dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,798
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I'm not so sure about "out of harms way" however. Anything mounted on the boom,
especially on the underside, has a risk of being damaged. Why not mount the valve under the operator's station and
just run 1/4" hose to the cylinder from there? That would also eliminate the need to run electrical wires out to the
boom.
No installation is going to be completely out of harm's way, IT.
If you mount the valve close to the operator's station, then the wire is more protected, yes, but now you have
hoses to deal with. They must go along the boom and dipper to the cylinder, exposing THEM to damage.
AND, if you use 1/4" hoses they will have to be at least 8' long each, resulting in more flow restriction. Of
course, you could make hardlines....
I was able to run my wires thru the boom, so they have minimal exposure. There is no room to run more
hoses thru the boom.
Once I decided to put the valve near the bucket/thumb cylinders, I had a choice of mounting it to the
bkt cyl, on the thumb cyl, or side of the dipper. I went with the thumb cyl because
my applications (deep in the woods here) put the valve at lower risk. Others may have less tree branches
to deal with.
