Snow Rearview Camera on Rear-mount snowblower tractor...Pros and Cons?
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #1
jix
Fredericton, New Brunswick. CANADA
2015 Kioti CK2510HST/CAB?loader/bush hog,front blower
Need your input please:
Thinking of putting a rearview camera rig inside my heated cab for seeing behind me without having to twist around and trying to steer. Cost about 50 bucks, 7" colour HD viewscreen, non-wireless camera, 140 degree field of view, mounted inside looking through rear window, attached to cab wit custom metal brackets.
In general, what do you guys think?..Pros and cons, experience lessons learned (tractor is small 18 hp Kubota with custom-made cab and ducted heater..manual tranny.) Driver is a geriatric.
Thanks, JIX
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #2
I would question the quality of a $50.00 camera.I have one on my cabbed Kubota,camera outside and a 5in.moniter.It's just fair,picture quality is not that good, I paid $241.00 for the supposed "wireless" unit which isn't really.You have to power the camera and screen,the transmission is wireless.
Mine was purchased from www.tadibros.com
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #3
Thanks, JIX
No need for HD monitor. The camera will not support it, most are pretty grainy at best unless you spend big $$$. Also the bigger the screen the worst the picture. Owners of cars/trucks that have the image in the rear view mirror 3.5" size find the image is much worse when they install a navigation unit with a 7" screen and switch the camera to it. I think you will have to spend a lot more than $50 to get a decent unit.
I think where wireless would be the way to go is if you wanted to monitor something like a horse in a horse trailer. If the trailer has a battery or there is a battery feed to the trailer then wireless would make the install easier. No real benefit on a car/truck or tractor. Plus hardwired will not have any interference problems. The only other benefit of wireless might be if you have multiple cameras. Say front and rear and you can just power up the one you want to use and power down and power up a different one to switch between cameras with one monitor.
I agree with you, $50 will not buy much of a camera system.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #4
You might want to go to the ( A back up camera for $50 ) tread by 94Bullitt as many seem to be very satisfied with those set ups . I am going to put one in my cab for this winter also .
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #5
If you are trying to steer by a camera/screen, you'll find the lack of depth perception a hazard. That's why the in car back up cameras have those lines on the screen.
Yes, I do agree about image quality, but the photo that Bullitt posted impressed me. I ordered the same unit(s) for that reason. I agree that wireless systems have interference issues.
My 50 bucks is not enough money to get anxious about, if the thing is junk. I wanted to try the concept of the idea at low cost...plus I have seen some pretty expensive gear that WAS junk.. Bullitt has done me a favor, by pioneering a cheap system..and he deserves thanks for that.
No, I do not think one should safetly depend solely on the camera for operation. It only can tell you if you are going in the correct path. I still intend to place rearview mirrors to give me other visual clues..and to turn and look behind me in a critical area, of course. I do not operate my tractor if there are persons, or other objects nearby, especially with a man-eating snowblower running.
Tractor machinery is dangerous if you are blase' about using it. It is dangerous whenever it is running. It is very much like gun safety. Mistakes, carelessness..kills people.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #8
I did install the $50 special (see 94bullit thread). The 7" monitor supports 2 cameras so I installed a 2nd cam on the front for use.with my forks. It's not HD quality but for $50 it works well.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #9
For $50, why WOULDN'T you put one in?? Worst case, you'll have to look over your shoulder anyway. I would think the biggest problem would be getting snow on the camera - it does tend to blow back in your face roughly 100% of the time...
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #10
If finding a place for the 7" monitor is problematic in a smaller tractor, you may want to try one of the cameras that is in a rear view mirror. I use my inside the cab mirror quite a bit and you said you wanted mirrors. Just a thought.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #11
Has anyone had problems with any over heating as a few of the comments on these and other units did have problems both mounted inside and out to the point of melting some of the other cameras . Might be a good idea to keep a close watch on them for awhile at least .
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #12
Jix, sounds like you've seen 94Bullitt's thread on this. He's done a lot of us a huge service by posting about the $28 7" monitor and the $12 HD camera. I've installed both (with the camera mounted outside under the cab overhang, rather than inside), and so far no problems with depth of field driving in reverse (carefully). I posted pics of the good image I get at post #120 on p. 12 http://www.tractorbynet.com/forums/customization/316927-backup-camera-50-a-12.html.
I've put about 15 hrs on the tractor since the install, with the monitor and camera on throughout. No overheating or any other problems. Anyone with a cab tractor should consider doing this and share the joy! Haven't seen any posts yet where someone has tried to use a rear snow blower with this set-up. That will be interesting to see. Some of us have mounted the camera outside, others inside as you are thinking of doing. Should have some snow reports coming within the next couple of months. :)
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #13
A year or so ago I put a rear view camera on my RZR4 so I could see when I had two kids with helmets in the seat behind me and a big cooler in the cargo area. I used a very similar one to the unit posted in the other thread and just ordered another monitor/camera for $36 from Amazon (was $50 but there was a price drop) as it worked so well on my RZR4. I sold the RZR and ended up buying a new Mule and plan to install the same system on it seeing it worked so well on the RZR. I have been wiring camera's for a lot of years (20+) and always feel wired is best if it is possible. I have worked with a LOT of high end wireless stuff and even the best can have more problems than a simple wired connection. These cheapie cameras really are good for the price. The one on my RZR was soaked numerous times, bang and shook harder than a camera should. The screen was under the roof of the UTV but got wet when it was washed, and got jarred around a lot. The hot and cold had not effect on the camera or the monitor. For snow use having the camera in a heated enclosure may help with the picture clarity due to snow build up issues.
Yes, Exactly!
I am putting the camera inside the cab, looking out thru the upper rear window. Big monitor on a suction cup mount on the front window...just above the steering window. it can be removed/relocated very quickly cause its a big window. Curved Mirrors are outside, like truck mirrors, on swivel mounts. It's a work in progress...creative thinking is the ticket. If at first I don't succeed, try it another way.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #15
I have a rear cam in my tractor and it helps a lot when backing up, as for snowblowing in reverse i still have to turn and look for myself when close to anything important. My neck still hurt alot after a hour, sooo i went to a front mount blower and solved all my problems.(neck). i do like the cam though as it give an extra eye.
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #16
Thanks for the kind words about the camera setup fellas. If anybody is looking for a smaller camera you can get them from amazon. There are 5', 4.5', and 3.5.'' Amazon.com: backup camera monitor
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #17
Now that I have installed a system everything looks like it will be just great but so far no snow yet. (thanks)
Main concern at this time is that specs quote range 0 deg F to + 40, does that mean that in real cold the camera will not work? or is my heated cab going to override that spec. Only time and cold will tell. Otherwise the image works just fine. ($55. setup)
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #18
Since it is in the heated cab you should not have to worry about the operating temp.
I doubt that the cold will much effect the electronics. Silicon chips are pretty good in cold. The bigger issue is condensation inside the camera lens, or trhe image screen of the viewer, which freezes. Most damage would therefrom occur by the expansion of freezing water if the relative humidity gets high in the cab. If the camera is waterproof that would solve the problem for the most part, I would guess...only time will tell.
..but it is so cheap to replace, who cares..mirrors cost more anyways,
/ Rearview Camera on Rear-mount snowblower tractor...Pros and Cons? #20
I've seen LCDs (liquid crystal display) freeze in the cold. They just don't work until they warm up. No lasting damage once they start functioning again though.
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
BOAT TRAILER (A60430)
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
