Custom hydraulic backhoe thumb
/ Custom hydraulic backhoe thumb
I'm not so sure about "out of harms way" however. Anything mounted on the boom,
especially on the underside, has a risk of being damaged. Why not mount the valve under the operator's station and
just run 1/4" hose to the cylinder from there? That would also eliminate the need to run electrical wires out to the
boom.
No installation is going to be completely out of harm's way, IT.
If you mount the valve close to the operator's station, then the wire is more protected, yes, but now you have
hoses to deal with. They must go along the boom and dipper to the cylinder, exposing THEM to damage.
AND, if you use 1/4" hoses they will have to be at least 8' long each, resulting in more flow restriction. Of
course, you could make hardlines....
I was able to run my wires thru the boom, so they have minimal exposure. There is no room to run more
hoses thru the boom.
Once I decided to put the valve near the bucket/thumb cylinders, I had a choice of mounting it to the
bkt cyl, on the thumb cyl, or side of the dipper. I went with the thumb cyl because
my applications (deep in the woods here) put the valve at lower risk. Others may have less tree branches
to deal with.
/ Custom hydraulic backhoe thumb #62
Looks nicely installed. I'm not so sure about "out of harms way" however. Anything mounted on the boom, especially on the underside, has a risk of being damaged. Why not mount the valve under the operator's station and just run 1/4" hose to the cylinder from there? That would also eliminate the need to run electrical wires out to the boom.
I've never smacked the tractor side (underside) of the dipper stick against anything, though I guess there's always a first time :c(.
I thought (briefly) about doing it the way you suggest, but then figured it would be easier to run one little wire out the boom than two hoses. I was going to have to run wire to the backhoe anyway (used Powerlet plug and jack). One of the advantages of using the solenoid valve is it's relatively small size and ease of plumbing, doing it out at the dipper is a lot easier on the BH77 with it's limited space for running new hoses the further outboard of the tractor you go.
To AVC8130, my smaller hoe doesn't have any hard tubing on the cylinders. I replaced the 90's on the curl cylinder with T's, then ran the new hoses (an 18" and a 24" IIRC) in a loose "S" config, the top one running less than half way down the curl cylinder before bending back toward the valve on the thumb cylinder. Everything works full stroke with no conflicts. I did put anti-chafe sleeve on anything than might ever rub.
bumper
I don't really know what happens long term when you run a valve at 3 times it's rated flow rate (your machine isn't
quite this dramatic of a difference). Since I found the SV10 so easily on Ebay I am not even going to worry about it.
If those valves are the correct function, then try them. When I was looking, most of the solenoid valves on eBay
required a manifold or were poppet-type valves, not spool-type. The L45 is a bigger CUT and has bigger cyls,
allowing for more mounting space.
I like that custom hardline you made.
/ Custom hydraulic backhoe thumb #64
bkt cyl as BUMPER does, or the inside or side of the dipper. I went with the inside of the dipper because
to deal with.
I appreciate that any installation will have pros and cons. I guess the vision of that valve sitting on top of the cylinder (or even under the dipper stick) makes me worry about inadvertently bumping it on a branch or stump when reaching out or swinging near brush. I agree that hoses are also a vulnerability but having already had to replace a BH hose that got busted by snagging in brush, the replacement of such a hose is pretty easy compared to potentially damaging a diverter valve. On the other hand, hoses aren't particularly cheap either. I think I would probably choose the location you did over bumperm's mounting just because I presume it would be a bit closer to the main boom/dipper "elbow" and less proud so as to be a bit less likely to snag something. It might be overkill but as long as one is mounting to that location it would be possible to fabricate a little cage for it to add a bit more protection.
Easy for me to critique at this stage as I haven't tackled the job yet myself. Thanks to both you and bumperm for blazing the trail and showing us where the potholes are.
You are right to be concerned.
Full disclosure here: I did snag one of my lines in my many hours of use. It was one of the 2 that goes around the
side of the dipper. I was thinking of making a guard plate for that area.....hardlines would not work there since
the hoses have to move a bit with the cylinder action.
As for the costs, you WILL pay more for a longer hose if you have to rush down to the hyd shop. More than the
50-odd clams that the valves go for.
BTW, I used another Hydraforce SV spool valve for my 4-in-1 bucket. I did not want more hoses on that boom, either.
/ Custom hydraulic backhoe thumb #66
I think I would probably choose the location you did over bumperm's mounting just because I presume it would be a bit closer to the main boom/dipper "elbow" and less proud so as to be a bit less likely to snag something. It might be overkill but as long as one is mounting to that location it would be possible to fabricate a little cage for it to add a bit more protection. .
