Custom hydraulic backhoe thumb
/ Custom hydraulic backhoe thumb #41
Nice job. I have to get around to doing this on my Woods BH-90x. I have a mechanical thumb but find it next to useless so I don't use it. I could definitely use the hydraulic version though.
/ Custom hydraulic backhoe thumb #42
MEA,
The valve is a Hydraforce SV08-24-6T-N-12DS
As mentioned earlier, I tried to order direct from Hydraforce, but no joy. They referred me to one of their dealers Hydraulic Controls in the S.F. Bay area 510-658-8300, who referred me to their branch in Yuba City, CA (closer to me). Called them and it wasn't in stock, 3 week wait and I flew over to Sutter County airport and they met me there with the parts!
Hydraulic Controls, I think, has outlets all over, so you might could find one close to you.
I used two 3/8 JIC female 1/4 inch hoses, one 24" and one 18" (stock lengths) from surpluscenter.com/Hydraulics/
I bought all the hydraulic fittings from Discount Hydraulic Hose
One particular part, the SAE 8 O-ring to SAE 6 O-ring 90 degree, I could only find at discount hydraulic hose:
O-Ring Boss (ORB) Union 90ー Elbow part 6807-08-06
This goes from the cylinder (assuming you use the same one I am using, as it has SAE 8 O-ring flush ports) and the hydraforce valve has SAE6 ports. This fitting allows the valve to fit nice and snug (snugger than what I've shown in my pics - as this particular fitting was out of stock so I used two fittings to "get there"). I have the right one now and will install it when I lengthen my cylinder a little. (OCD . . . the cylinder works as is, I just can't leave good enough alone - it's a sickness :c).
BTW, you will be replacing the 3/8 JIC male to 1/4 NPT 90's on the BH77 cylinder with street T's 3/8 JIC 1/4 NPT
Plumbing is a piece of cake.
Oh, the switch I used is this'n: Amazon.com: Alpinetech 19mm 3/4" Waterproof Momentary Stainless Steel Metal Push Button Switch Screw Terminal Extended Button Normally Open 1NO: Automotive
bumper
Thank you , I will let you know how I make out.
/ Custom hydraulic backhoe thumb #43
When swapping curl cylinder fittings, I used a step ladder to block up the dipper stick so the ram end of the curl cylinder was almost level (ram end a little higher), then removed the upper pin from the curl cylinder and used a wood blocks to keep that end of the cylinder higher. Relieve any pressure on curl cylinder with joystick. This is all necessary as otherwise there would be no room to install the street T fittings. Note when removing the original 90's, they are screwed in **** for tight - - I mean *seriously* tight. I had to use a large adjustable wrench to get enough leverage to break them loose. Pipe wrench would have worked too, but those were at the hangar.
Even w/ steps to get ends of cylinder higher and remove pressure, there will still be leakage of course. Car drip pan, garbage can lid, etc is helpful, along with lots of paper towels. Pre- teflon tape the new NPT threads before starting.
I purchased the anti-chafe hose sleeve from Amazon: Amazon.com: apache hose and belting inc 39020518 1.59 -Inch ID x 15 -Feet, Nylon Protective Hose Sleeve: Industrial & Scientific
best,
bumper
Getting the cylinder length and stroke just right makes a big difference. I remember when I got
my first hyd toplink, an off-the-shelf unit. Worked OK, but when I went with a custom cyl with
the stroke and length optimized for my CUT and implements, it was much better. I hope
this thread shows that clearly.
Since the cylinder is harder to modify than the dipper bracket and the thumb itself, I would
encourge people wanting to make a hyd thumb to get a cyl that you DON"T modify, and
adapt the thumb and dipper bracket to IT.
/ Custom hydraulic backhoe thumb #45
dfkrug,
No argument from me. But, you were fabricating your thumb from the get-go, so that has your approach making a lot of sense. For those adapting an existing manual thumb (Kubota sells only the manual thumb option for their BH77 hoe) it makes more sense to leave the mechanicals as is . . . the BH77 hoe comes with a nicely welded on and substantial upper thumb cylinder bracket, whether or not your order the thumb. Guess they figured it makes more sense to make all the dipper sticks the same.
Modifying the cylinder is both straightforward and easy enough if you have a metal cutting band saw, as all you need do is cut off the cylinder end tube. Insert a 1/2" spacer and reweld it. I did this when modifying an off-the-shelf cylinder for my TnT tilt (cut apart fixed support link and used the ends on the cylinder. I disassembled cylinder for welding, though wrapping with wet rags, could probably have gotten away with leaving it intact.
