battery
/ battery #1
blake037374
Baton Rouge, LA
CT440
anybody know what kind of battery to put in the ct440.....there is zero markings on the original.
/ battery #2
There are several ways of doing this. Measure length, width and height and buy a battery based on that. Take the old battery with you when you buy a new one and match it that way. The owners manual usually indicates the battery capacity in amps or cca's or sometimes even a part number.
/ battery #3
I usually just take the old battery to the store with me and have them get me the highest CCA's they have in that size battery.
/ battery #4
I'l check for you in the morning. Mine is out of the tractor while I'm cleaning up corrosion. I'll see if there is a part # or anything on it.
/ battery #6
^^ Yep. My CT445 has a group 24 battery as well.
/ battery #7
Consumer Reports Rated #1, Walmart's Everstart MAXX-24 group 24 with 750 cca
/ battery #8
Last time I looked, Wal-Mart batteries are about the cheapest.
/ battery #11
Had my battery split open last winter. 3 year old stock battery on my CT335 replaced it with an Exide battery, group 24. The acid did a number on the bolts and frame :mad:
/ battery
mooseriver,
I bought some battery cleaner from lowes....sprayed my whole battery with it waited 5 minutes and washed it off. I was surprised how good it did. when I get home ill try and look for name but if not just ask them for battery terminal cleaner.
/ battery #13
I put in a Exide AGM 24f just yesterday. Been meaning to for quite some time. I got my tractor in 2011 and only had acid leak the 2nd summer. Luckily I was aware off the issue and had the composure to check. I used a little battery cleaner and escaped damage with no other occurrences on the frame but the battery had always shown signs of leakage on its case. Slight dampness and staining as it had when I brought its core in. Stroke that off my list.
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
(4) MOUNTED 2000 LB TRAILER JACKS (A64280)
(4) MOUNTED 2000...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2023 MANITECH MTECH-2.0T TELESCOPIC WHEEL LOADER (A64279)
2023 MANITECH...
