My first Kubota tractor B7100D
   / My first Kubota tractor B7100D
Consider chains all around to complete the unit. Also remember the dynamo has limited capacity so battery loads have to be watched.:thumbsup:
How will the cab heater circulation be designed?
Hi Egon: Thanks for the tip about the dynamo capacity. I cannot find out about that with only the operator manual or the parts book that I got with the tractor. It looks as if there is a generator on this tractor, as for a car type. This generator is located below the air cleaner in the space where the belt tensioner pulley is shown to be, so it is a mystery at the moment. THe seller told me that he thought that this tractor was manufactured in 1988 or 89, but it defginitely is a b7100d with a manual tranny with high and low ranges and selectable 4wheel drive. So I may need chains evan thoiugh my driveway is level, you think.
the heater will be connected to the bottom coolant hose, in series with the coolant circuit and the existing coolant block heater. That work is to be done by the mechanic who is making my custom cab,(He also owns a B7100D) and the core of the cab heater will have some kind of a fan behind it that will blow warmed air around in the the cab at a low point. I dunno how much it electric current it will draw yet, but now I am concerned about that. Tomorrow in daylight I must go and look more closely at the generator and also try to find the serial number of the beast. I must follow this up. There is something different about the generator, I do not think it is a dynamo, and it is not an alternator either. It may be a mod installed by the previous owner, who was a mechanic for Thomas equipment in Florenceville, NB. Thomas was a Kubota dealer a few years back.
Please do stay tuned. I may be asking more questions and will appreciate any helpful info you may offer. That will be critical, I feel.:)
I just dunno how much in the summer. Not a lot, cuz I prolly wont use it much in the summer, Newbury. The engine is about the size of a four slice toaster. 21 hp. Previous owner said that all he ever put in it since new was about 16 gallons total. Tank only holds 2.6 gals US.. Little tusker holds less fuel than a cigarette lighter...lol..
   / My first Kubota tractor B7100D #13
Jix, the dynamos fits on the hub of the fan blade. As you have a different setup my comments just may be adding unnecessary worries/confusion that are not warranted.
   / My first Kubota tractor B7100D #14
I found that a copper T fitting that is 1 1/4" on each end with a 1/2" nipple works great in the lower radiator hose to feed a 5/8" heater hose. I found this at Lowes.
Re: My first Kubota tractor B7100D Defining, searching, designing, heater progess
:laughing:I found a new Bosch 12v auxillary coolant pump on the internet in Carson, CA. for 40 bucks delivered. It would be for a VW. Not a bad price. I also found that my tractor has a 20-amp belt driven generator. Now searching for a heater core and fan box (scrapyard) to put in the cab. Now, if I can run my lights and heater, and if the little diesel makes enuff heat I should be nice and dry and warm in the cab. The safety glass for the windows is going to be 1200 bucks, with the rubber gaskets that hold them in the metal cab and two wipers. The fabricator will start work next Tuesday week and it will be all finished NLT 7 Oct. Putting in a ROPS too. Not as tuff, nor maybe as stupid, as I useta be. lol.. Wee little tractor weighs 1100 lbs nekkid! :eek:
Might try to find some wheel chains for it, not sure they are required, but cannot hurt to have 'em. Any body got some for sale? rear:8-16-4PR front 6-12-2PR
Zippity doo-dah! This might be fun.:cool2::cool2:
Hey, Travelover...thanx for the fitting tip. Gonna need them...and sum pipe insulation too. Stainess hose clamps, n' stuff. Its the nickels and dimes that getcha.
   / My first Kubota tractor B7100D #17
I found a heater core (new but surplus) at the metal recycler. You can also buy a new one on eBay or from an auto parts store for not much. I started with a 5" computer fan, but found it didn't move much air through the core, so I replaced it with a small fan off a RV stove hood exhaust. I used plywood to make a box for the core and fan and I will mount it vertically to the left of the engine and just in front of the foot rest. I also added a variable PWM speed controller so I can run the fan at any speed. I expect it to bake me out of there. 6V 12 24V 10A Pulse Width Modulator PWM DC Motor Speed Control Switch Controller | eBay
Egon...there is never a thing that adds unnecessary worry. Confusion motivates me to learn more and better information, and fires my imagination to discover innovations that lead to progress. Your posts do help me, as do others. I learn pretty quickly, and best when I must overcome doubts. one important fact I have learned is that my tractor has no water pump in the coolant circuit to drive hot coolant into the heater I propose. I overcame that today by discovering an aux pump made by Bosch for Volkswagens. I bought one today from California for only 40 bucks. Carpe Diem!
   / My first Kubota tractor B7100D #19
Jix, on the chains think about two lader for a better ride.
On the B7100 I had rear chains really made a difference. Adding chains to the front also really helped with the steering.
Rad covers for cold weather to keep temps up but with a cab you may not hear the whistle if overheated.
If yours has the old style rear hubs that loosen and let the wheel move around there are new hubs that work.
Overfilling the fuel tank means you'll get a soaked clutch.
G'mornin' Egon. Soaked clutch?? Well, I'll be darned.Can't figger that mystery.Hmmm. How full is overfull? PO kept it half full, judging from the discoloration of the plastic tank. I filled it up to the bottom of the filler tube filter, is that too much? Dread an empty fuel line. Nasty air bubbles...not in the *@%!! wintertime
Rad covers without a temp alarm or guage..poor idea. Gotta install a guage, or an idiot light. If she is hot enuff to whistle, she's way too hot. Little tractor has very few gauges..only hour meter. Needs temp, oil pressure, voltmeter. depth of bank account gauges. A tach would be nice, but difficult. Hmmmm.. mebbe trade her in on a new KIOTI k25 with factory cab..be cheaper??
Back to reality..keep the oil up..use her sensible. Drive her as built (except for a heated cab) till I drop dead. Keep it simple. Its not a game of gadgets. Practice good PM habits always.
Gotta find a just-right brick-sized heater core and smallish fan at a junkyard somewhere.... EBay guys are quite pricey, tryna get rich offa the net. E-bay has gone nuts past five years. I like junkyards better...sumtimes.
Make a heater box outa a square cookie tin, Currier and Ives-like...Hmmmm. Would smell good for awhile.
Just keep on head-scratching, it'll come.
Chains...hard to find in the right size in this locale. They need lotsa cross links on Ag tires, I s'pose. Chains are a pain, usually...unless you get stuck. Mebbe a 5000 lb winch, A la ATV. Nope..a big come-along. I got one awreddy..8 ton pull. Look for chains, sedately. meanwhile. :dance1:
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2014 POLAR TANK...
1794 (A58375)
1794 (A58375)
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