I took the tractor to the shop today with the intent of modifying the thumb cylinder. I thought it was maybe 1.5 inches too short. Actually, it's only 1/2" short. Now admittedly, that 1/2 inch translates into 4 inches of movement at the distal end of the thumb. So I decided I didn't have time to make the mod now, as it really doesn't buy me much. The cylinder I purchased is a good match for the BH77, and has the advantage of flush ports that can be adjusted circumferentially to exit where needed (cylinder end only two choices, 90 degrees apart). I'll run it like it is for now, and knowing me, probably still add the spacer one day - - maybe.
bumper
Actually, I did not fabricate this hyd thumb using a new design from scratch. So I had to modify an
off-the-shelf cylinder for the correct stroke and closed length (see post #4). I had built up several
thumbs that fit my hoes, but were initially intended for mechanical use. The cylinder pivot point on
the thumb was fixed and I was not going to make another thumb to move it.
I understand that some folks will not want to design from scratch in order to keep from changing their
thumb or their existing dipper bracket. In starting this thread, it was my intent to show what I did,
but also talk about tradeoffs and suggest other approaches that may be easier.
But if someone wanted a hyd thumb and had not made any commitments, then I would suggest
making an off-the-shelf cylinder of the right diameter the "dependent variable", and the dipper
bracket position and the thumb pivot the "independent variables". I DO think that removing and
welding a new dipper bracket is easier than cyl mods.
/ Custom hydraulic backhoe thumb #47
You are obviously very talented, no question . . . and your posts were a huge help to me in "hydraulicizing" my thumb. But, I disagree with your last contention, at least as it applies to the Kubota BH77 (and probably BH65), inasmuch as the upper thumb bracket is "seriously" welded to the dipper stick. To remove it would both risk destroying the bracket itself, which has welded in bosses for the pin, or compromising the integrity of the dipper stick if the removal effort was botched. This is exacerbated by the bracket being welded along both edges of the sides of the dipper stick, and then also across the recessed bottom of the dipper stick in a position that would be all but impossible to remove copious amounts of grinding. Also, to even consider thumb bracket relocation would mean the use of hand tools (electric or otherwise) though it would be "easier" if one remove the whole dipper stick. Okay, one could cut off just the sides of the bracket and then start over that way, but even that's more work than "adjusting" a cylinder's length or shortening its stroke.
Increasing the length of a hydraulic cylinder I find to be no problem, can be done in the generally recommended "disassemble first" method, or the "wrap it with wet rags and don't weld near the seals" method (some recommend filling with water first). Takes a little more work to decrease a cylinder's length, but if that was my only alternative, it's doable too. Both these options obviously require a modicum of welding and fabricating skill, and it's nice to have a machine tools as well.
bumper (with "hobby" machine shop)
/ Custom hydraulic backhoe thumb #48
Are there any concerns with the flow rate limits of the solenoid valve you have chosen?
The SV08 is only rated for 4.5 gpm.
ac
chosen?
The short answer is no.
Remember that flow is shared with both cylinders when the valve is open. Of course, both
cylinders do not move at the same time usually, due to different loads.
Also, I do not run my hoe at the full engine RPM where I get my specced 8.3 GPM.
Finally, the flow rating from the manufacturer must make some account for duty cycle. Any
sustained flow that I subject it to will be for a few seconds at a time. I do not know
how Hydraforce rates their valves, but I am sure that it is rated for 4.5GPM over a longer
period, and it can tolerate momentary excursions into higher flow conditions.
Oh yeah, it has worked very well in the field for over 6 years.
/ Custom hydraulic backhoe thumb #50
Ok, just checking. I might choose the SV10 series just to have a little head room. My machine is rated at 11.8 GPM and the SV10 series is 10gpm.
ac
/ Custom hydraulic backhoe thumb #51
I basically copied dfkrug . . . using an SV08 on a BH77 hoe. Works just great, but does take a few minuted to get used to. As df said, the cylinder facing the least resistance works first/fastest. This means that when you want to pick something up, and place either bucket or thumb on or near the object, that's pretty much where it gets grabbed. i.e. if the bucket teeth are on the ground, the thumb is coming over to meet it! To pick up a large rock or chunk of concrete that would be too big for the bucket alone, simply curl the bucket under it, then activate the thumb to hold it in position. It's amazing what you can pick up that way!
I'd have to say that dfkrug really did come up with a simple, straightforward, and relatively inexpensive way to hydraulicize a mechanical thumb and add a bunch of usefulness in the process. Thanks!
bumper
/ Custom hydraulic backhoe thumb #52
Any hindering when you are reaching for objects at full reach for the backhoe which would require the bucket to be fully open and the thumb fully extended to grab an object?
