them.
   / Introducing the Kubota Super L45! #20
Rocks & Rocks
Note I have 750 lbs of inner and outer wheel weights, a 120 lb thumb on hoe, The loader tube s are stuffed with 4" dia. steel bars and some other reinforcmets, that adds toatal of =1000 lbs to my L39,
Note rear wheels are very light. I'd need a heavier built machine to lift more. Front Axle is not up to it, 39 HP is already a lot to move an 8,000 Lbs empty tractor, and hydraulics are set as much as I dare.
Lauren,
How do you keep rear on ground with those new pistons. What did you set your hydraulic pressure? My factory setting was way low, as new it could only lift about 1,500 Lbs, I figure about 2,500 Lbs. now at 2800 psi. (Near 2,000 hours on Tractor)
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2018 Kubota B2301 (A53317)
2018 Kubota B2301...
2018 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
Rooster Wooden Statue (A55853)
Rooster Wooden...
2010 Chevrolet Equinox SUV (A55853)
2010 Chevrolet...
