battery
/ battery #1
blake037374
Baton Rouge, LA
CT440
anybody know what kind of battery to put in the ct440.....there is zero markings on the original.
/ battery #2
There are several ways of doing this. Measure length, width and height and buy a battery based on that. Take the old battery with you when you buy a new one and match it that way. The owners manual usually indicates the battery capacity in amps or cca's or sometimes even a part number.
/ battery #3
I usually just take the old battery to the store with me and have them get me the highest CCA's they have in that size battery.
/ battery #4
I'l check for you in the morning. Mine is out of the tractor while I'm cleaning up corrosion. I'll see if there is a part # or anything on it.
/ battery #6
^^ Yep. My CT445 has a group 24 battery as well.
/ battery #7
Consumer Reports Rated #1, Walmart's Everstart MAXX-24 group 24 with 750 cca
/ battery #8
Last time I looked, Wal-Mart batteries are about the cheapest.
/ battery #11
Had my battery split open last winter. 3 year old stock battery on my CT335 replaced it with an Exide battery, group 24. The acid did a number on the bolts and frame :mad:
/ battery
mooseriver,
I bought some battery cleaner from lowes....sprayed my whole battery with it waited 5 minutes and washed it off. I was surprised how good it did. when I get home ill try and look for name but if not just ask them for battery terminal cleaner.
/ battery #13
I put in a Exide AGM 24f just yesterday. Been meaning to for quite some time. I got my tractor in 2011 and only had acid leak the 2nd summer. Luckily I was aware off the issue and had the composure to check. I used a little battery cleaner and escaped damage with no other occurrences on the frame but the battery had always shown signs of leakage on its case. Slight dampness and staining as it had when I brought its core in. Stroke that off my list.
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2019 Mercedes Sprinter 2500 Cargo Van (A61573)
2019 Mercedes...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