Oops! This being one of those "forrest for the trees" things. dfkrug's valve is rotated 180 degrees on the upper cylinder port from mine to move it higher relative to the dipper stick. There's plenty of room to move mine to a similar position, I just didn't think of it. To do that, I have only to rotate the valve fitting to the cylinder port by 180* and then flip the valve body 180* so the hose and wire exit on the same side as now. Don't know that a cage is truly necessary, if it is needed, then it would stand to reason that the upper hydraulic fitting before adding the valve, if not located on the side of the thumb cylinder, would need similar protection. At least in my case, I don't think it does as I have never had anything impact my hoe there.
bumper
/ Custom hydraulic backhoe thumb #67
You guys are lucky - I was looking at my Case 580B today, want a thumb on it before next year - unfortunately, I may end up running new hard lines out the boom (hoses where necessary) because Case really buried anything that could snag.
Bucket curl connections are BETWEEN the cylinder and the boom, with access holes in the boom for the hoses to dive into and -12 JIC's - absolutely no room to play with those connections. Here's a pic from a few years ago when I re-hosed the hoe.
Oh well, if it was too easy it wouldn't be as much fun :confused: ...Steve
Yeah, industrial equipment is a lot harder to work on, but they go thru h3ll.
The guy who did the major excavation for my house had a Case 580 with over 30,000 hr on it.
/ Custom hydraulic backhoe thumb #69
Agree, it's tight. But this T connection may work I'd think: SAE 37° (JIC) Swivel Nut Run Tee
6602-12-12-12
http://www.discounthydraulichose.com/v/vspfiles/photos/6602-1.jpg
This would move the existing hose end fitting towards the hole in the boom, the T fitting going between it and they cylinder to provide perpendicular JIC males for the new hoses to connect, and exit parallel to the cylinder.
bumper
/ Custom hydraulic backhoe thumb #70
Guys, I may complain but I'm too stubborn to give this up without a serious fight - before I bought that 580 I was looking for a used Kubota, found the 580 and at first wondered why anybody'd want one - light on the front end for good downpressure backdragging (figured that one out), older ones you could take off the hoe and replace with a HERKY 3 point with both float and power down (got one, along with a Gannon box) - suffice to say, that's now ANOTHER thing they'll hafta pry out of my cold dead hands :thumbsup:
Bumper, I'll have to check out that run tee plan, thanks for that - also, I've been collecting tons of pix of any and all 580's from CK's up to L's, and noticed a few today that the curl cylinder is in upside down - that would put those inaccessible JIC's on TOP, and they would just clear the back end of the knuckle cap.
Downside is the hosing could get messy, gotta look at that more when I don't get a mouthful of rain :mad:
DF, after seeing how slick your "timeshare" is, I jumped the gun and ordered a pair of those Hydraforce valves, which may have been a mistake since the ones on e-pay appear to (maybe) be a -6 SAE instead of an 8 or 10.
NO biggee though, I'll find something they'll be good for - I'm down to only 25-30 projects for this winter anyway, wouldn't wanna get bored :laughing:
Now, back to your original program :rolleyes:...Steve
/ Custom hydraulic backhoe thumb #71
As long as it shows up and is the actual PN they claim, it has the proper function. I think the only differences between it and what you chose are the GPM rating and I believe it is NC and yours was NO. So basically the electrical function is opposite but that shouldn't matter.
Custom hardline? That is 100% Kubota there.
ac
Mine is NC (normally closed), but either will work. Since the thumb is not used more than half the time, I
designed for OFF or NC. Since these solenoids have 100% duty cycle, it is OK to have them ON most of the
time, then OFF for when you want to use the thumb/grapple.
HydraForce has a very nice PDF catalog that shows all the models and codes.
/ Custom hydraulic backhoe thumb #73
I am wondering about whether it would be possible to rig a simple system that would permit the bucket and thumb independently. If two of these on/off valves were stacked in series, would it be possible to rig 1) bucket only, 2) thumb only and 3) simultaneous operation. I cannot quite envision how this might work but wonder if some of you with more experience could figure out how to plumb that using the simple valves we have been discussing.
/ Custom hydraulic backhoe thumb #74
Mine is normally closed also. It must have been the other guy with the BH77 that used a normally open.
I don't think it really matters in the long run.
ac
/ Custom hydraulic backhoe thumb #75
Of course it IS possible, you'd need another valve on the curl to isolate it "off". I don't think it would gain you much.
You can isolate with the proposed setups to use the bucket any time you'd like. You can also "place" the thumb by locking the valve and it should hold any position you'd like. I'm not sure what advantage being able to move the thumb 100% separately would truly provide, but maybe something will come up in practice.