Any of you guys with these setups have any action videos?
ac
/ Custom hydraulic backhoe thumb #53
ac
If I understand your question correctly, to position the thumb fully extended with bucket fully open would require you to touch the bucket teeth or edge against the ground (or other object) and then fully extend thumb. Then de-energize thumb solenoid and fully open bucket. I've done this, but in most instances it is both quicker and easier to touch bucket against item to be grabbed and then energize solenoid and extend thumb. Sounds complicated, but it becomes second nature quickly.
No vids, and the box scraper is on the tractor at the moment, some thoughts . . .
Operating with curl and thumb cylinders in parallel (with momentary switch to lock or unlock thumb cylinder - I use a push button switch on right joystick)
a) Whichever has the least resistance to movement will move first; This means that with the dipper stick just "hanging there" if you move the joy stick to uncurl (extend) the bucket, the thumb will move to it's "stowed" position first - this is due to the heavier bucket having to move against gravity. i.e. the lighter thumb retracts first, then the bucket uncurls or extends fully. If you then release the button (de-energizing the solenoid valve and locking thumb cylinder) the the hoe is ready for normal digging with the thumb tucked up and out of the way.
If you the want to pick something up from the thumb "put away" position, there are a couple of basic ways to proceed. Curl bucket, and/or move bucket with dipper, towards or against "something" and push the "thumb button" while continuing to curl the bucket. The bucket will stop or slow when it comes up against resistance - the thumb will then swing into position against the object and both thumb and bucket exert increasing pressure together upon object. Alternately or in combination with the above, you can leave thumb partially extended and use bucket against pre-positioned thumb (as one would do with a mechanical thumb. Or use a combination of the above, positioning thumb for best advantage.
b) Once the bucket and thumb are in contact and exerting pressure on an object, one cannot move both thumb and bucket in harmony (i.e. curling bucket while retracting thumb together) to "swing" or position object - further positioning can only be accomplished using other backhoe functions, dipper, boom, or swing. I practice, this isn't really much of a functional limitation.
c) In use, the "follow the leader" or "me too" operation of thumb and bucket quickly becomes instinctive and natural, though I had my doubts at first as it seemed a little clumsy as I tried to pick something up with finesse.
bumper
/ Custom hydraulic backhoe thumb #56
It'll work, though it's bigger than the SV8 I used. For details, see: http://www.hydraforce.com/Solenoid/Sol-pdf/1-016-1.pdf
BTW, the ebay price looks to be about what retail would be brick and mortar. Only problem is that this valve is hard to find "in stock". I paid $45 each for the two SV8's I bought.
bumper
/ Custom hydraulic backhoe thumb #57
bumper
Yeah, I liked that this valve is rated much closer to the gpm my machine will produce.
I saw the price was close to retail, but it seems much easier than making a dozen phone calls.
What did you use the 2nd valve for?
It looks like I already have someone to split these with.
/ Custom hydraulic backhoe thumb #58
Second one is a spare - not that I'll ever need it :c). For my app, on the BH77, I'm happy with the smaller valve as it works nicely and mounts in tightly out of harms way*. From the thumb's speed, flow is not an issue as it nicely matches the curl - gravity excepting of course.
The port on my cylinder is SAE O-ring, as is the valve. I was able to find a 90 degree SAE O-ring to SAE O-ring fitting at discount hydraulic hose (not shown in photo). I used 1/4" hose (for it's tighter radius and flexibility) with 3/8 JIC fittings. The whole installation tucked in nicely and looks clean. This photo shows the valve install with a JIC to SAE O-ring 90 as the right fitting was not in stock) so now it's even cleaner than shown in this photo - though I did have to take *everything* apart to get the SAE to SAE 90 installed - - one of those "gotta remove this, this and this in order to thread in this" things.
I am still going to remove the thumb cylinder yet again, cut off the mounting tube and weld in a 1/2 inch extension to make it just right. Quite usable as is, but **** is me I guess.
bumper
/ Custom hydraulic backhoe thumb #59
bumper
Bumper,
Did you check out the actual dimensions? The SV10 is almost identical in size. 1/2" difference is the largest change in dimension. The overall length is 1/2" longer and the diameter of the coil is about 1/2" larger. I'm not anticipating this making any arguable difference.
I don't really know what happens long term when you run a valve at 3 times it's rated flow rate (your machine isn't quite this dramatic of a difference). Since I found the SV10 so easily on Ebay I am not even going to worry about it.
I like your plumbing, and I plan to copy it. I took some pics of my curl connections:
The lower connection is obvious, how did you route the upper?
ac
/ Custom hydraulic backhoe thumb #60
bumper
Looks nicely installed. I'm not so sure about "out of harms way" however. Anything mounted on the boom, especially on the underside, has a risk of being damaged. Why not mount the valve under the operator's station and just run 1/4" hose to the cylinder from there? That would also eliminate the need to run electrical wires out to the boom.
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
LOOK! (A65640)
LOOK! (A65640)
