Grab hooks
/ Grab hooks #1
Moves
Member
Perkinston, MS
MF 231 1996; JD D110 2012
Hi all - I've searched everywhere I could and cannot find the answer to this question...
I have two lengths of similar chain, each with a similar grab hook at each end (2 chains, 4 grab hooks). If I want to connect them, do I connect the hook from chain 1 to a link on chain 2? Or do I connect the hook on chain 1 to the hook on chain 2?
In other words, can two grab hooks connect to each other safely?
(I'm trying to be precise in how I lay out this question bacause my brother is going to pick the quality of the question to death if he doesnt get the answer he thinks is right..... brothers....)
/ Grab hooks #2
Hook to chain. Grab hooks often won't even engage each other more than a little bit.
Bruce
/ Grab hooks #3
On all the chains I have with grab hooks the hooks do not couple or connect fully with each other. The grab hooks are meant to grab a link of the chain. to connect the chains together connect the grab hook to the chain not the other hook.
/ Grab hooks #4
Most "chain" hooks have the size (i.e., 3/8, 1/2 etc.) stamped on them...the "slot" of the hook is sized to grip a link of the stated size chain...
/ Grab hooks #5
When I connect two chains - I connect the hook of one chain to a link on the second. Reason - normally the hooks will not grab & hold each other. Hooks are normally designed to grab on to links and not other hooks. AND I see no difference on whether chain #1 is hooked to chain #2 or vice/versa. If I'm going to use the two chains, hooked together, for more than one pull - I will use wire around the hook/link attach point to keep them from falling apart. Hope this helps.
BTW - welcome to TBN.
/ Grab hooks #6
As already stated, Hook to Chain always with "grab" style hooks, with slip hooks you can get away with Hook to Hook.
Also, you might want to check out the new style "Twist-Lock" grab hooks we sell, guaranteed not to come apart!
Ken's Bolt on Grab Hooks <<Accessories>>
/ Grab hooks
Thanks all. Happy to know the answer. Sad to know my brother was right... Again... He had me wire the connections together.
On a lighter note, the assembly easily unstuck the tractor. (Yep, I got it stuck, not my brother; but it was him who almost burned down the barn last weekend :)
/ Grab hooks #8
You two sound like you're a blast to hang out with!! Never a dull moment! :laughing::laughing:
How often do you guys have to go to the emergency room? :laughing:
/ Grab hooks
Haven't yet, but we'll keep trying!
/ Grab hooks #10
I usually take one chain and hook the grab hook back on that chain, making a small loop, then hook the grab hook of the other chain to the center of this loop. It keeps the other hook from catching on things.
/ Grab hooks #11
Clever idea. :thumbsup: Could have used that yesterday.
/ Grab hooks
Zebra - that seems like the "go to" idea..... simple and seems like it would have less chance of coming apart when slack in the chain. It's gonna be my new technique.
/ Grab hooks #13
View attachment 394816 View attachment 394817
I saw these on the web and I like them. It's just that Ihave all my chains "hooked up". It seems the pin/spring/securing-device would be able to be added to old hooks, just replacing the pin.