From what I can tell, and I haven't done it yet myself so my opinion is just theory based, this is a very cheap way to get a functional thumb. If it has limitations, I'll probably be more than willing to live with them knowing I saved $1500 on the hydraulics alone. I can and will use those savings to buy another implement.
ac
ac
/ Custom hydraulic backhoe thumb #76
ac
ac
I certainly agree this is a great bang for the buck solution. I guess I was just wondering what it would take to make it more flexible.
Why move the thumb independently? Well, when picking up some items it might be desirable to accurately place the bucket and then close the thumb. Let's say you were dismantling a stone wall and wanted to pick stones off rather than pull the wall over. If you use the standard method, whichever steel hits the wall first is going to push it. If however you could accurately place the bucket just behind a stone and then close the thumb on it to secure, it would work better. Kind of like being able to accurately "pick up sticks".
I honestly don't know if having independent thumb control would be a big advantage or not. Certainly the cheap and dirty dual movement is WAY better than manual control. I'm exploring possibilities, not complaining.
The "classical" method of setting up a diverter valve to steal power from the bkt cyl is to use a 2-spool
solenoid valve. Then you have truly independent thumb control, or independent bkt control. Clearly,
there are some uses where independent thumb control is valuable, as you mentioned. Using this
same setup for independent JAW control on my 4-in-1 FEL bkt would also give me one capability I
do not have. Sometimes I want to open the upper jaw when the FEL is high and full of dirt.
The biggest reason I used a SINGLE spool valve was not to save money. It was so I could locate
the valve, which is tiny, up closer to the action and avoid routing long hoses. I get one capability
that the 2-spool diverter design does not have, and I lose one capability, too. A fair tradeoff,
given the hose advantage.
/ Custom hydraulic backhoe thumb #78
Assuming I was comfortable running 1/4" lines from the operator station to the thumb cylinder, what "easy" options are there for installing a simple control valve that would permit independent operation of that cylinder? I wonder for example what it would take to parasitize one of the stabilizer lines (diverter valve?) that would leave the stabilizer in position while flow was diverted temporarily to the thumb. My understanding of hydraulic valving is really pretty naive so that might not be the reasonable approach. It seems however that there might be some home made solution intermediate between the now famous "dfkrug simultaneous operation" set up and the $1800 kit offered by Woods for independent control. Is a two spool solenoid valve necessary (seems to cost about $250 on surplus supply) or could a simple mechanical "solenoid" be used to divert flow to a separate control valve? As one would rarely adjust stabilizers once set, it seems plumbing something that would allow physically turning a valve from A to B at the operator station to divert flow might allow use of the stabilizer control itself to control the thumb. Is that nuts?
/ Custom hydraulic backhoe thumb #79
It's not nuts, it's possible. I don't see a lot of guys using mechanical valves around these parts, but I am sure it is possible.
You'd have to run the current stabilizer hoses to the new valve(s). Then hoses from that valve to the stabilizers. You'd also need hoses from the valve all the way to the thumb.
I have a feeling that the valve cost won't be the driving factor. By the time you buy the 2 long hoses I think hose cost will become quite significant.
My thought/plan is to install the single solenoid valve and have the thumb paralleled to start. This is SO much further ahead of the nothing I have now. I was about to hit the trigger for a mechanical thumb for $700. Then I saw this thread and realized a ~$50 valve would make the $1k hydraulic thumb possible. $1500 for the Kubota hydraulic valve/hoses was a complete show-stopper. $2500 for a hydraulic thumb was just never going to happen. I was so happy I could jump. (I might have.)
If this setup proves to be a "tease" and I want the full control, I'll worry about updating later. I'll have only sunk ~$50 in unrecoverable costs into the valves mentioned in this thread.
I'm really looking forward to the "pinch" thumb. My main use for the thumb will be picking up logs to cut for firewood. I have a rock retaining wall I want to relocate also. I have run through the operation in my head with this setup enough time to know I doubt I will miss the full control.
ac
It is completely feasible, IT.
You can get a 6-way, 2-circuit lever-operated diverter that would use flow from one outrigger. That WOULD reduce
your hoses along the boom to 2, and that's good.
I did a quick check and a manual diverter like this runs over $100, so it does not save much money vs. solenoid
diverters for the same task. If you put your solenoid diverters down near the operator, then you have more
flexibility re size and shape. I think you would get tired of manually switching whenever you had to move.
So....consider this valve, from the HydraForce catalog. One solenoid, six-way:
SV12-60 Spool-Type 2-Position, 6-Way Hydraulic Cartridge Valve
Not small in size, and I do not know what it would cost. You have to ask a disti.
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2018 Case TV380 (A64126)
2018 Case TV380...
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
